8ntruck
Opinions, please
8ntruck
Mrs. 8n and I are considering building a garage on the lake house property.  We are thinking of a bay and a half wide and 32 or 36 feet long.
The question is:
Stick built or pole building?
Kit or from scratch?
Pros?  Cons? Comments?
ri702bill
So this is a stand-alone structure I take it?? Not one with a walk thru access?
First thing to consider since it is in Michigan is snow load and proper pitch of the roof. Along with runoff and drainage of the accumulated snow as it melts.
If time is the most important factor, a kit may be the better choice - but may have design limitations for alterations / custom features.
Stick built allows you go at your own pace but will take longer to finish.
A "newer" alternative - is it possible to get a 10 x 40 shipping container in place there? There are numerous excellent videos of folks that have adapted one to become a garage - when done it is almost unrecognizable from its original form.
Achto
For me this would depend on my plans for usage. If you plan to finish the inside then I would go with a stick built, just easier to do an inside finish. If there is no future plans to finish the inside then a pole building might be a better option. You mentioned that this would be on lake property. Is there a lake association or township that would have a say in what kind of building that you can out up?
If there are a lot of trees around, then I would do a steel roof no matter what the building choice is. Shade from trees as well the leaves or pine needles that tend to build up on a shingled roof keep it from drying out. This greatly shortens the life span of the shingles.
One other thought. Not sure how Michigan tax laws are but in Wisconsin a pole building with a gravel floor is not considered a permanent structure, thus the property taxes are much lower.
  • Like 4
JoeM
I am pretty much done with the building my own thing, to arthritic and short on time.
My last build was a prefab.
It was so nice just getting the pad level, wrote a check and viola....I have a building, here are the keys.
After looking around found this place in Ohio. Super high quality.
They do large custom structures.
I got the tongue and groove treated flooring, and it solid.
https://alpinestructures.net/index.html
WHX??
:text-yeahthat:
If just a cold storage warehouse then pole frame.
Stick you need concrete. Gravel is fine for a warehouse.
Nice thing about gravel is you can drop the mule's oil right on it, rake it around and walla ... blacktop. :)
Edited by WHX??
  • Haha 2
Pullstart
Hybrid?
lynnmor
One should get an estimate of taxes before deciding on type of construction.  Figure how many years you will be paying those taxes and how old you will get before the building will no longer be of good use for you.  My pole building had no concrete floor and no electricity till after I got the occupancy permit, then those things magically appeared.
ri702bill
Akin to those midnight sewer connections??
WHX??
Interesting Joe... i always thought they were just fancy fake garages that had to fit on a trailer. Might havta look into it more.
Know any thing about that Pullstart? :lol:
