CD Long Jr 203 #1 Posted January 2 As some are aware, I'm new. I got my hands on a what the seller said was a 1992 312-8, with deck & front blade. Serial number says she's a 1988. She's not running. Needs ignition module, battery & Ignition switch key. I intend to roll her off the trailer, remove the deck & grease her. I have no idea when she last ran. What should I do, other than check the air filter & change the engine oil, before tryin' to start her. Anything with the carb & fuel tank? Anything with the oil in the rear? Share this post Link to post Share on other sites
Achto 32,347 #2 Posted January 2 (edited) 5 hours ago, CD Long Jr said: Anything with the carb & fuel tank? You'll want to make sure the fuel system is clean and that any old gas has been removed. @ebinmaine can you throw that new to me check list up? Edited January 2 by Achto 2 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #4 Posted January 2 1988 312-8 model 21-12K805 would have a 5 digit serial number. What we have recorded range from serial 27067-32459. Wheel Horse never published serial numbers and Toro started in 1991. 1992 312-8 model 31-12K804 would have a 7 digit serial number ranging from 2000001-2099999. If the decal also has a 4-digit number stamped on it and often faded it is the Julian build date. A 1xxx number would be a 1992 model made in late 1991 and a 2xxx would be made in 1992 1 Share this post Link to post Share on other sites
John2189 599 #5 Posted January 2 I would remove the engine shroud to be sure that there are no mice nests 1 2 Share this post Link to post Share on other sites
953 nut 68,500 #6 Posted January 2 2 hours ago, CD Long Jr said: Needs ignition module, battery & Ignition switch key I should have mentioned this in your other post, Lincoln at A-Z Tractor will probably have a good tested ignition module for your engine, give him a call on the phone, he will be able to furnish a used key too. https://a-ztractor.com/ 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,701 #7 Posted January 2 (edited) To save myself some headaches later on I have started to include fuel pump rebuild or at least a good cleaning and new diaphragm in my fuel rejuvenation procedure. I also recommend new r9 rated or above fuel line from tank to carb. If it was me I would want to confirm it had compression first then start on fuel system while I waited on ignition module. Edited January 2 by sqrlgtr Share this post Link to post Share on other sites
oliver2-44 11,694 #8 Posted January 2 While you wait for ignition module remove spark plug and spray a bunch of good penetrant like Kroil Dow spark plug hole. Let it set so penetrant reaches rings to free any that might be a little stuck FYI I’m assuming it has a Kohler Magnum engine. It has a compression release so you cannot check compression the normal way. You however can belt it to another tractor so engine turns in reverse and check compression that way. Share this post Link to post Share on other sites
953 nut 68,500 #9 Posted January 3 11 hours ago, 953 nut said: Lincoln at A-Z Tractor will probably have a good tested ignition module for your engine, give him a call He can also fix you up with the engine tins, cooling fan, voltage regulator and anything else you know are missing. 1 Share this post Link to post Share on other sites
