tommyg 156 #1 Posted January 27 Anyone have any recommendations for an electric fuel pump for a D180? This tractor is retrofitted with a 25 hp Kohler Command engine with a pulse type pump mounted on the engine itself which really seems to be struggling to get fuel from the tank in the back. Once it's running it's fine, but man trying to get it started is gonna take out my starter motor. I know a low pressure pump is called for, but I'm not sure the pressure range. Willing to pay a little more for NOT a Chinese knock off (which may be asking a lot) so a manufacturer to look for would be helpful too. Share this post Link to post Share on other sites
WHX?? 54,693 #2 Posted January 27 (edited) We sure have been talking about these a lot lately. I use the offshore 9.98 ones with no problems but any low pressure 2-4 or 5 psi will work. Search on electric fuel pump to find those threads. Just installed a cheapy on a 520 that was a notorious hard starter. Started right up the other day at -15 out. Another one in progress. Edited January 27 by WHX?? 1 1 1 Share this post Link to post Share on other sites
kpinnc 17,088 #3 Posted January 27 (edited) In the short term, a primer bulb will help greatly. They certainly save batteries and starters when the fuel tank is that far back. I like my electric pumps, but I keep a couple primer bulbs on hand as well. The cheaper electric pumps can croak on you at the worst possible time... Facet low pressure (1-2 psi) electric pumps are best but they are expensive. Edited January 27 by kpinnc 1 Share this post Link to post Share on other sites
Stan50 80 #4 Posted January 27 (edited) 7 hours ago, kpinnc said: Facet low pressure (1-2 psi) electric pumps are best but they are expensive. I found something familiar link . PSI probably 4.5-7, there is some differences in psi description. Edited January 27 by Stan50 Share this post Link to post Share on other sites
squonk 45,414 #5 Posted January 27 I've seen too many of those cheapie and cube pumps fail prematurely in my auto parts store days. Use a Facet Posi Flo, Carbole, Mr. Gasket, Napa Balkamp. All the same pump in a different box. 4 Share this post Link to post Share on other sites
kpinnc 17,088 #6 Posted January 27 9 hours ago, Stan50 said: there is some differences in psi description. Lower PSI (1-3psi) is better. Otherwise you'll overpower the carb float and flood the crankcase. Very dangerous and also can destroy the engine. 2 Share this post Link to post Share on other sites
Stan50 80 #7 Posted January 28 I was wondering if someone using them. As of now I stacked 2 mechanical ones and I bought CarBole 2-3.5 psi, I'm waiting for delivery . I did fab 1/8 block off plate, just in case, I'm going to try another aftermarket plastic one first. Share this post Link to post Share on other sites
midpack 1,103 #8 Posted January 28 On 1/26/2026 at 8:07 PM, WHX?? said: We sure have been talking about these a lot lately. I use the offshore 9.98 ones with no problems but any low pressure 2-4 or 5 psi will work. Search on electric fuel pump to find those threads. Just installed a cheapy on a 520 that was a notorious hard starter. Started right up the other day at -15 out. Another one in progress. I have a couple of that type in machines, one has been in service for almost a decade. I used another one to build an electric pump to drain my maxhines for off seasonal storage. I ended up giving that one to my FIL because he put gasoline in a diesel tractor. He was able to get the contaminated fuel out easily. I let him keep it so he wouldn't have to lift and pour fuel containers. he's 88 yo and refuses to stop! We should all be so lucky Share this post Link to post Share on other sites
WHX?? 54,693 #9 Posted January 28 (edited) 2 hours ago, midpack said: been in service for almost a decade. Probably the luck of the draw. You get one that lasts for years or one that works a week. 2 hours ago, midpack said: build an electric pump to drain my maxhines for off seasonal storage. Good idea 2 hours ago, midpack said: able to get the contaminated fuel out easily. Another good idea. Maybe rig one up on a iv tank for running & testing motors "on the bench". Of course the big thing with this is observing safety protocols when working with fuels. Edited January 28 by WHX?? Share this post Link to post Share on other sites
pfrederi 19,822 #10 Posted January 28 I bought two of those gold can pumps several year ago. One is still working the other failed after just a few hours. Share this post Link to post Share on other sites
WHX?? 54,693 #11 Posted January 28 6 minutes ago, pfrederi said: other failed after just a few hours. Do you remember if it quit "clicking" or makes that noise and failed to pump? The thing I liked about these (electric) pumps is when you turn the key to run and the pump takes off you can hear, if you have decent hearing, the pump change pitch as the bowl fills and it changes pitch as the float shuts off fuel flow and the pump changes pitch building pressure. 1 Share this post Link to post Share on other sites
pfrederi 19,822 #12 Posted January 28 It has been a few years. But as I recall I was at the far end of the field when the C-141 just sputtered and died. No clicking from the pump. I agree one thing I like about electric turn the switch on listen to clicking when it changes bowl is full and it fires right up. Incidentally trying to tow a C-141 with a front mount mower several hundred feet is a real PITA 1 1 Share this post Link to post Share on other sites
AHS 1,591 #13 Posted January 29 22 hours ago, WHX?? said: Do you remember if it quit "clicking" or makes that noise and failed to pump? The thing I liked about these (electric) pumps is when you turn the key to run and the pump takes off you can hear, if you have decent hearing, the pump change pitch as the bowl fills and it changes pitch as the float shuts off fuel flow and the pump changes pitch building pressure. Yes!! I listen for that change in the tone of the pump, then i crank it. If you just crank it, you’ll be waiting for a while!! Share this post Link to post Share on other sites
kpinnc 17,088 #14 Posted January 29 On 1/28/2026 at 8:59 AM, WHX?? said: you can hear, if you have decent hearing, the pump change pitch as the bowl fills and it changes pitch as the float shuts off fuel flow and the pump changes pitch building pressure. I laughed out loud at the "if you have decent hearing" part. For me at least, it would depend on who you ask... But I agree: you can definitely tell when the pump primes the system and you're ready to crank. No more cranking forever that kills the battery before gas even makes it to the carb... 1 Share this post Link to post Share on other sites
tommyg 156 #15 Posted Sunday at 09:11 PM I ended up going with the Facet pump 1-2 psi. It was a relatively easy install. It's quite and seems well made. But it didn't solve my problem. Something else going on. Even still, I'm glad i replaced it. Share this post Link to post Share on other sites
lynnmor 8,594 #16 Posted Sunday at 10:43 PM 1 hour ago, tommyg said: I ended up going with the Facet pump 1-2 psi. It was a relatively easy install. It's quite and seems well made. But it didn't solve my problem. Something else going on. Even still, I'm glad i replaced it. Did you replace all of the fuel lines? If it is sucking air that could cause your problem. Share this post Link to post Share on other sites
tommyg 156 #17 Posted Monday at 02:59 AM 4 hours ago, lynnmor said: Did you replace all of the fuel lines? If it is sucking air that could cause your problem. I did. All new hose and filter. Share this post Link to post Share on other sites
peter lena 9,745 #18 Posted Monday at 10:31 PM @tommyg for me its the CARBOLE MICRO ELECTRIC FUEL PUMP , been bombproof verify the pressure you need , personally have the lowest pressure model 2- 3 psi , pete Share this post Link to post Share on other sites
kpinnc 17,088 #19 Posted Tuesday at 12:23 AM 1 hour ago, peter lena said: CARBOLE MICRO ELECTRIC FUEL PUMP , been bombproof verify the pressure you need , personally have the lowest pressure model 2- 3 psi , pete Two of mine are this same model and I like them very much. Available on the jungle site for about $25. The facet pump is very nice and is quieter (I have just one), but the Carbole is 1/3 the cost. So far they have performed about the same so far as I can tell. 1 Share this post Link to post Share on other sites
ineedanother 1,837 #20 Posted Tuesday at 02:34 AM I intend to convert the remainder of mine to electric pumps this year, time permitting. I'm an emergency manager so some of what I do is mitigation. With regards to small engines with cam-driven fuel pumps, mechanical pump inefficiencies and fuel leaks into the block are reasonable concerns. An electrical pump minimizes those threats to some extent. At this point I think the investment is easily justified. 2 Share this post Link to post Share on other sites
peter lena 9,745 #21 Posted Tuesday at 01:24 PM @ineedanother that pump has been bombproof for me , initially tried the small tube type , failed , also added a single green LED dash light to verify its operation , always experimenting with REPEDITIVE ISSUES / PROBLEMS , love doing that , go over EVERY STAGE OF FAULT / FUNCTION , NO MATTER HOW SMALL OR INSUGNIFICANT , ITS THE COLLECTION OF THOSE ,that makes for REPEDITIVE FAILURES , regularly marvel at how easily , lever , related movement can be . years ago , eliminated , pulley failures , lubrication , also functional detailing , actually pretty simple to make a change , and you would be hard pressed to see it , ex , the pto lever set up , is a STRUGGLE OF FUNCTION , every hand off point , adds to the drag . proof of the pudding is , no / zero issues / failures since , simple change . also no belt related bounce , you can't do that , pete 1 Share this post Link to post Share on other sites
Racinbob 12,730 #22 Posted 3 hours ago I've been using the Mr. Gasket 42s only because that's what I first bought. Outstanding pumps. Put any of the quality pumps in a bag, shake them up and pull one out. It will be fine too. I will never, never, never, never ever again use one of those cheapies. I just had another one fail. Some of you may have good luck with them but I'm at over a 50% failure rate. Unacceptable. The one that failed yesterday was replaced with a 42s this morning. I still have 2 of the cheapies sitting on the shelf. A product of some idiot buying them in bulk. Anybody can come get them if they want. Share this post Link to post Share on other sites
pfrederi 19,822 #23 Posted 3 hours ago 14 minutes ago, Racinbob said: I've been using the Mr. Gasket 42s only because that's what I first bought. Outstanding pumps. Put any of the quality pumps in a bag, shake them up and pull one out. It will be fine too. I will never, never, never, never ever again use one of those cheapies. I just had another one fail. Some of you may have good luck with them but I'm at over a 50% failure rate. Unacceptable. The one that failed yesterday was replaced with a 42s this morning. I still have 2 of the cheapies sitting on the shelf. A product of some idiot buying them in bulk. Anybody can come get them if they want. How far away a from the shop were you when it quit. I was on the far side of the field when mine died.... 1 Share this post Link to post Share on other sites
Racinbob 12,730 #24 Posted 3 hours ago About 900' which is about as far as I can get and still be on our property. 1 Share this post Link to post Share on other sites
squonk 45,414 #25 Posted 1 hour ago 1 hour ago, pfrederi said: How far away a from the shop were you when it quit. I was on the far side of the field when mine died.... That's where all tractors die. Either that or the farthest spot away from the tent at the tractor show! 3 Share this post Link to post Share on other sites
