oliver2-44 11,610 #26 Posted January 8 (edited) Hang on to that small pedal or offer it for sale here. Someone is usually looking for one. Edited January 8 by oliver2-44 1 Share this post Link to post Share on other sites
WHX?? 57,275 #27 Posted January 8 (edited) 11 hours ago, 855project said: that might get eliminated I used to take them off knowing I was never gonna run a implement BUT @Achto restores them and puts them back on. More for safekeeping than anything. If it goes out to the magic parts shed it might be lost forever. Kinda like that battery tray I know is out there. I'm sure there are pics here that show the correct set up. Edited January 8 by WHX?? 1 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,171 #28 Posted January 8 7 minutes ago, WHX?? said: I used to take them off knowing I was never gonna run a implement BUT @Achto restores them and puts them back on. More for safekeeping than anything. If it goes out to the magic parts shed it might be lost forever. Kinda like that battery tray I know is out there. I'm sure there are pics here that show the correct set up. Looks like they would make a good feet throttle for a puller tractor also. I try and keep um also like @WHX?? says may get lost in the majical spare parts storage. Better to have it and not need it than to need it and not have it. 2 Share this post Link to post Share on other sites
Achto 32,035 #29 Posted January 8 (edited) 12 hours ago, 855project said: That might get eliminated or changed some 49 minutes ago, WHX?? said: @Achto restores them and puts them back on. Like Jim said I like to put them back on if for nothing else so is they don't get lost. They do not interfere with operation or for loading to go to a show. A few pic's to help explain where it goes. Basically the same set up on the square hoods like yours. Edited January 8 by Achto 2 2 Share this post Link to post Share on other sites
Handy Don 16,914 #30 Posted January 8 (edited) 14 hours ago, 855project said: Ah now it makes sense! Thanks guys, I had suspicions of that but never had a deck with the mower. That might get eliminated or changed some, I don't think I'll have a PTO attachment on this tractor. A couple of images augmenting @kpinnc’s response... The pedal with its spring puts tension on the belt to engage the implement; the lock latch holds it disengaged. I have only the mower deck but I believe it also handled others--tiller, sickle bar, etc. Similar to the drive belt, the PTO belt needs a close-aligned guide to slow/stop the belt when it is disengaged. I hadn’t learned that yet when these pictures were taken! Edited January 8 by Handy Don 1 Share this post Link to post Share on other sites
kpinnc 18,721 #31 Posted January 8 18 hours ago, 855project said: can't seem to figure out what the right side pedal does on the tractor, it has a spring but doesn't seem to be connected to anything important, the left side engages the clutch and the brake. Can someone point me in the right direction? If you decide against using the pedal, I'd take it off your hands. The PO of my 701 snapped it right off somehow. 1 Share this post Link to post Share on other sites
WHX?? 57,275 #32 Posted January 8 I may have one for you too KP. I get out to the parts shed for his battery tray I'll look. 2 Share this post Link to post Share on other sites
kpinnc 18,721 #33 Posted January 9 2 hours ago, WHX?? said: I may have one for you too KP. I get out to the parts shed for his battery tray I'll look. Thank ya sir! 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,667 #34 Posted January 9 (edited) 2 hours ago, WHX?? said: I may have one for you too KP. I get out to the parts shed for his battery tray I'll look. Hey when you're out there find me a Senior... enough with @Pullstart gettin all the Michigan ones... Edited January 9 by SylvanLakeWH 1 4 Share this post Link to post Share on other sites
855project 52 #35 Posted January 10 I'll get mine off and take some pics of it, I'd part with it although a foot throttle does sound kinda cool. 1 Share this post Link to post Share on other sites
855project 52 #36 Posted January 15 Not too much interesting to report, but the tractor is torn all the way down and cycling parts through the dip tank and getting primer on them, starting to have more parts cleaned and primed than dirty so that's good, made a good order from Wheelhorseparts, a bunch of odds and ends that I'll need to put things together so I'm excited to get that in the mail. The engine ran really well so I don't plan on tearing that down although I have taken the shields off to get ready for paint and clean the whole thing up. I plan on just cleaning everything well and painting the block and the shields and putting back together. 4 Share this post Link to post Share on other sites
WHX?? 57,275 #37 Posted January 15 9 hours ago, 855project said: don't plan on tearing that down although I have taken the shields off to get ready for paint and clean the whole thing up. I plan on just cleaning everything well and painting the block and the shields and putting back together. Sure does make restos go faster if you don't have to tear into it. Might just want to pop the head and check things out that's not a hugh chore. Check for oil wash and de-carbon. Examine the bore & valve seats. Even if you don't tear into it gives you an idea of what's going on in there. 1 Share this post Link to post Share on other sites
WHX?? 57,275 #38 Posted January 15 (edited) On 1/8/2026 at 2:50 PM, kpinnc said: using the pedal, I'd take it off your hands. The PO of my 701 snapped it right off somehow. Found this KP. Don't know if it's correct for a 701 or not. Think it was on a 753. Has a tlt on the side I don't see in Dan's pic Edited January 15 by WHX?? 2 Share this post Link to post Share on other sites
ebinmaine 79,503 #39 Posted January 15 6 hours ago, WHX?? said: want to pop the head and check things out Seconded. We've started removing the cylinder head and hand planing it on ALL our restorations. 4 Share this post Link to post Share on other sites
855project 52 #40 Posted January 15 I forgot to say that I got my right pedal off but it's missing the pulley that goes with it so I don't know if it's much good for anyone but if someone wanted it and paid the shipping I'd send it off. 2 Share this post Link to post Share on other sites
Achto 32,035 #41 Posted January 15 (edited) I agree with pulling the head to see what's what. I pulled the head on a non-smoking engine on this years resto. Found that it had a fair amount of piston wash & you could use the cylinder as a mirror to shave with. Piston should have a black coating most all the way across. Was an unplanned rebuild but I will feel better when it's done. Edited January 15 by Achto 2 1 Share this post Link to post Share on other sites
WHX?? 57,275 #42 Posted January 16 22 minutes ago, Achto said: I pulled the head on a non-smoking engine But that's what made me think of telling him. I would have been tempted to run it 855 but his royal analness is just going to hone it and put new rings in. Not a bad move I guess. Yah EB a guy can glass it as long as it's off. 57 minutes ago, 855project said: missing the pulley that goes with it The pullies I have a ton of. Its the same one that's in the clutch. If you ain't gonna run a PTO maybe KP would want the pedal then. I should put mine back on the tractor it belongs with. 1 1 Share this post Link to post Share on other sites
855project 52 #43 Posted January 17 Anyone have any advise for me, getting close to painting stuff and hoping I can get it to turn out decent. So far all the parts have been sprayed with a Rust-Oleum gray primer and I think going to use the Rust-Oleum regal red paint to finish it. I know a bunch of you guys have a lot more experience than I do, just looking for some helpful tips. Thanks Share this post Link to post Share on other sites
oliver2-44 11,610 #44 Posted January 17 If your using a gun get some enamel hardener such as Majic brand hardener from tractor supply. Do not use their paint just the hardener. Drys much faster and higher gloss. 1 Share this post Link to post Share on other sites
Easton Rich 1,259 #45 Posted January 17 I will say IH red is brighter than regal red. They are extremely similar, but I use IH red for everything 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,667 #46 Posted January 17 I've used Rusto Regal Red and Satin Black on all my Black Hoods. I've been satisfied with the results. I like the multi spray tips - if one gets spurty or clogs, you got options... My paint jobs are best admired from a distance though... 3 Share this post Link to post Share on other sites
adsm08 4,747 #47 Posted January 17 55 minutes ago, SylvanLakeWH said: My paint jobs are best admired from a distance though We call those a 50/50 job where I come from. Looks good from 50 ft or 50 MPH. 1 3 Share this post Link to post Share on other sites
ebinmaine 79,503 #48 Posted January 17 37 minutes ago, adsm08 said: We call those a 50/50 job where I come from. Looks good from 50 ft or 50 MPH. Yepp. We have 50/50s and 20/20s or regular. Share this post Link to post Share on other sites
squonk 47,262 #49 Posted January 17 On 1/8/2026 at 12:12 PM, Handy Don said: A couple of images augmenting @kpinnc’s response... The pedal with its spring puts tension on the belt to engage the implement; the lock latch holds it disengaged. I have only the mower deck but I believe it also handled others--tiller, sickle bar, etc. Similar to the drive belt, the PTO belt needs a close-aligned guide to slow/stop the belt when it is disengaged. I hadn’t learned that yet when these pictures were taken! We had a 604 brandy new in 64. It did not have the belt stop thingy on it. Share this post Link to post Share on other sites
855project 52 #50 Posted January 17 I was thinking that it should look good from 100ft, maybe I'll have to up my targets to 50ft, I like the 50/50 rule. I let my nephew decide the color and we looked at IH red and Regal red, after a long deliberation he decided that we shouldnt make it too bright since we probably won't wash it very often haha, smart kid. 1 Share this post Link to post Share on other sites
