markseven 93 #1 Posted January 7 I have a question regarding these electric fuel pumps it seems to me the power is always turned on to them. pump gas 100% of the time is there a built-in regulator that shuts them down ? just don't think that the needle and seat would hold too much pressure if that fuel pump is pumping constantly. I'm thinking about putting one on my charger 12. Share this post Link to post Share on other sites
peter lena 10,125 #2 Posted January 7 @markseven have carbole electric pumps on mine , 2-3.5 psi , zero issues , they do self regulate , never had a carb seat area issue , have a filter just before pump , and another filter just after tank start , have many years on these , you also might consider doing a fuel hose replacement , filter debris is telling you of hose break down . note the style / type of pump , NOT the small tank type of pump . very solid , reliable set up , pete 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #3 Posted January 7 46 minutes ago, peter lena said: they do self regulate Facet 60245 or 60304. Mr. Gasket 42s. Carter P4070. All of the above pumps are regulated at 4 PSI or less. 3 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #4 Posted January 8 (edited) I have installed this brand on my 856. These are designed for aviation but work well on small engines. They make different ones a bit pricey but very well-made. I always say it’s good enough for aviation. It’s good enough for a lawn tractor. Edited January 8 by Retired Wrencher 3 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,712 #5 Posted January 8 I have the facet on my C-161 and never an issue with it. Cured my hard starting immediately! 3 Share this post Link to post Share on other sites
sqrlgtr 4,225 #6 Posted January 8 I have the Facet # 40163 (1.5-2.5psi) that I got for a 312-8 (tank under seat) but haven't installed it yet . It's my understanding that these pumps run continuously but 2.5psi max is all they will build. 1 Share this post Link to post Share on other sites
adsm08 5,247 #7 Posted January 8 12 hours ago, Retired Wrencher said: I always say it’s good enough for aviation. It’s good enough for a lawn tractor That's a good point. Lawn tractors don't tend to fall out of the sky when they quit running. I might have more of them if they did. 3 Share this post Link to post Share on other sites
lynnmor 9,081 #8 Posted January 9 13 hours ago, Retired Wrencher said: I have installed this brand on my 856. These are designed for aviation but work well on small engines. They make different ones a bit pricey but very well-made. I always say it’s good enough for aviation. It’s good enough for a lawn tractor. I have posted this before, is there an echo in here? This is a copy and paste from the manufactures website: Not Intended for Aircraft Use WARNING: FACET AND PUROLATOR FUEL PUMPS SHOULD NOT BE USED IN AIRCRAFT AS THEY ARE NOT DESIGNED, TESTED OR MANUFACTURED FOR ANY AIRCRAFT APPLICATIONS. 2 Share this post Link to post Share on other sites
wallfish 20,744 #9 Posted January 9 Good thing we aren't flying our tractors! (Although some guys seem to get close every once in a while). 3 1 Share this post Link to post Share on other sites
Handy Don 17,735 #10 Posted January 9 Just now, wallfish said: Although some guys seem to get close every once in a while The vid of @ebinmaine pushing snow made me think he was gonna launch! 4 Share this post Link to post Share on other sites
ebinmaine 81,281 #11 Posted January 9 2 minutes ago, Handy Don said: The vid of @ebinmaine pushing snow made me think he was gonna launch! I'll try harder next time!!! 1 3 Share this post Link to post Share on other sites
sqrlgtr 4,225 #12 Posted January 9 2 minutes ago, ebinmaine said: I'll try harder next time!!! I thought a driving Barr was cool I would love to see a flying barr. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,921 #13 Posted January 9 1 hour ago, ebinmaine said: I'll try harder next time!!! Gonna need video... 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #14 Posted January 9 10 hours ago, lynnmor said: I have posted this before, is there an echo in here? This is a copy and paste from the manufactures website: Not Intended for Aircraft Use WARNING: FACET AND PUROLATOR FUEL PUMPS SHOULD NOT BE USED IN AIRCRAFT AS THEY ARE NOT DESIGNED, TESTED OR MANUFACTURED FOR ANY AIRCRAFT APPLICATIONS. Ok my bad.But still a great pump. Share this post Link to post Share on other sites
Retired Wrencher 7,043 #15 Posted January 9 10 hours ago, wallfish said: Good thing we aren't flying our tractors! (Although some guys seem to get close every once in a while). Well, John, I guess I didn’t do my research. My bad. Share this post Link to post Share on other sites
lynnmor 9,081 #16 Posted January 9 3 hours ago, Retired Wrencher said: Ok my bad.But still a great pump. Since they are sold by Aircraft Spruce one would think that they are qualified for aircraft use. My thought is that builders of ultralights use the pumps for the small engines they use and there is little regulation on those aircraft. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #17 Posted January 9 4 minutes ago, lynnmor said: Since they are sold by Aircraft Spruce one would think that they are qualified for aircraft use. My thought is that builders of ultralights use the pumps for the small engines they use and there is little regulation on those aircraft. Agree. Also ground equipment--tow tractors, snow clearing, generators, pressure washers... 1 Share this post Link to post Share on other sites
pfrederi 21,342 #18 Posted January 9 I buy the PosiFlo because they seem to last and they are made in Elmira NY USA 2 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #20 Posted January 9 1 hour ago, pfrederi said: I buy the PosiFlo because they seem to last and they are made in Elmira NY USA Same reason for my choice. 2 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #21 Posted January 19 Mark buy a good quality one like this manufacturer. There made in USA. You will not be sorry. 1 Share this post Link to post Share on other sites
