Webrx 0 #1 Posted December 28, 2025 Hi, new guy here. I have a few older cubs and a GT14. The GT was an engine and trans on a rolling frame so it’s mostly just a shell. I bought it for the engine but found it won’t work in the project I had. So, I decided to see if the trans works. My intent is to use it as a trailer puller and maybe do a little snow plowing. The pressure hydraulic hose was there but the return was missing. So, I looped the hose from pressure to return, replaced filter and fluids and put it on jack stands. Fired it up, had motion in fwd and reverse but the hoses leak pretty good. 2 questions. 1. is looping this hose going to cause an issue assuming I can stop the leaks. 2. Is it ok to plug the hydraulics off if I don’t intend to use them just now, assuming I can find plugs that are right size. thanks in advance for any info. Share this post Link to post Share on other sites
953 nut 64,611 #2 Posted December 29, 2025 Our resident Sundstrand experts @daveoman1966 or @pfrederi should be along to help. in the meantime take a look at this manual. 1 Share this post Link to post Share on other sites
pfrederi 20,048 #3 Posted December 29, 2025 Welcome. You have a Sunstrand Hydro gear system. If you want to eliminate the hydraulic lift You need to make some changes to relief valves. You will remove the implement lift check valve and move the charge pump relief valve over to that position and plug that port. Do not just plug ports. Look a page 35/6 in the manual provided above. I am not sure if you loop idea will cause an issue or not. 1 Share this post Link to post Share on other sites
Handy Don 16,049 #4 Posted December 29, 2025 40 minutes ago, pfrederi said: Welcome Ditto! And be sure to hold onto any parts you remove! Many members work on Sunstrands, some converting the other way (to ADD hydraulic lift) and look for parts! 1 1 Share this post Link to post Share on other sites
cleat 8,813 #5 Posted December 29, 2025 I would think the loop should be fine as that is really what happens with the lift valve plumbed in as the oil passes through the valve and back to the return when it is not being actuated. Your leaks might be as simple as needing new O rings on the hose fittings. 1 1 Share this post Link to post Share on other sites
pfrederi 20,048 #6 Posted December 29, 2025 Looking at Cleats reply and thinking on it he is right the loop should not cause an issue... If it is leaky hose ends you could try replacing the O rings Sometimes it is the swivel itself worn out..but it doesn't hurt to try the rings first. They are Dash #905 o rings. PM me your address i can send you a couple. 1 1 Share this post Link to post Share on other sites
