bo dawg 643 #1 Posted January 3 Is there anything on here about repair work on the decks? Like rebuilds, or weld/patch work on the shells? Just curious how others might perform tasks thats needed to keep these old thing still functional. Point at hand..... I need to weld up a hole in the corner of the deck and would like to see how others go about it. Ive done a couple others that were smaller but this one is larger and right in the crown of the corner. Share this post Link to post Share on other sites
ri702bill 13,392 #2 Posted January 3 The damaged area is much larger than it appears on the outside. Once you grind that surface to expose good parent metal to weld to, you will be amazed how much is gone. Folks here have used either metal or fiberglass cloth & resin for that type of repair with acceptable results. Third choice is a replacement shell... 4 Share this post Link to post Share on other sites
peter lena 10,125 #3 Posted January 3 @bo dawg the secret to deck life is oiled lubrication , been doing this for years , original decks , zero rot / rust , my decks were put away cleaned , and sun hot , soaked , propped up to a wall , with a heavy spring to screw in eye , decks also have a total , bearing clean out and re grease , lucas XHD green chassis grease , every related bearing has this , mule drive / pto set up , YOU HAVE TO BREAK THE GRUNGE CYCLE . also no belt squealing , decks spin by hand . pete 1 Share this post Link to post Share on other sites
ineedanother 2,885 #4 Posted January 3 I went the fiberglass route with one last year. I have a wire welder but molding steel patches was going to be messy at best and the repair I was making was a bit less than what you have. I layered 8 oz. cloth on holes as well as thinned areas and it has held up well so far. 3 3 Share this post Link to post Share on other sites
peter lena 10,125 #5 Posted January 3 this is another stage of deck preservation on all my decks , found once done , and sun hot baked into cleaned / dry base , its going no whare , like a 2 step , chain / cable lube , hot bake that , once established use an OPEN GEAR spray , over that , and hot bake , better part of the day , at angle , to get hot , sit there for hours , also have them up against the wall stud , with heavy screw in eye , and spring to 10" long S looped connector , makes it easy to grab deck lift frame and hold in place , pete 2 Share this post Link to post Share on other sites
8ntruck 9,420 #6 Posted January 3 The easiest repair method in that location is fiberglass as @ineedanother describes. But, if you have sandy soil like I do, a fiberglass patch is probably a temporary patch, due to the sand blasting action while the mower runs. Being a retired press & die engineer, I'd get out a ball peen hammer and a log with a shallow depression in the end and try to beat out a reasonable facsimile patch panel. Might be easier to match the contour with a 2 or 3 piece patch. I've got some patch work to do on my decks, so that was more of a pep talk to myself..... 4 2 Share this post Link to post Share on other sites
Blue Chips 881 #7 Posted January 3 (edited) If you have enough solid metal under and around the height-adjustment bracket, then I think you could get by with fiberglass and resin. If the height-adjustment bracket has lost much of its support, then if it were me I'd opt for welding. IF it's just a matter of expediency and looks don't matter, then a welded repair should be pretty easy. If appearances are important, it will take a bit of work to do a nice-looking welded repair, which would involve cutting back the rust until you hit good solid metal, and then cutting and shaping the insert(s) to match the opening and the original contours. Some extra strips of metal could be welded across the seams underneath the deck if extra strength is needed. Shaping mild steel sheet isn't terribly difficult for small pieces. If you don't have fancy equipment like a metal stretcher/shrinker, English wheel, bending brake, body hammers, dollies, etc., you can get by with a vise, a leather bag full of steel shot to pound against (or just some soft wood with a depression in it, like @8ntruck suggested) and a couple of sizes of peening hammers. Here are some photos of one of my more recent sheet metal repairs. It's not a mowing deck, but the approach is basically the same. BTW, I'm NOT a professional body man, but I like doing some sheet metal work from time to time. Before (bad welds and repairs by previous owners, rusted and cracked metal): Disassembled and chipped off enough old paint and body putty to assess how extensive the damage was, which revealed several cracks, rust, and bad brazing work: Straightened out a few spots, cut the cracked metal and rust spots back to solid metal, and started welding a few places. Not all of the repair areas are shown in these photos. New metal shaped, welded in, and rough ground: After a few small dabs of Bondo, sanding, and priming: The result after painting and reassembly (plus a new badge): If you haven't done sheet metal restoration before, fixing the deck could be a fun little project. Edited January 3 by Blue Chips 5 2 Share this post Link to post Share on other sites
Brockport Bill 2,553 #8 Posted January 3 2 hours ago, peter lena said: this is another stage of deck preservation on all my decks , found once done , and sun hot baked into cleaned / dry base , its going no whare , like a 2 step , chain / cable lube , hot bake that , once established use an OPEN GEAR spray , over that , and hot bake , better part of the day , at angle , to get hot , sit there for hours , also have them up against the wall stud , with heavy screw in eye , and spring to 10" long S looped connector , makes it easy to grab deck lift frame and hold in place , pete hey Pete -- when you do your sun soak treatment are we limited to how strong the sun is - and the outside temperatures? in other words -- is it essential for it to be summer or fall temps? Or, will a warm sunny winter day of perhaps 30-40 degrees produce enough "sun heat effect" to accomplish the process of the oil to the metal? Said simply -- if it's direct sunny day, what is the minimum outdoor temp that's needed to be effective and for how many hours? I have been doing the gear oil treatment on my decks for a few years with good results but have only done minimal sun treatment.......Thanks, Bill Share this post Link to post Share on other sites
Lee1977 7,813 #9 Posted January 3 I welded several pieces of 1/8" to the inside it's rough. Then fill in the out side with JB weld, it's held up for at least 20 years and still holding. . 3 Share this post Link to post Share on other sites
peter lena 10,125 #10 Posted January 3 @Brockport Bill basically found it better on a hotter day . think if you don't have sun , but do have a heated , inside set up it might work , reason for heat is that you can see the transitional oil absorption into / on the deck surface . realise everyone is going to see this differently , basically started it after , rebuilding all the spindles , and detailing the functional hell out of it , can honestly say the baked oil finish has been bombproof , years now , with zero wear areas . do a lot of experimenting on REPEDITIVE FAILURE AREAS , thats where I seperate myself from the regular , repetitive fix , decks and plows are fun to correct , and really not that difficult to do , often refer to roller stooling around , and studying failure points , lubrication failure is a very common ,problem . that and detailing , have stuff years , with zero issues , after correction . my decks spin up with no effort or noise , never burned up a pto clutch disk, every related bearing , was cleaned out and hand packed , with hi temp / stress grease . plow swing quadrant , and related squeeze lever , are the key areas , to movement ease , hiding in plane site , love to eliminate a problem . pete Share this post Link to post Share on other sites
Brockport Bill 2,553 #11 Posted January 4 1 hour ago, peter lena said: @Brockport Bill basically found it better on a hotter day . think if you don't have sun , but do have a heated , inside set up it might work , reason for heat is that you can see the transitional oil absorption into / on the deck surface . realise everyone is going to see this differently , basically started it after , rebuilding all the spindles , and detailing the functional hell out of it , can honestly say the baked oil finish has been bombproof , years now , with zero wear areas . do a lot of experimenting on REPEDITIVE FAILURE AREAS , thats where I seperate myself from the regular , repetitive fix , decks and plows are fun to correct , and really not that difficult to do , often refer to roller stooling around , and studying failure points , lubrication failure is a very common ,problem . that and detailing , have stuff years , with zero issues , after correction . my decks spin up with no effort or noise , never burned up a pto clutch disk, every related bearing , was cleaned out and hand packed , with hi temp / stress grease . plow swing quadrant , and related squeeze lever , are the key areas , to movement ease , hiding in plane site , love to eliminate a problem . pete so can i conclude based on your comments that a deck bottom could be cleaned in the winter --- then apply oil - then bring into heated garage and point space heater at oiled deck area and that the oiled deck surface would interact with metal just as if it were heated in the sun? Share this post Link to post Share on other sites
peter lena 10,125 #12 Posted January 4 @Brockport Bill I would think to a degree , ha ha , that would help establish it . if you can enhance that set up , angularity to air flow and deck bottom , would regularly settle things out . don,t forget 2 step process , lighter cable chain oil first , if it seams to dry , not run at all , would say ok , mine takes on a dull oiled look , then months of drying heat , for the open gear lube , that looks like , dry settled black oil is dry to touch . when doing this with sun , it doesn't go any whare , set up is there . all 3 of my decks have this , with no maintenance issues at all , still regularly , prop them up to the sun , inspeck , look over . dare to experiment , that led me to spindle belt bounce , add a flat idler push pulley , like this, imagine no buzzing belt , its LUBRICATION BASED , pete 1 Share this post Link to post Share on other sites
bo dawg 643 #13 Posted January 4 I do appreciate all the help and info, I think I will go with welding narrow strips of 1/8' metal running horizontally be easier to control the corner and making shorter and shorter strips to round over the top. (if that makes sense) Starting at the bottom and working up. Or as I was typing this.... I got a thought of going vertical with 1" strips bending over the top of deck butting them up. Am I thinking right about it or is that too much ? Share this post Link to post Share on other sites
