oliver2-44 11,609 #151 Posted March 31 There are some 2 part glazing putties that don’t shrink. They are a bit pricy compared to the old standard red glazing putty. 2 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #152 Posted March 31 18 minutes ago, oliver2-44 said: There are some 2 part glazing putties that don’t shrink. They are a bit pricy compared to the old standard red glazing putty. I'll check that out. Thanks. If it was only for the scale model building I'd be pretty resistant to the cost.. but if I had a good full scale vehicle product we'd likely try it on a future tractor project. Trina's 1045 for instance, has a very rough surface. Share this post Link to post Share on other sites
ebinmaine 79,491 #153 Posted March 31 16 hours ago, Achto said: One caution with glazing putty. Normally this is lacquer based and it will shrink under the paint allowing your imperfections to show through. Can you give a rough idea how thick/thin it needs to be limited to? We talking like a 1/16" ? Or less.....? Share this post Link to post Share on other sites
Achto 32,035 #154 Posted March 31 54 minutes ago, ebinmaine said: We talking like a 1/16" ? Or less.....? I would go with Or less. This is an excellent ultra fine body filler. I use it as the very last coat when doing filler work to get rid of any pin holes or minor imperfections. https://www.summitracing.com/parts/ucp-26006 This product runs a very close second. https://www.oreillyauto.com/detail/c/fantastic/u-pol-fantastic-glaze/upl2/up0922 1 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #155 Posted March 31 10 minutes ago, Achto said: I would go with Or less. This is an excellent ultra fine body filler. I use it as the very last coat when doing filler work to get rid of any pin holes or minor imperfections. https://www.summitracing.com/parts/ucp-26006 This product runs a very close second. https://www.oreillyauto.com/detail/c/fantastic/u-pol-fantastic-glaze/upl2/up0922 Any thoughts or experiences with USC 32035 ? Share this post Link to post Share on other sites
Achto 32,035 #156 Posted March 31 (edited) 1 hour ago, ebinmaine said: Any thoughts or experiences with USC 32035 ? Looks to be a lacquer based, use as packaged putty. Wii be fine for minor imperfections. USC 32035 Red Glazing Putty is a lacquer-based, one-component, fast-drying putty. It is designed for fine-finish filling of minor imperfections like pinholes, scratches, and chips. Edited March 31 by Achto 1 Share this post Link to post Share on other sites
Handy Don 16,908 #157 Posted March 31 8 minutes ago, Achto said: Looks to be a lacquer based, use as packaged putty. Wii be fine for minor imperfections. USC 32035 Red Glazing Putty is a lacquer-based, one-component, fast-drying putty. It is designed for fine-finish filling of minor imperfections like pinholes, scratches, and chips. @ebinmaine, you might want to test this on scrap plastic first. Lacquer might be a solvent for styrene! 2 Share this post Link to post Share on other sites
ebinmaine 79,491 #158 Posted March 31 1 hour ago, Handy Don said: @ebinmaine, you might want to test this on scrap plastic first. Lacquer might be a solvent for styrene! I'd had the same thought... I believe it to be safe with thin coats. The recommendation is from a friend who's also a very long time modeler. 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #159 Posted April 5 Wheels & tires are on. Stance is good. Have to leave the front a little higher than I'd like for a day so the back set of wheels will dry straight. The 3D printed back end has been coated with Tamiya filler and wet sanded once. Now covered with filler again. Also been experimenting with fenders. At the back I've decided to use a stock styrene set from another kit. The fronts are longer and need a straight front corner to go up over the truck tires. I'll use a set from @Wheel Horse 3D for that. They have a corrugated wave, unlike the smooth rear set, but that's not the least bit abnormal for a road trailer. 3 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #160 Posted April 19 I've been working on adding layers of filler and primer, then sanding them to get the tank end smoothed up. I sprayed a coat of silver paint on that today. Pics later. Here, the left rear fender has been attached. 2 2 Share this post Link to post Share on other sites
Oldskool 6,678 #161 Posted April 19 That's looking really nice Eric. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #162 Posted April 20 Okay.. so on this tanker back end piece. I have the general shape 99% to where I want it. The current issue is that the 3D filament that it's made out of, and the filler I am using between those lines, sands off at two different rates. One of my customers this morning... He knows about such things... He said, "Why don't you make a mold out of silicone and then get some resin so that the piece you are trying to sand is all the same density." 4 Share this post Link to post Share on other sites
ebinmaine 79,491 #163 Posted April 24 Took some setting and resetting and patience... and I got the rear fenders where I wanted em. The pics don't quite show the angles right. They do sag to the outside away from the trailer. That lean is real. And on purpose. Some full scale trailers are built that way. I did catch that the fenders are a slightly different tilt. Decided to leave it. Sometimes life and machinery get tangled up and things get bent. I think the differing tilts adds to the realism of a working trailer. 6 Share this post Link to post Share on other sites
702854boy 964 #164 Posted May 24 Here's a model 57 Belair that I just made, its my first model that I have made 2 Share this post Link to post Share on other sites
Handy Don 16,908 #165 Posted May 24 On 4/24/2026 at 5:30 PM, ebinmaine said: tilts adds to the realism of a working trailer. Looks great. Will it have lighting? Certainly needs a clever vanity license plate! 1 Share this post Link to post Share on other sites
ebinmaine 79,491 #166 Posted May 24 18 hours ago, Handy Don said: Looks great. Thanks! 18 hours ago, Handy Don said: Will it have lighting? I'd like to.... but haven't found a way to make it happen that's realistic and reasonably priced. 18 hours ago, Handy Don said: Certainly needs a clever vanity license plate! Ya know..... I hadn't considered that. The more I do though... the more I like the idea. 1 Share this post Link to post Share on other sites
