oliver2-44 11,329 #151 Posted Tuesday at 03:45 PM There are some 2 part glazing putties that don’t shrink. They are a bit pricy compared to the old standard red glazing putty. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,896 #152 Posted Tuesday at 04:06 PM 18 minutes ago, oliver2-44 said: There are some 2 part glazing putties that don’t shrink. They are a bit pricy compared to the old standard red glazing putty. I'll check that out. Thanks. If it was only for the scale model building I'd be pretty resistant to the cost.. but if I had a good full scale vehicle product we'd likely try it on a future tractor project. Trina's 1045 for instance, has a very rough surface. Share this post Link to post Share on other sites
ebinmaine 77,896 #153 Posted Tuesday at 04:08 PM 16 hours ago, Achto said: One caution with glazing putty. Normally this is lacquer based and it will shrink under the paint allowing your imperfections to show through. Can you give a rough idea how thick/thin it needs to be limited to? We talking like a 1/16" ? Or less.....? Share this post Link to post Share on other sites
Achto 31,356 #154 Posted Tuesday at 05:10 PM 54 minutes ago, ebinmaine said: We talking like a 1/16" ? Or less.....? I would go with Or less. This is an excellent ultra fine body filler. I use it as the very last coat when doing filler work to get rid of any pin holes or minor imperfections. https://www.summitracing.com/parts/ucp-26006 This product runs a very close second. https://www.oreillyauto.com/detail/c/fantastic/u-pol-fantastic-glaze/upl2/up0922 1 Share this post Link to post Share on other sites
ebinmaine 77,896 #155 Posted Tuesday at 05:21 PM 10 minutes ago, Achto said: I would go with Or less. This is an excellent ultra fine body filler. I use it as the very last coat when doing filler work to get rid of any pin holes or minor imperfections. https://www.summitracing.com/parts/ucp-26006 This product runs a very close second. https://www.oreillyauto.com/detail/c/fantastic/u-pol-fantastic-glaze/upl2/up0922 Any thoughts or experiences with USC 32035 ? Share this post Link to post Share on other sites
Achto 31,356 #156 Posted Tuesday at 06:47 PM (edited) 1 hour ago, ebinmaine said: Any thoughts or experiences with USC 32035 ? Looks to be a lacquer based, use as packaged putty. Wii be fine for minor imperfections. USC 32035 Red Glazing Putty is a lacquer-based, one-component, fast-drying putty. It is designed for fine-finish filling of minor imperfections like pinholes, scratches, and chips. Edited Tuesday at 06:48 PM by Achto 1 Share this post Link to post Share on other sites
Handy Don 16,063 #157 Posted Tuesday at 06:57 PM 8 minutes ago, Achto said: Looks to be a lacquer based, use as packaged putty. Wii be fine for minor imperfections. USC 32035 Red Glazing Putty is a lacquer-based, one-component, fast-drying putty. It is designed for fine-finish filling of minor imperfections like pinholes, scratches, and chips. @ebinmaine, you might want to test this on scrap plastic first. Lacquer might be a solvent for styrene! 2 Share this post Link to post Share on other sites
ebinmaine 77,896 #158 Posted Tuesday at 08:44 PM 1 hour ago, Handy Don said: @ebinmaine, you might want to test this on scrap plastic first. Lacquer might be a solvent for styrene! I'd had the same thought... I believe it to be safe with thin coats. The recommendation is from a friend who's also a very long time modeler. 1 Share this post Link to post Share on other sites
ebinmaine 77,896 #159 Posted 4 hours ago Wheels & tires are on. Stance is good. Have to leave the front a little higher than I'd like for a day so the back set of wheels will dry straight. The 3D printed back end has been coated with Tamiya filler and wet sanded once. Now covered with filler again. Also been experimenting with fenders. At the back I've decided to use a stock styrene set from another kit. The fronts are longer and need a straight front corner to go up over the truck tires. I'll use a set from @Wheel Horse 3D for that. They have a corrugated wave, unlike the smooth rear set, but that's not the least bit abnormal for a road trailer. 1 Share this post Link to post Share on other sites
