AHS
93 314H FEL
AHS
its not mine. (But could be!). I know of the guy with the FEL and he want to sell it. It needs a seat. Ok, what’s it worth? A 93 314H, I didn’t see it run, it was out of gas. But, let’s assume it runs. It’s a Kiki way loader and it’s got non leaking lines. I think the lines are original. The muffler is whole! I mean, lets assume its got oil to be changed, fuel lines and an air filter to be changed. Shoot me all the questions and I’ll try to answer them! I mean, I’ll make sure the loader works!
  • Excellent 4
ebinmaine
That loader ALONE is worth $2500 minimum.
JCM
Does it come with weight box with both axle brackets ?  How about the 2 loader stands if you want to remove it ? That way you could drive into it to disconnect or reconnect .Makes it much easier.
ebinmaine
I believe I have those items here.
c-series don
From my experience, once the loader is on that’s it. It becomes a dedicated loader tractor. You’re not switching attachments like you would mower to tiller, or tiller to plow. It’s a process to take that off or put it on. That being said, go get it and add another one to your collection!!
JCM
Don.are you talking about the Kwik - Way off and on. The only tools you need is small open end / box wrenches for the pump and axle brackets. Not much work I found when I had mine.  @c-series don
AHS
I don’t believe it does come with the 2 loader stands. I believe it has the weight box.
JCM
They are limited to what they can do but come in handy for many tasks. Not a big deal to install and remove.
  • Excellent 6
lynnmor
The first few years I had just one tractor to do everything, I could install or remove the loader under a half hour.  The front axle and spindles should be upgraded to handle the load, the 520H tractors have what is needed.  Also. gear reduction steering will help a lot, the weight really makes it difficult to steer.
c-series don
Actually @JCM I’m not talking about the Kwik-Way, my bad ! Mine is a Wheel Horse loader which I believe is actually made by Ark. I think I only took it off once before realizing it was easier to leave it on and just get more tractors for different attachments!!
  • Excellent 2
  • Haha 1
ebinmaine
Agreed.  Follow the @SylvanLakeWH rule!!
AHS
Actually, i have a few of those spindles!
AHS
So, what do you guys think? $2000-2500?? Im gonna try to get it for less than that.
  • Like 4
Bill D
Go for it!
