BrianX128 115 #1 Posted January 27 (edited) Chasing an issue with no spark to cylinder #3 on my 52 vac, the plug gets extremely fouled and quits firing. If I take it out and sand it down clean and let the fuel evaporate in the cylinder or torch the hole real quick then it will run great all day. When it's acting up and is only running on three cylinders, if I hold the spark plug wire about an inch from the distributor then that cylinder will start firing again even if I don't clean it, but if I plug the wire back in then it stops firing. All 4 cylinders have 110psi of compression still, and I've replaced the plug wires and plugs but the problem is always cylinder 3. New cap made no difference either. Points are clean. The only thing I can even think of is it still has a ballast resistor on top of the engine, I could try bypassing that but what would you guys do? Nothing stands out given that it "can" run fine, no compression issues, and the problem always goes to the same hole. I've heard that weak spark can start working if you hold the plug wire away like I am and it "jumps", but I'm not sure why it only happens to this cylinder no matter what I do electrically. Edited January 27 by BrianX128 Share this post Link to post Share on other sites
ri702bill 12,040 #2 Posted January 27 It sounds like a shorting path to ground. Or maybe is it getting oil fouled?? Try switching the plug from #3 with another - see if it follows the cylinder or the plug... I have seen a bad plug before that when removed & grounded the spark jumped the gap just fine. Reinstall, and it would not work under compression. Changed the plug and it ran fine. Not so sure an inline spark checker would be of help - gives a false positive for the condition above... 2 Share this post Link to post Share on other sites
BrianX128 115 #3 Posted January 27 It stays with the cylinder, it's only done it on that cylinder. I've even taken the "dirty" plug out and put it in another cylinder and put a clean plug in the suspect one, and the dirty plug will fire fine in another hole. Tried switching the wires in case something was going on there as well, but problem stays with the hole. Ironically, this cylinder has slightly higher compression than the other three. It's probably closer to 115 while the other 3 are all either right at or slightly below 110. Hard to tell exactly with such small differences. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,208 #4 Posted January 27 When the plug fires with the wire held away from the plug you are increasing the plug gap which increases the spark voltage. With that happening one has to assume everything up to the plug is OK meaning the components are not leaking voltage to ground and the coil has the ability for higher output. Share this post Link to post Share on other sites
8ntruck 8,825 #5 Posted January 27 (edited) I've got a small block Chevy in my old ugly orange truck with sketchy valve seals or maybe worn guides. Th3 #3 cylinder was fouling the plug. As a stop gap, i installed a plug with a higher heat range in that cylinder. That patch has been working for several years now. Probly ought to mention that I don't drive that truck very often. Edited January 27 by 8ntruck 5 Share this post Link to post Share on other sites
BrianX128 115 #6 Posted January 27 Interesting thought, I'm not sure what the stock plugs even are. I've just been replacing them with what was in it after I inherited it from my grandfather. I'll check when I get home today and see what is actually in there. I know there were a set of auto lites and champions both in the little toolbox on the side. None of them have ever changed anything, but they could be the same heat too. Share this post Link to post Share on other sites
squonk 46,343 #7 Posted January 27 Oil fouled. The make anti foulers you can install on low RPM engines like a tractor, It raises the plug out of the cylinder to keep the oil out. If it is a high RPM or hard working engine you can burn a piston using them. Off the top of my head you may be able to use Autolite 386 or Champion 541 @pfrederi ? Share this post Link to post Share on other sites
BrianX128 115 #8 Posted February 1 I found an old 386 in the drawer of plugs, cleaned it up and originally made no change. I took it out, cleaned it up a second time but before I put it in I actually fired up the engine with no plug in #3 to see if I could let it "air out". After doing this, I put the 386 plug in and she immediately was firing on all 4. 1 Share this post Link to post Share on other sites
6wheeler 675 #9 Posted February 2 (edited) I found on my tractors. Both my 49 JD-A and my 65 AC 190XT, that using NGK plugs makes all the difference in the world. Your Case should take AB-6 NGK's Gapped at .035. I don't know if you have done this. But, you should also set your valve clearances too. On that VAC 0.014" on intake and exhaust. If you remove the resistor(obviously converted to 12v) you will end up eventually burning the points. It uses 12V to start and then the resistor drops to between 6 and 9 volts to run and save wear on the points. I wonder if the resistor gets "weak" when warmed up and cuts the voltage Too much? Just a thought....... Edited February 2 by 6wheeler 1 Share this post Link to post Share on other sites
BrianX128 115 #10 Posted February 11 On 2/2/2026 at 10:28 AM, 6wheeler said: I found on my tractors. Both my 49 JD-A and my 65 AC 190XT, that using NGK plugs makes all the difference in the world. Your Case should take AB-6 NGK's Gapped at .035. I don't know if you have done this. But, you should also set your valve clearances too. On that VAC 0.014" on intake and exhaust. If you remove the resistor(obviously converted to 12v) you will end up eventually burning the points. It uses 12V to start and then the resistor drops to between 6 and 9 volts to run and save wear on the points. I wonder if the resistor gets "weak" when warmed up and cuts the voltage Too much? Just a thought....... I actually ordered a set of new plugs, I took a look and all of mine were mismatched. I also think the fuel was too rich, the plugs were all extremely fouled but it doesn't burn any oil. I was able to turn the idle screw in a full turn and the high screw in 3/4 a turn and the tone changed slightly but in a healthy sounding direction. It also doesn't smoke black when wide open up a hill or under a load. 1 Share this post Link to post Share on other sites
6wheeler 675 #11 Posted February 12 Nice video. Glad to see it is running well. Do you put it to work at all? All of my tractors still have to work for a living. Nice to see these old tractors running. Good Job. Share this post Link to post Share on other sites
BrianX128 115 #12 Posted February 12 3 hours ago, 6wheeler said: Nice video. Glad to see it is running well. Do you put it to work at all? All of my tractors still have to work for a living. Nice to see these old tractors running. Good Job. Yes and no, it used to work a lot. My great grandfather and my grandfather used to use it all of the time when the back field was a small family farm. When I was a kid, it was basically just used to drag deer up from the field during hunting season and teach us how to drive something big and heavy with absolutely no brakes or safety features. After my grandpa passed it just sat for almost 10 years while I was in college and working right after. After my grandma passed when I moved out here I got it running again and actually used that finish mower hooked to the kubota in the background to mow a lot of the property (before I had the kubota). There are a lot of hills and trees in one half of the yard and old manual steering like it has vs the power steering kubota and it having 4 wheel drive made mowing with the case a bit pointless. Now I just use it to backblade the driveway after big rain storms and to haul wood back and forth to the pile or give the kiddo some rides. I've wanted to get a 3 point driven log splitter for it but missed out on those on facebook marketplace. Share this post Link to post Share on other sites
6wheeler 675 #13 Posted February 13 At least you get to play with it a bit. That is about 18 hp. So, it can pull a 2 bottom plow, either 2-12's or 2-14's. Food for thought if you ever want to start a garden. Good Luck Share this post Link to post Share on other sites
