AHS 1,642 #1 Posted January 18 its not mine. (But could be!). I know of the guy with the FEL and he want to sell it. It needs a seat. Ok, what’s it worth? A 93 314H, I didn’t see it run, it was out of gas. But, let’s assume it runs. It’s a Kiki way loader and it’s got non leaking lines. I think the lines are original. The muffler is whole! I mean, lets assume its got oil to be changed, fuel lines and an air filter to be changed. Shoot me all the questions and I’ll try to answer them! I mean, I’ll make sure the loader works! 1 4 Share this post Link to post Share on other sites
ebinmaine 77,972 #2 Posted January 18 That loader ALONE is worth $2500 minimum. 2 Share this post Link to post Share on other sites
JCM 11,002 #3 Posted January 18 Does it come with weight box with both axle brackets ? How about the 2 loader stands if you want to remove it ? That way you could drive into it to disconnect or reconnect .Makes it much easier. 3 Share this post Link to post Share on other sites
ebinmaine 77,972 #4 Posted January 18 9 minutes ago, JCM said: Does it come with weight box with both axle brackets ? How about the 2 loader stands if you want to remove it ? That way you could drive into it to disconnect or reconnect .Makes it much easier. I believe I have those items here. 3 Share this post Link to post Share on other sites
c-series don 11,757 #5 Posted January 18 From my experience, once the loader is on that’s it. It becomes a dedicated loader tractor. You’re not switching attachments like you would mower to tiller, or tiller to plow. It’s a process to take that off or put it on. That being said, go get it and add another one to your collection!! 2 1 Share this post Link to post Share on other sites
JCM 11,002 #6 Posted January 18 Don.are you talking about the Kwik - Way off and on. The only tools you need is small open end / box wrenches for the pump and axle brackets. Not much work I found when I had mine. @c-series don 1 Share this post Link to post Share on other sites
AHS 1,642 #7 Posted January 18 58 minutes ago, JCM said: Does it come with weight box with both axle brackets ? How about the 2 loader stands if you want to remove it ? That way you could drive into it to disconnect or reconnect .Makes it much easier. I don’t believe it does come with the 2 loader stands. I believe it has the weight box. 3 Share this post Link to post Share on other sites
JCM 11,002 #8 Posted January 18 58 minutes ago, AHS said: I don’t believe it does come with the 2 loader stands. I believe it has the weight box. They are limited to what they can do but come in handy for many tasks. Not a big deal to install and remove. 6 Share this post Link to post Share on other sites
lynnmor 8,700 #9 Posted January 18 The first few years I had just one tractor to do everything, I could install or remove the loader under a half hour. The front axle and spindles should be upgraded to handle the load, the 520H tractors have what is needed. Also. gear reduction steering will help a lot, the weight really makes it difficult to steer. 3 Share this post Link to post Share on other sites
c-series don 11,757 #10 Posted January 18 Actually @JCM I’m not talking about the Kwik-Way, my bad ! Mine is a Wheel Horse loader which I believe is actually made by Ark. I think I only took it off once before realizing it was easier to leave it on and just get more tractors for different attachments!! 2 2 1 Share this post Link to post Share on other sites
ebinmaine 77,972 #11 Posted January 18 2 minutes ago, c-series don said: Actually @JCM I’m not talking about the Kwik-Way, my bad ! Mine is a Wheel Horse loader which I believe is actually made by Ark. I think I only took it off once before realizing it was easier to leave it on and just get more tractors for different attachments!! Agreed. Follow the @SylvanLakeWH rule!! 2 1 Share this post Link to post Share on other sites
AHS 1,642 #12 Posted January 19 12 hours ago, lynnmor said: The first few years I had just one tractor to do everything, I could install or remove the loader under a half hour. The front axle and spindles should be upgraded to handle the load, the 520H tractors have what is needed. Also. gear reduction steering will help a lot, the weight really makes it difficult to steer. Actually, i have a few of those spindles! Share this post Link to post Share on other sites
AHS 1,642 #13 Posted January 19 So, what do you guys think? $2000-2500?? Im gonna try to get it for less than that. 5 Share this post Link to post Share on other sites
Bill D 2,686 #14 Posted January 19 Just now, AHS said: So, what do you guys think? $2000-2500?? Im gonna try to get it for less than that. Go for it! 1 Share this post Link to post Share on other sites
Treepep 1,099 #15 Posted January 20 Buying...anything. In my opinion folks are selling biz for a variety of reasons. 1. cant fix it. 2. have no use for it 3. need money for life or to fund something that works 4. significant will murder me etc etc. due diligence of course. I would not buy something that is obviously neglected and stored outside. Me specifically. Not my skill level. Also as previously stated... Toro Im out! Wrenched on enough of them in college to know. Me thing not a ya'all thing. That said if you want a project and you significant wont smother you go for it. heart wants what the heart wants yeah? 1 1 1 Share this post Link to post Share on other sites
AHS 1,642 #16 Posted January 20 @Treepep if it has a red metal hood, I'm on it!! Toro or WH!! I have ‘73-‘99 Toro/WH. Everyone is different!! Share this post Link to post Share on other sites
Treepep 1,099 #17 Posted January 20 1 minute ago, AHS said: @Treepep if it has a red metal hood, I'm on it!! Toro or WH!! I have ‘73-‘99 Toro/WH. Everyone is different!! I hear you there brother. Not really a brand issue per se. Newer models I am not qualified to wrench on. You do you! 1 Share this post Link to post Share on other sites
AHS 1,642 #18 Posted January 21 @JCM you have a FEL on a 417-8. Do you have. A separate pump mounted on the PTO side? Share this post Link to post Share on other sites
JCM 11,002 #19 Posted January 21 (edited) I sold it years ago. Yes it did have the pump on the PTO side. I bought it with 30 hours on it. The original owner had it on a late model, 96 or 7 520 -H and he passed and I received a call from the dealer that he was buying the complete package back. I would have bought the 520 but already had 2 of them. It mounts on a factory bracket in front of the footrest on the subframe, @AHS Edited January 21 by JCM 2 1 Share this post Link to post Share on other sites
lynnmor 8,700 #20 Posted January 21 3 hours ago, AHS said: @JCM you have a FEL on a 417-8. Do you have. A separate pump mounted on the PTO side? Here is the information. 1 Share this post Link to post Share on other sites
