Easton Rich
C-Series Hybrid Idea
Easton Rich
Since I’ve got TONS of extra parts, I have been thinking about what to do with them. I had this idea that I could make a C-Series hybrid tractor. I’d like to have electric clutch, hydraulics, forward swept axle and gear reduction steering, Eaton 1100 or 5091 8spd? Maybe C-195 3pt? I don’t know what else I could do, but my end goal is to have a tractor I can plow, till, harrow, and snowblow with. I’ll get pictures soon of my parts selection.
  • Excellent 3
ri702bill
Electric clutch - why so??
Easton Rich
I’ve never had one on a tractor, and I wanted to experiment. This thread is for feedback because you guys have way more knowledge than I do.
ri702bill
Depending on the implement being driven by the PTO, the instantaneous engagement of an electric clutch may be an issue; better done with the traditional lever type where you can ease into it. All I use are lever style. My :twocents-02cents:...
  • Like 5
Ed Kennell
                                :text-yeahthat: Agree with Bill.  I addition to bringing gold prices if you can find one this was not a good Wheel Horse idea.
I understand the need for idiot safety switches, but IMO, the original PTO engagement lever used on the Raiders was the best.
Looking forward to seeing this build.
kpinnc
Soft start clutch controller works well for this issue. I've used one for 8 years and it works great.
I didn't use hydraulics on this one but it can be done! Not a C-series but has alot of those parts in it.
  • Excellent 7
Easton Rich
Is there a build thread on this one?
Easton Rich
I can see how electric wouldn’t work. The immediate start would cause belt slippage. Now I know!
ri702bill
These allow a more controlled, less violent engagement. As I recall, they are aftermarket, not Factory offered.
ebinmaine
3 hours ago, Easton Rich said:
I’d like to have *******,
forward swept axle and gear reduction steering, *****
 8spd
Things I'm doing to my '74 C160-8 currently.
Also a larger steering wheel, new low back seat, and Briggs vanguard swap.
Previous mods included 24x12.00-12 tires on wide rear wheels.
I'll be looking forward to your progress.
Manual vs hydro transmission is a personal preference.
Seems the majority like a manual for rototilling.
Snow plowing could go either way.
I've gotten used to a hydro with hydro lift for plowing because of my VERY heavy plow.
Trina wouldn't be caught on a hydro unless her manual tractors are buried or broken.
For any other usage we both highly prefer a manual transmission.
Adding a hydro lift to a manual transmission tractor is certainly possible but obviously starting out with a hydro transmission and hydro lift would be beneficial.
kpinnc
Yes.
Frokenstien Build
  • Excellent 2
midpack
I have a soft start module on a Magnum 18 with an electric PTO. It makes a huge difference. I originally ran it with a manual PTO so I knew exactly how much of a difference it made.
  • Excellent 2
kpinnc
These are what I use on my Scag zero turn and it is awesome. They work with any engine, and are simple to wire up.
You wrap the sense wire around a spark plug wire, so it engages based on the RPM of the engine.
Easton Rich
Wow, I’ll definitely look into it. How much does it cost? The website didn’t say
kpinnc
I paid about $50 for mine, but that was several years ago.
ri702bill
Just Googled it - costs over $100 now...
midpack
That makes it tougher to bite the bullet.
They do work well IMO
peter lena
@Easton Rich   rotational drag  is the issue , when you  minimise that , the difference is amazing .  often refer to  , my pto  driven belt to the mule drive , easily moving by hand , to attachment .  another glairing  bearing hang up  is BELT FRAYING  , caused by incremental  spindle stoppage , causing  BELT BOUNCE  ,  as you can see  I am suggesting  , verifying  and insuring  smooth / easy  pulley / bearing  movement . there are a number of  related bearings  in those pulleys . with ceiling fan lubrication , grease , that consistently  , whine  with noise . @midpack    has the cure with the soft start  , module , would check that out  , wheel horse  , lever /  linkages , are at best minimal , small improvements , make a world of difference , good luck with that  , pete
