Joker72 96 #1 Posted January 25 (edited) I was plowing with my C-160 (relatively new to me) and it was performing like a champ. I parked it after a second go round at the snow and took a nap. Woke up went out to do a little more and it would not lift and then I noticed it would not roll either. The fluid looks perfect in the hydro. Hoping someone has an "ah haa!" quick fix. My toys broken. Thanks! Edited January 25 by Joker72 1 Share this post Link to post Share on other sites
pfrederi 20,823 #2 Posted January 25 Hydro? Sunstrand ... Tow valve tightened up? Did you push the engagement lever all the way down? Belt running ?? Hydro input pully turning 2 Share this post Link to post Share on other sites
Joker72 96 #3 Posted January 25 Yes. Hydro Sustrand. Having trouble finding the tow valve. Going back out to inspect. Share this post Link to post Share on other sites
Ed Kennell 46,462 #5 Posted January 25 (edited) Belt tensioning spring broke. Roll pin on left side of the clutch cross shaft. Input pulley key. Edited January 25 by Ed Kennell 2 Share this post Link to post Share on other sites
Joker72 96 #6 Posted January 25 (edited) The push valve is not moving without soaking in PB blaster. I don't see any exposed pullys or belts to tell if it's turning. Did fully engage the lever again just for certainty. Thanks! Edited January 25 by Joker72 Share this post Link to post Share on other sites
Joker72 96 #7 Posted January 25 @Ed Kennell Where would I find the belt tensioning spring? Share this post Link to post Share on other sites
pfrederi 20,823 #8 Posted January 25 (edited) Rusty spring Edited January 25 by pfrederi 3 2 Share this post Link to post Share on other sites
Ed Kennell 46,462 #9 Posted January 25 First, like Paul said, with the engine running and the Hydro engaged, look for the transmission pulley behind the front of the rear right tire. It should be turning. 1 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,321 #10 Posted January 25 4 minutes ago, Ed Kennell said: First, like Paul said, with the engine running and the Hydro engaged, look for the transmission pulley behind the front of the rear right tire. It should be turning. And make sure the shaft the pulley is on is turning with it. 1 2 Share this post Link to post Share on other sites
Joker72 96 #11 Posted January 25 It's a miracle. I disengaged the mechanism in the pic above and re-engaged it and Shazaam! Thanks for your help Guys. I saw everything turning as expected. Thanks so much. 3 Share this post Link to post Share on other sites
Ed Kennell 46,462 #12 Posted January 25 15 minutes ago, Joker72 said: It's a miracle. I disengaged the mechanism in the pic above and re-engaged it and Shazaam! Time to get some grease on the levers and spring. 3 Share this post Link to post Share on other sites
Joker72 96 #13 Posted January 25 Definitely will. The snow got heavy during my delay. Love that C-160. 1 3 Share this post Link to post Share on other sites
