ineedanother 2,487 #1 Posted January 19 It's time to replace fuel lines on a couple machines and I didn't see anything recent with a search...looking for local (NAPA?) or other source for quality fuel line. I use E-0 and this would be for 300 and c-series. Thanks Share this post Link to post Share on other sites
Retired Wrencher 6,723 #2 Posted January 19 I have been using tractor supply made in USA hose for a few years now very happy with it well-made. Have a good day. 2 Share this post Link to post Share on other sites
sqrlgtr 3,015 #3 Posted January 19 I have started using the j9 rated from any parts store but it is more $$$ and the j7 would probably be just fine here is some info I got from interweb... I dont like the looks of the clear fuel hose but know nothing about them Based on SAE (Society of Automotive Engineers) standards for automotive fuel hoses, J30R6, J30R7, and J30R9 represent different grades of fuel hose, with significant differences in pressure rating, temperature resistance, and permeability. SAE J30R6 (J6) Application: Designed for low-pressure, carbureted fuel systems, emission systems, or fuel return lines. Suitability: Not recommended for modern fuel injection systems due to lower pressure limits. SAE J30R7 (J7) Application: A versatile, standard fuel hose designed for fuel systems (carbureted or low-pressure fuel injection) and emissions systems. Suitability: Suitable for under-the-hood applications. It has better heat and oil resistance than R6, but lower pressure ratings than R9. SAE J30R9 (J9) Application: Specifically designed for high-pressure fuel injection systems. Performance: Highly durable, with superior resistance to heat, pressure, and, most importantly, low permeation (fuel vapor escaping through the hose wall). Compatibility: Excellent for modern fuels, including ethanol blends. Key Differences Summary Pressure: J9 (highest) > J7 > J6 (lowest). Permeability: J9 is designed to prevent fuel vapors from escaping, making it more compliant with modern environmental standards compared to R7 or R6. Best Use: Use J9 for fuel-injected engines, J7 for carbureted/fuel return, and J6 for basic fuel transfer. 3 Share this post Link to post Share on other sites
peter lena 9,898 #4 Posted January 19 @ineedanother great time to lay in a frame length 5/16 steel brake line , ? tucks right up into the inside frame corner bend , tie wrap or screw or c clamp , finish ends with a clear fuel rated hose , use a swage lock to hose barb connection . like a fuel filter at tank flow start , another just before carb , also have fuel check valves on my units , yo can see the holding fuel to carb , did this fresh / clean set up years ago , to eliminate what was there , also started using , sta bil in all my fuels then , just an ounce or two , to any tank top off . zero hose break down , no debris in any carb bowl , that additive will help maintain a clean / fresh hose . isn't that what you want ? been using this for years , with no issues , also a good time to tune up your choke / throttle cables , using hydraulic super lube , temp specs verify consistent slide, added , light pull springs to my cables , to assist , close / stop ? that way your movement is always spring assisted , another experiment , always works , evolution of change , pete 1 Share this post Link to post Share on other sites
Lagersolut 802 #5 Posted January 20 13 hours ago, Retired Wrencher said: I have been using tractor supply made in USA hose for a few years now very happy with it well-made. Have a good day. Do they have a roll you can buy/per foot ? I usually look for the USA stuff on the bay because I hate shopping . Share this post Link to post Share on other sites
ineedanother 2,487 #6 Posted January 20 59 minutes ago, Lagersolut said: Do they have a roll you can buy/per foot ? I usually look for the USA stuff on the bay because I hate shopping . That's what I'll do, likely J7 like @sqrlgtr suggested. Not sure I can run steel line like @peter lena suggests but I like the thought of it if I can fish some through without a bunch of bends. Share this post Link to post Share on other sites
Retired Wrencher 6,723 #7 Posted January 20 9 hours ago, Lagersolut said: Do they have a roll you can buy/per foot ? I usually look for the USA stuff on the bay because I hate shopping . I believe it is a 5 foot roll. Share this post Link to post Share on other sites
peter lena 9,898 #8 Posted January 20 @ineedanother , you are only talking about 4 / 5 foot measure your frame length , typically have a barrel , with odd shapes / sizes , also a good time to cut off ferreled ends , go to clear fuel rated hose , from their to filter / check valve . I was fed up with the , repetitive failures , also did tank valve , and tank flush out , this set up eliminated my carb debris issue , never returned , use regular gas , and 1 , 2 ounces of stabil storage additive , every tank top off , years in , no debris , no failures , combine this with choke and throttle cables that easily move , spring pull assist to close / stop , did this on my c-85 , experimental horse , work out the bugs , then added it to my other 2 horses . have not had any fuel issues at all , in years , regularly , snoop around for anything , then kill it . clean carb bowl / filters . stand by generator also , pete 2 Share this post Link to post Share on other sites
