horseman with no horse 68 #1 Posted January 30 i spent probably 2 hours screaming at my c120 and no matter what i do i cant get traction. i have 10 or 12 inch wide turfs with 2 sets of wheel weights on it. and its atrocious. i dont have tire chains and im broke so i cant afford aggs. what can i do to increase traction? i probably have 90 pounds on each tire, its like the blower just makes the whole tractor useless. i couldnt even back up 10 inches its pitiful Share this post Link to post Share on other sites
WHX?? 58,138 #2 Posted January 30 You don't need ags ... a set of chains on turfs will make a world of difference and weight ... never hurts but all the weight in the world will not help on sheet ice. Definitely sounds like you don't have it set up right. 6 Share this post Link to post Share on other sites
horseman with no horse 68 #3 Posted January 30 im not on ice, i can dig the snow its slipping in with my hands its so soft im gonna post a pic Share this post Link to post Share on other sites
horseman with no horse 68 #4 Posted January 30 my setup Share this post Link to post Share on other sites
horseman with no horse 68 #5 Posted January 30 15 minutes ago, WHX?? said: a set of chains on turfs will make a world of difference and weight ... ive heard great things about rubber chains, i have 23x 10.5 x 12 tires on the rear. where can i buy rubber chains? Share this post Link to post Share on other sites
WHX?? 58,138 #6 Posted January 30 What you need is a set of double link v bars. Your might have more trouble fitting any kind of chains with that battery rigamarole in the way. 2 1 Share this post Link to post Share on other sites
horseman with no horse 68 #7 Posted January 30 where would i buy a set of v bars for 23x8.5.12 tires? and how would i mount them? off the machine? Share this post Link to post Share on other sites
horseman with no horse 68 #8 Posted January 30 the battery tray is gonna probably be in the way i didnt think about that 1 Share this post Link to post Share on other sites
Ed Kennell 47,351 #9 Posted January 30 (edited) 53 minutes ago, horseman with no horse said: where would i buy a set of v bars for 23x8.5.12 tires? and how would i mount them? off the machine? Peerless Chain 24x10x12 ATV Tire Chains, 22x11.00x8 Minimum Tire Size, 15 lb., 2-Pack at Tractor Supply Co I also have a new set of 4 link McKay Vee Bars. PM me if interested. Edited January 30 by Ed Kennell 1 2 Share this post Link to post Share on other sites
JimSraj 585 #10 Posted January 30 (edited) You can mount the chains with the wheels on or off the tractor. Either way, I’d suggest deflating the tires, fitting the chains so they are even in every way and connecting the inside connector first then the outside. You may want to do this more than once to get them good and snug and evenly spaced. Then reinflate. The chains should be held in place without “snubbers” with this method. Btw, 2 link chains are better than 4 link but any chains are going to be a big improvement. good luck. PS. It’s not the Wheel Horse or the blower. It’s just lack of traction. I’ve got a 312-8 with a blower running 23 - 8.5x 12 with 2 link chains and I walk through 12” of snow on grass ( with the skids down) or on the pavement (skids up) no problem. Usually in low range 3rd gear or 1st gear hi. You may need to move your battery tray set up. Edited January 30 by JimSraj 2 Share this post Link to post Share on other sites
Racinbob 13,192 #11 Posted January 30 You've got enough weight. You need chains. Often you can lower the blower to the ground/pavement and blow your way through. You need chains. That takes the weight off the front and effectively adds to the rear. Did I mention you need chains? 4 1 Share this post Link to post Share on other sites
squonk 48,126 #12 Posted January 30 Those tires are pretty much wore out tread wise. Get chains. 2 1 Share this post Link to post Share on other sites
Racinbob 13,192 #13 Posted January 30 (edited) 8 hours ago, horseman with no horse said: ive heard great things about rubber chains, i have 23x 10.5 x 12 tires on the rear. where can i buy rubber chains? Here's one place. SoftClaw Rubber Tire Chains - Traction without damaging your surfaces I have them on both my blade tractor and the blower tractor. I love them and find that in most cases are as good as steel. Some cases a bit better. I also need them because of an asphalt drive. I do quite a bit of dirt work in the summer. They are excellent for that too. With that being said, would I choose rubber if I didn't have the asphalt drive? No. If for no other reason the cost. Edited January 30 by Racinbob 2 Share this post Link to post Share on other sites
Achto 32,707 #14 Posted January 30 Like stated above, tire chains are a key item for snow removal. If you don't have pavement that you are worried about, then go with regular chains not the rubber chains. You will be much happier. I'm running chains on my snow pusher with out added weight. Very seldom do I have an issue with traction. 2 1 Share this post Link to post Share on other sites
WHX?? 58,138 #15 Posted January 30 (edited) 13 hours ago, horseman with no horse said: im broke Nothin to be ashamed of we've all been there so we get it. 12 hours ago, Ed Kennell said: I also have a new set of 4 link McKay Vee Bars. PM me if interested. Bet I've got a set of chains you can have for shipping. They ain't much but but if you can't afford Ed Dog's. Bet the ranch others here have them they don't need. Chains are a regular in everyone's snow horse diet here. Edited January 30 by WHX?? 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #16 Posted January 30 I have chains laying around for 8.50 tires you can have for shipping as well. I bet @Pullstart has extras laying around too. Don't know how close you are to him. 1 1 Share this post Link to post Share on other sites
oliver2-44 11,751 #17 Posted January 30 Chains rubber or steel are the way to go. But for no cost lower the rear tire press to 3-4 psi as mentioned above. Also for the best additional low cost weight fill you tire fit rv antifreeze. 3 Share this post Link to post Share on other sites
WHX?? 58,138 #18 Posted January 30 4 hours ago, Racinbob said: choose rubber if I didn't have the asphalt drive? No. If for no other reason the cost. Actually Bob that's not a bad price for rubber. Not a great deal more than steel. https://tirechainsonline.com/lawn-garden-chains/11-12-rims/23x10-5x12/#product-listing-container 1 hour ago, Mike'sHorseBarn said: I bet @Pullstart has extras laying around too. Don't know how close you are to him. Bet he does too Mike. 1 Share this post Link to post Share on other sites
midpack 1,148 #19 Posted January 30 I had rubber chains, not very good on ice. Great on the flat driveway with no ice 2 Share this post Link to post Share on other sites
Pullstart 71,252 #20 Posted January 30 2 hours ago, Mike'sHorseBarn said: I have chains laying around for 8.50 tires you can have for shipping as well. I bet @Pullstart has extras laying around too. Don't know how close you are to him. 44 minutes ago, WHX?? said: Actually Bob that's not a bad price for rubber. Not a great deal more than steel. https://tirechainsonline.com/lawn-garden-chains/11-12-rims/23x10-5x12/#product-listing-container Bet he does too Mike. unfortunately it’s a couple two three hours plus curds. @SylvanLakeWH do you have any spares? 4 Share this post Link to post Share on other sites
pfrederi 21,151 #21 Posted January 30 (edited) You are missing the steel wheel that goes on the blower is there one missing on the other side also. That is going to make it harder to shove the blower ahead if it is down. Edited January 30 by pfrederi 3 Share this post Link to post Share on other sites
Achto 32,707 #22 Posted January 30 The one thing that I don't like about snow blowers is that it is usually cold out when you need to use them. 1 9 Share this post Link to post Share on other sites
SylvanLakeWH 32,520 #23 Posted January 30 32 minutes ago, Pullstart said: unfortunately it’s a couple two three hours plus curds. @SylvanLakeWH do you have any spares? Unfortunately no... 2 Share this post Link to post Share on other sites
WHX?? 58,138 #24 Posted January 30 37 minutes ago, Pullstart said: plus curds. 4 minutes ago, SylvanLakeWH said: Unfortunately no... Well what good are ya ... No curds for either of ya then ... 4 Share this post Link to post Share on other sites
WHX?? 58,138 #25 Posted January 30 14 hours ago, horseman with no horse said: how would i mount them? You get the chains we'll school on the many ways to properly install them. Jim S has already got you started. 3 Share this post Link to post Share on other sites
