Bill D 2,462 #26 Posted 7 hours ago 10 minutes ago, Krice58 said: I don’t see a regulator on the parts tractor? Would it be unregulated? Likely unregulated 3 amp charging system with separate A/C line for the lights. You may want to swap the charging stator. Share this post Link to post Share on other sites
Krice58 138 #27 Posted 7 hours ago Two wires coming out of the shroud Share this post Link to post Share on other sites
Krice58 138 #28 Posted 6 hours ago Comparing the two wiring diagrams I’m trying to figure out what would need to be changed. Ignition switch is the same, coil is the same, solenoid is different not sure if that matters, original K341 harness has rectifier K301 does not. Don’t really care about original lights, I have leds wired to a switch. Share this post Link to post Share on other sites
