19richie66 17,935 #26 Posted February 6 On 2/3/2026 at 7:17 PM, Bill D said: Based on the recommendation of another RS member, I picked up a small medical crane for moving disabled people. Excellent for lifting small engines. Hoya lifts are awesome. I got one from a lady in the neighborhood that was for her son but they never used it. Works great. Sad part is they have thrown out about a dozen of them here at the hospital. Mostly electric, some manual lift. Breaks my heart 😢 1 4 Share this post Link to post Share on other sites
Wayne0 1,634 #27 Posted February 6 I passed up a free one on CL cause the better half says I've got too much sh*t. (I really do) 1 1 Share this post Link to post Share on other sites
CCW 1,519 #28 Posted February 7 Used this crane last spring to lift and place six 350 pound blocks of concrete for a dock anchor. Planning on the same job again this spring on another dock. Worked perfectly and no strain on my back. Then mounted in my trailer to move a recliner I purchased. It is worth every penny of the $200 it cost at HD. 6 Share this post Link to post Share on other sites
kpinnc 18,969 #29 Posted February 8 Well I used my setup for it's intended purpose today, and it worked like a champ. K321 now has a new oil pan gasket and I lifted nothing. This thing is awesome! 2 4 Share this post Link to post Share on other sites
Treepep 1,151 #30 Posted February 8 Dad said just don't get old Nice stuff guys! 2 Share this post Link to post Share on other sites
peter lena 10,070 #31 Posted February 8 @kpinnc wait ! you can't do that ! thinkin and improving a problem area ? good for you , pete 1 1 Share this post Link to post Share on other sites
19richie66 17,935 #32 Posted February 9 On 2/6/2026 at 2:22 PM, Wayne0 said: I passed up a free one on CL cause the better half says I've got too much sh*t. (I really do) Having too much !%#$ and having something to lift that !%#$ is two different things 😁 2 4 Share this post Link to post Share on other sites
Spareparts 92 #33 Posted February 11 I am 80 and feel your pain about lifting, We pull Garden Tractors and always working to improve our engines, so I built a 1/2 size engine hoist to do the lifting re helps the old back 1 Share this post Link to post Share on other sites
kpinnc 18,969 #34 Posted February 12 Too late for a test run tonight, but all back together. This lift has helped so much. I never knew how bad I needed this! It lowered the engine gently down and all I had to do was nudge one way or the other until the engine settled in place. Neither the lift nor myself ever broke a sweat! Every once in a while, I fab up something that works! All too often a given project goes back to the scrap pile. 9 Share this post Link to post Share on other sites
c-series don 12,462 #35 Posted February 13 @kpinnc Every time I see that tractor I love it! It just looks bad ass! Duel spool valves, and a 3-point hitch 👍🏻Where are the front weights? 1 Share this post Link to post Share on other sites
kpinnc 18,969 #36 Posted February 13 1 hour ago, c-series don said: @kpinnc Every time I see that tractor I love it! It just looks bad ass! Duel spool valves, and a 3-point hitch 👍🏻Where are the front weights? Thank you sir. It is definitely a keeper. Has a few scratches and spots that need a touch up, but definitely one of my favorites. The front weights are about 4 feet away from it. I'll stick them back on when I finish it up. I thought it was all done but the electric clutch wobbles really bad and when driving it around today it started spitting oil from around the fuel pump. So this weekend it's getting an electric pump. The clutch can wait... 2 Share this post Link to post Share on other sites
steelsmith 34 #37 Posted February 13 My garage was put up back in the 1920's so there is only about 7' to the bottom of the 2X6 rafter. Knowing that it's bad to over work a back I needed a lifting point for a host/chain fall, So I went with 10' of un-a-strut and there 600# cap. trolleys, welded 2X3X6 " angle iron on top the the Un-a-strut to line up with the sides of each of the rafters, Drilled a 1/2" hole in each end of the angle iron and bolted them to the rafters. hooked my com a long to the trolley and now I can lift what ever I want and move it where ever I want along the 10' of rail. Worked so well that I did the same with a shorter run from the center of the garage to go over my work bench. Then I got a hoyer 400# patient lift , replace the casters with some bigger ones so I can use it in the drive way . spent about $50.00 on the Unistrut and trolley, $100.00 on the hoyer lift . ( now if only I can get people off my back ) Share this post Link to post Share on other sites
19richie66 17,935 #38 Posted February 13 On 2/11/2026 at 11:00 PM, kpinnc said: Too late for a test run tonight, but all back together. This lift has helped so much. I never knew how bad I needed this! It lowered the engine gently down and all I had to do was nudge one way or the other until the engine settled in place. Neither the lift nor myself ever broke a sweat! Every once in a while, I fab up something that works! All too often a given project goes back to the scrap pile. How about a closeup on the battery cables. I have some of those 50A Anderson plugs I want to put to use. Just wondering how you did yours. I want to be able to trickle charge the battery and that looks the part. Hope to have my Bronco 14 going soon. That’s inspiring 😁 Share this post Link to post Share on other sites
kpinnc 18,969 #39 Posted February 13 (edited) 3 hours ago, 19richie66 said: How about a closeup on the battery cables. All of my tractors have those. You can swap a battery in seconds. I also prefer to disconnect all my machines when they are not being used. Some have brackets holding the chassis side, some don't. And yes, trickle charging is simpler too. I've also never found a dead battery since I started using them a few years ago as there are no drains to bleed down. It's also nice to be able to wrench on a tractor without worrying about touching a hot spots. Some examples: Edited February 13 by kpinnc 1 1 1 Share this post Link to post Share on other sites
19richie66 17,935 #40 Posted February 13 23 minutes ago, kpinnc said: Thanks Kevin. Exactly what I wanted to see. Going to slap some on the herd. 1 Share this post Link to post Share on other sites
