peter lena 10,087 #1 Posted January 19 https://www.google.com/search?q=atv+plow%2C+spring++skid+shoes&sca_esv=24a056545c946754&rlz=1C1CHBF_enUS866US866&sxsrf=ANbL-n5L1dWS3ZbeJQJofQl9qY-AUogJgQ%3A1768829957635&ei=BTRuabDMJsuIptQPwqvwyQ0&ved=0ahUKEwjw4quK3ZeSAxVLhIkEHcIVPNkQ4dUDCBM&uact=5&oq=atv+plow%2C+spring++skid+shoes&gs_lp=Egxnd3Mtd2l6LXNlcnAiHGF0diBwbG93LCBzcHJpbmcgIHNraWQgc2hvZXMyCBAAGIAEGKIEMggQABiABBiiBDIIEAAYgAQYogRIxyZQlAtYkiJwAXgBkAEAmAFsoAHRBqoBAzYuM7gBA8gBAPgBAZgCCqAC_AfCAgoQABiwAxjWBBhHwgIKECMYgAQ think an experiment with a compression spring , will dial in a plow blade slide . related size / size set ups , pete 1 Share this post Link to post Share on other sites
WHX?? 58,302 #2 Posted January 19 9 minutes ago, peter lena said: hink an experiment with a compression spring Not the worst idea Pete. When a blower gets dropped on the skids and you don't throttle the lift lever, which happens in the heat of the battle, she can come down with quite a bang. 1 Share this post Link to post Share on other sites
peter lena 10,087 #3 Posted January 19 @WHX?? have to start / try something , use every / any gain / loss as your , direction , do that regularly , will be plowing this morning with my mower deck enhanced slick blade finish . that slide off is very different , pete Share this post Link to post Share on other sites
JoeM 10,317 #4 Posted January 19 One thing I have done in the past, is to adjust my tip on blade to match how much shoe is contacting the ground. I plow both gravel and asphalt drive ways. The blade has a rubber edge. I tip it back for the gravel allowing the shoes to contact the ground and forward for the asphalt. It worked good. 2 Share this post Link to post Share on other sites
sqrlgtr 4,091 #5 Posted January 19 2 hours ago, JoeM said: One thing I have done in the past, is to adjust my tip on blade to match how much shoe is contacting the ground. I plow both gravel and asphalt drive ways. The blade has a rubber edge. I tip it back for the gravel allowing the shoes to contact the ground and forward for the asphalt. It worked good. @squonk posted in another thread about using piece of pvc split down middle and slipped over blade and cutting edge that I may try if I ever get a piece of pipe. My only worries is the buildup of snow on top of pipe but will be using the 1257 with the HY2 unit so not to worried about it. 1 Share this post Link to post Share on other sites
Tonytoro416 1,392 #6 Posted January 19 4 hours ago, sqrlgtr said: @squonk posted in another thread about using piece of pvc split down middle and slipped over blade and cutting edge that I may try if I ever get a piece of pipe. My only worries is the buildup of snow on top of pipe but will be using the 1257 with the HY2 unit so not to worried about it. Use schedule 80. I tried regular schedule 40 and it got cold enough it just shattered. If I were to do it like that again I’d use steel pipe. Maybe something thinner walled 1 Share this post Link to post Share on other sites
