Easton Rich
C-Series Hybrid Idea
Easton Rich
I can see that. I was worried about that, I figured the linkage would be a nightmare
Easton Rich
Neither run, but I've worked on both and they are strong runners (When they ran last). So give me your opinions!
sqrlgtr
Im a C160 With the k341 Kohler fan so my vote goes to it.
kpinnc
Definitely the C160 if you're planning on a hydraulic setup at the rear.
My Bronco is basically the same, and I just added a D series spool valve to control the rear separately.
Plus the Sundstrand has 4 bolts on to to work with attaching fabrications to. Not sure if that black hood has an Eaton or not, but those only have two bolts to work with.
I just fabbed a 1/4 inch plate steel toolbox and added pivots for the upper lift arms and a seperate cylinder. No way that same design would work with (1) a fuel tank under the fender and (2) no room with an Eaton.
Handy Don
Plus the Sunstrands have internal pressure relief for the hydraulic pump so chaining tandem center control valves is straightforward
kpinnc
Excellent point! :thumbs:
Easton Rich
Is there any difference in strength between the two? How do I strength test one?
kpinnc
Both make around 700psi on the hydraulic pump. So far as torque at the wheels, I don't have numbers. But on a decent model of either one, you'll break something internally before stopping one. I have a couple Eatons and Sundstrands, and either will spin wheels under load.
Handy Don
I would go to the specs.
Both use equivalent WH final drive gears. Both run the hydraulics at 700psi and similar volumes (a bit over 1 gal per minute at full pressure).
The Eaton 1100 can transfer on the order of 17hp for motion
I don’t know about the Sunstrands and it may depend on the model
kpinnc
The only numbers I remember was the Eaton 1100 has 3 times the output torque over the 700 model.
Can't speak for the difference between Sundstrands.
Easton Rich
Ok, I'll look for the model, but I was wondering since I had the choice between a 1100 and that Sunstrand.
kpinnc
I've had a couple of each, and as Don @Lee1977 and I were talking about them this past Sunday- they vary so much one to another, regardless of type. You would think the precision built into them would make them more like any other of the same type, but that is not the case.
My Bronco has the absolute fastest hydro I've ever had. My 1990 520H has the quickest response of all of mine. It will spin the tires easily. I'm starting to think the linkage adjustment has alot to do with it, but I'll know about that soon enough.
Easton Rich
Im not sure the size of the case, but since you guys are saying they are both really great, I think I'll go with the smaller of the two (If there is a smaller one)
Easton Rich
Oh and I'll make sure to get pictures of the parts tractor on Monday.
Easton Rich
Well Monday went by fast. I bought the parts tractor sight unseen.... I gotta stop doing that. It's the super rare woody anniversary edition... 1 of 1. You'll just have to wait to see what I mean
Easton Rich
Here she is in all her glory! I gotta stop buying them sight unseen. Or just stop all together!
  • Confused 1
Easton Rich
I forgot to mention that's the parts machine. It fell off a truck at 55mph. Frame is welded, axle is welded (Which I have another of), and the trans needs new seals, but all in all it is a great parts machine. I'll probably be getting rid of the Eaton out of this unless the C-160's sunstrand is bad.
kpinnc
There's alot of Wheel Horses in those pictures. Are they all yours?
Parts machines are very good to have. I have had a couple myself.
Side note- I just modded my 523H with a taller steering column. Your parts 520H looks to have a factory extension on it. I've not seen that before.
JoeM
Maybe more so then you think, looking at the belt guard, the ultra rare cutting board edition?
Foot pads are nicely done tho
Easton Rich
They are all mine for now. @Shuboxlover bought a few in the background. I didn't even notice it had the extension.
kpinnc
All of my 520s were 1990 models, so that may be normal for reduction steering. I wouldn't know for sure. All of mine had the swept axle but no reduction steering.
Easton Rich
Yeah, I'm pretty sure this is a 92 or 93 model. I just sold my '96 520 to @Shuboxlover and its mostly the same. I'll do some research
Lee1977
Somebody removed the 8 1/2" wide rear wheels, thoes are 7" that are on it.
The later model three hole steering wheel has a longer extinction on the bottom where it attaches to the shaft.
Don't know if that steering wheel ever came on a 520 from the factory.
Edited by Lee1977
Easton Rich
I know. I've got the correct steering wheel.
Easton Rich
Next dilemma, I sold the Eaton out of this tractor to a friend with a C-160 that has a Sunstrand. How easy would this swap be? He wants the Onan off of it too. How hard would it be to swap that in?
