Handy Don 17,168 #51 Posted March 6 13 hours ago, Easton Rich said: Next dilemma, I sold the Eaton out of this tractor to a friend with a C-160 that has a Sunstrand. How easy would this swap be? He wants the Onan off of it too. How hard would it be to swap that in? Motion control linkages for Sunstrands and Eatons are very different--you’ll need a donor tractor to get all the bits. Size differences may also become an issue as might clearances (the Eaton has an external charge pump and different routing for lift plumbing. The engine swap will likely be easier, though you’ll need the unique Onan engine mounting plate to go with the engine and do a thorough crosscheck on the wiring--sensors, safety switches & relays, etc. 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #52 Posted March 6 Ive got the donor tractor and everything will would need. How would fitment look? Any cutting or modification needed? Share this post Link to post Share on other sites
Handy Don 17,168 #53 Posted March 6 I’ve not done a detailed side-by-side comparison. Perhaps someone else here has. My initial instinct would be to keep the Eaton together with its original, linkage-embedded chassis/tunnel/console (and hoodstand?) and move other parts around. 2 Share this post Link to post Share on other sites
kpinnc 18,851 #54 Posted March 6 1 minute ago, Easton Rich said: How would fitment look? I think the hydraulic lines and remote oil filter would be a challenge but is solvable. The input sheave for the Eaton seems to sit a little higher than the Sundstrand, but that may not be an issue. The main issue in my mind is being sure the left pedal neutral/ brake setup can be made to work on the older subframe. It might not be an issue at all, but it's something to look at. None of my Sundstrands have a brake so I have no reference. 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #55 Posted March 6 Another option is 8spd. How would that go? Regardless he wants the Onan. Share this post Link to post Share on other sites
Handy Don 17,168 #56 Posted March 6 5 hours ago, Easton Rich said: Another option is 8spd. How would that go? Regardless he wants the Onan. 8-speeds are a LOT less complicated and much smaller. Only have to figure out the brake linkage and then make sure there is clearance/alignment for the shift levers and dipstick. 1 Share this post Link to post Share on other sites
953 nut 68,131 #57 Posted March 7 7 hours ago, Handy Don said: Motion control linkages for Sunstrands and Eatons are very different--you’ll need a donor tractor to get all the bits. Size differences may also become an issue as might clearances (the Eaton has an external charge pump and different routing for lift plumbing. Not as bad a job as you might think. @19richie66 did a thread about widening the Eaton to replace the Sundstrand on a GT-14. If you disregard the axle change out to accomplish the widening it is a rather easy job. Very few changes to the tunnel need to be made for the this swap and Richie has documented it well. 1 1 Share this post Link to post Share on other sites
c-series don 12,304 #58 Posted March 7 I saw your C-175 pictures and I thought it looked similar to mine! I restored this one 2-3 years ago. IMG_9389.mov 5 Share this post Link to post Share on other sites
Easton Rich 1,260 #59 Posted March 7 One of these days I'll get to that one, but I need to for sure downsize! Share this post Link to post Share on other sites
19richie66 17,931 #60 Posted March 8 Hopefully soon I will be putting an Eaton1100 in a Bronco14. The linkage is different but not bad. I have it ready to go. Just need to find the time. 3 Share this post Link to post Share on other sites
kpinnc 18,851 #61 Posted March 9 9 hours ago, 19richie66 said: Hopefully soon I will be putting an Eaton1100 in a Bronco14. The linkage is different but not bad. I have it ready to go. Just need to find the time. That sounds pretty cool! I look forward to what you come up with. Share this post Link to post Share on other sites
19richie66 17,931 #62 Posted March 9 17 hours ago, kpinnc said: That sounds pretty cool! I look forward to what you come up with. I have to get it off the stand hopefully this week. I want to get the transmission swapped do I can roll it around. Wanting to clean out my shed. 3 Share this post Link to post Share on other sites
sqrlgtr 3,583 #63 Posted March 9 Been following along, this is what I had in mind when I traded for a 520h a little bit ago. Thought I wanted to swap trans and onan to a 73 14hp Hydro no name but the more I fool with the 520 might just try and restore it to at least a great worker status . 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #64 Posted March 10 Yeah, mine is no good except for the steering, engine, and tranny. I'm regretting selling my good 520, but can't keep everything. 2 Share this post Link to post Share on other sites
Handy Don 17,168 #65 Posted March 10 14 hours ago, sqrlgtr said: Been following along, this is what I had in mind when I traded for a 520h a little bit ago. Thought I wanted to swap trans and onan to a 73 14hp Hydro no name but the more I fool with the 520 might just try and restore it to at least a great worker status . Not the end of the world to swap the 14hp Kohler into the 520 chassis if the Onan is toasted. Share this post Link to post Share on other sites
sqrlgtr 3,583 #66 Posted March 10 1 hour ago, Handy Don said: Not the end of the world to swap the 14hp Kohler into the 520 chassis if the Onan is toasted. Actually, was thinking about swapping the swept front, Onan and Eaton to the 74 chassis. The 520 is a more solid mochine than I thought when I got it home though. Share this post Link to post Share on other sites
