Ed Kennell 47,946 #26 Posted January 21 43 minutes ago, sqrlgtr said: Just wondering how the rubber chains do going out the side of a hill? I remember thinking someone told me they didn't do so well going out the side of a hill and that is the reason for me sticking with the vee bar steel chains. IDK if there is anything to that because Ive never tried the rubber type . I think it was @lynnmor that mentioned that. I don't have to plow on a side hill, but i'm sure the rubber straps would not offer much side traction. 1 1 Share this post Link to post Share on other sites
lynnmor 9,081 #27 Posted January 21 45 minutes ago, sqrlgtr said: Just wondering how the rubber chains do going out the side of a hill? I remember thinking someone told me they didn't do so well going out the side of a hill and that is the reason for me sticking with the vee bar steel chains. IDK if there is anything to that because Ive never tried the rubber type . I mentioned that on here. Side to side you are riding on rubber toboggans, I have a short and steep section that I did a 180 on the first time. I learned to do that first by plowing downhill and returning up the other side. 1 1 Share this post Link to post Share on other sites
Racinbob 13,290 #28 Posted January 21 1 hour ago, sqrlgtr said: That's where I was looking. I mis understood and thought you had ordered from terra grip. I appreciate the spec chart you posted above that helps tremendously. Nah! You didn't misunderstand. I thought I got them at TerraGrip too. I had to go back and check. 1 Share this post Link to post Share on other sites
Alrashid2 476 #29 Posted January 21 You guys are awesome. Really great discussions here!! I think I've ultimately decided that I'll wait until I blow one of these old dry rotted tires... at that point I can decide what tire I want to get, and most likely choose one of the ones discussed here and from there, see how it does compared to my current turf savers - maybe I won't need chains at all? And if I still do, then I'll buy the rubber chains that fit the new tires exactly, since I know regardless I'll be buying new sized tires since my size isnt readily available anymore. Appreciate you all! Great discussion. I'm sure I'll come back to this post in the new year or so and make a decision 1 Share this post Link to post Share on other sites
sqrlgtr 4,225 #30 Posted January 21 3 hours ago, lynnmor said: I mentioned that on here. Side to side you are riding on rubber toboggans, I have a short and steep section that I did a 180 on the first time. I learned to do that first by plowing downhill and returning up the other side. I thought I had seen that on here before. I have to go out the side of hills a lot around. I still might try to make a set up I know it would be easier on the pavement and concrete. Share this post Link to post Share on other sites
JoeM 10,318 #31 Posted January 21 Clean Machines and those weight boxes are the ticket for traction too! 4 Share this post Link to post Share on other sites
pfrederi 21,342 #32 Posted January 21 25 minutes ago, JoeM said: Clean Machines and those weight boxes are the ticket for traction too! Nice looking machines...But I have never seen any correlation between snowplowing.Blowing ability and tractor cleanliness 2 Share this post Link to post Share on other sites
Ed Kennell 47,946 #33 Posted January 21 2 minutes ago, pfrederi said: correlation between snowplowing.Blowing ability and tractor cleanliness A clean polished blade and blower chute is a good thing. 3 1 Share this post Link to post Share on other sites
Brockport Bill 2,553 #34 Posted January 21 like others, we here in the Hudson Valley of NY don't seem to have the same frequency or depth of snow storms as years ago -- i use the C175h with 48 plow for most clearing and occassionally when needed I have walk behind blower to do any deep build up of pushed back snow along sides of driveway from tractor plow. I have plowed over the years with just turf tires, sometimes with and/or without weights or chains ---- i did install the chains this winter --- but no weights. i have often thought of investing $$ in the "rubber" chains. This spring however I plan to have the asphalt driveway sealed so it will be very vulnerable to the steel chain scratches next winter - - certainly don't want chain marks after paying for nice seal job. I have slight slope on 75 ft driveway - but we all know once the plow blade has cleaned the snow almost bare on asphalt driveway traction is not a big need -- it is only on rare occassion i ever have the rear ties "spin" with no chains and just rubber treads - -but when i have steel chains i do get some spinning thus the scratch marks -- so we will see how this winter goes -- but maybe for next season the conversion will be wise after the asphalt gets sealed -- or i will just not put the chains on. 1 Share this post Link to post Share on other sites
pfrederi 21,342 #35 Posted January 21 If you have a paved driveway and you keep it plowed so it clears off between storms tires alone are probably enough, But if the UPS guy, the mail man, propane guy who ever drives in and packs it down so you can't scrape it clear completely before the next snow fall ....you may have an issue. 1 Share this post Link to post Share on other sites
lynnmor 9,081 #36 Posted January 21 1 hour ago, Brockport Bill said: i have often thought of investing $$ in the "rubber" chains. This spring however I plan to have the asphalt driveway sealed so it will be very vulnerable to the steel chain scratches next winter - - certainly don't want chain marks after paying for nice seal job. Before you pay for a seal job go to a shopping center and look at the white lines, there you see a crack alongside nearly every one. Yes, a seal job can look nice for awhile till it slowly destroys the asphalt. Share this post Link to post Share on other sites
Brockport Bill 2,553 #37 Posted January 22 2 hours ago, lynnmor said: Before you pay for a seal job go to a shopping center and look at the white lines, there you see a crack alongside nearly every one. Yes, a seal job can look nice for awhile till it slowly destroys the asphalt. interesting point and that may be the typical situation for most people's driveway ---------- but i do not have that problem -- my asphalt driveway is over 35 yrs old -- no deterioration or degrading, no holes, no chipping, no repair necessary etc -- Why? Because my asphalt guy was high end commercial paving company -- not a usual residential driveway guy or typical "Sealer guy" - Actually, my asphalt installation guy recommended my sealer guy -- i don't recall the exact product material name of the sealer product but it's not the standard driveway sealer product -- it's some type petroleum oil based product to avoid the "destroying" issue you noted - i have had that same company apply his product multiple times over the years - terrific results - both longevity and durability and appearance. 2 Share this post Link to post Share on other sites
kpinnc 19,107 #38 Posted January 22 (edited) 4 hours ago, pfrederi said: Nice looking machines...But I have never seen any correlation between snowplowing.Blowing ability and tractor cleanliness Can't speak for moving snow, but mine work harder when they look good... Edited January 22 by kpinnc 1 2 Share this post Link to post Share on other sites
Racinbob 13,290 #39 Posted January 22 16 hours ago, pfrederi said: Nice looking machines...But I have never seen any correlation between snowplowing.Blowing ability and tractor cleanliness Come on Paul. Ya know how you can spend a day washing, waxing and detailing your vehicle and the first time you take it for a drive it seems to run better? .............Same thing. 3 Share this post Link to post Share on other sites
steelman 255 #40 Posted January 22 My first winter using rubber chains. I bought two sets at an online auction for $5. I spent at least an hour installing them recently. I’m not impressed with their grip/ traction but they are quiet and don’t leave rust marks on my garage floor. 1 Share this post Link to post Share on other sites
peter lena 10,125 #41 Posted January 24 @sqrlgtr like tractor supply , welded rings for added spring / chain tension points , the rings are right there in the chain / related area , 2" size is good , also use curved hook extension springs , thin flat screwdriver for easy hook up , simple easy improvement . pete 1 Share this post Link to post Share on other sites
Alrashid2 476 #42 Posted February 19 I think I may finally break down and buy some chains. At $160 including tax and shipping, do you think that is worth it? I tried searching Facebook Marketplace and the forum classified but didnt see any rubber chains out there, in any size... Worth waiting for a deal or is $160 good? https://www.rubbertirechains.com/product/23x8-00-12-tire-chains/ Share this post Link to post Share on other sites
sqrlgtr 4,225 #43 Posted February 19 13 minutes ago, Alrashid2 said: I think I may finally break down and buy some chains. At $160 including tax and shipping, do you think that is worth it? I tried searching Facebook Marketplace and the forum classified but didnt see any rubber chains out there, in any size... Worth waiting for a deal or is $160 good? https://www.rubbertirechains.com/product/23x8-00-12-tire-chains/ The jungle sight had the terra grip rubbers for 110 and free shipping the other day might check them out first Share this post Link to post Share on other sites
Alrashid2 476 #44 Posted February 19 7 minutes ago, sqrlgtr said: The jungle sight had the terra grip rubbers for 110 and free shipping the other day might check them out first "The Jungle Site" lol! Always cracks me up I did some searching and I can't find a TerraGrip in my tire size. Closest they had was 23x10.5-12 and I didn't want to go that loose 1 Share this post Link to post Share on other sites
Alrashid2 476 #45 Posted February 19 Said screw it, and bought the chains! I was able to order SoftClaw through Amazon for a hair cheaper. And then, worst case, if I find that the rubber chains aren't making enough of a difference, I can at least uninstall them, clean them up, and return them. Not coming til next week and I'm busy for the next 2 weeks, so might be a later experiment. Will report back as always! 1 Share this post Link to post Share on other sites
Alrashid2 476 #46 Posted February 23 Can't remember if I asked this... Do you guys take your rubber tire chains off come summer? Or can you leave them on all year long? Share this post Link to post Share on other sites
Ed Kennell 47,946 #47 Posted February 23 I take mine off the 312H when I change the plow for the 42" deck each spring. I leave the chains on the 520H as it is a dedicated winter snow plow tractor. 1 Share this post Link to post Share on other sites
Alrashid2 476 #48 Posted February 23 2 minutes ago, Ed Kennell said: I take mine off the 312H when I change the plow for the 42" deck each spring. I leave the chains on the 520H as it is a dedicated winter snow plow tractor. Good to know! I use the tractor a lot less in the summer, but still do use it. Usually for moving logs or some additional firewood here and there. Usually either in the mud, or on hard as a rock, summer baked clay soil. Was hoping I could leave them on for that too but didn't want to ruin them or my tires Share this post Link to post Share on other sites
R Scheer 525 #49 Posted February 24 I leave my rubber chains on year round, but the tractor is lucky if it gets 5 hours use during the summer. 1 Share this post Link to post Share on other sites
Alrashid2 476 #50 Posted March 2 Hey guys, decided to make a fresh post as I have new questions. Long story short, took me almost an hour and half to install the rubber chains and even though they are as tight as I can get them, they're still too loose... ugh. I may be returning Share this post Link to post Share on other sites
