c-series don 12,446 #26 Posted December 30, 2025 @peter lena Funny thing Pete, Friday night before I took out my 418-C to plow the driveway I did in fact lube everything up and thought “Peter would be happy about this!” I was going to take a picture of me doing just that but was in a bit of a hurry, as we had received 5” of snow in under three hours. We ended up with around 8” by morning. 2 1 Share this post Link to post Share on other sites
peter lena 10,065 #27 Posted December 30, 2025 @c-series don thanks for sharing that , had about out the same ammount of snow . that mower deck spray graphite on the blade , made a world of difference on angular snow slide off , MOWER GUARD BY SLIP PLATE , next to nothing sticks on the blade , put that on last fall , really unaffected by snow , lets you do a quick easy , back plow on your edging . allowing you to plow toward that , as you know once it sets up , its a wall , so I always go long on first movement , pete 3 Share this post Link to post Share on other sites
RoubaixRider 284 #28 Posted December 30, 2025 Fabricated some Heim joints for my steering upgrade. Always a good day when you get to spark up the welder. Will be nice to have some adjustability. 1 7 Share this post Link to post Share on other sites
peter lena 10,065 #29 Posted December 31, 2025 @RoubaixRider , happy new year ! been experimenting with heim joints for years , extremely durable , like SUPER LUBE hydraulic oil in them , extreme temp range and rating , love it on the pto lever rod end , replacing the sloppy trundle , the ability to ANGULATE SMOOTH MOTION , for any lever end point , eliminates a lot of sloppy issues . use a DIE NUT 3/8 x 24 right over the original 3/8 x 16 threading , lubricate , heim screws right on , like this , that area is a GOLD MINE for improvement , glad to share it with you , questions ? ask away , pete Share this post Link to post Share on other sites
RoubaixRider 284 #30 Posted December 31, 2025 4 hours ago, peter lena said: @RoubaixRider , happy new year ! been experimenting with heim joints for years , extremely durable , like SUPER LUBE hydraulic oil in them , extreme temp range and rating , love it on the pto lever rod end , replacing the sloppy trundle , the ability to ANGULATE SMOOTH MOTION , for any lever end point , eliminates a lot of sloppy issues . use a DIE NUT 3/8 x 24 right over the original 3/8 x 16 threading , lubricate , heim screws right on , like this , that area is a GOLD MINE for improvement , glad to share it with you , questions ? ask away , pete That’s awesome Pete… Appreciate the feedback. Yes… The original ball and socket style steering system are definitely inferior, and I had replaced those on my CASE 444 as well. Made a massive difference in tightening up the steering, especially at high speed!🤣🤣🤣. my buddy was teasing me about my Heim joint fabrication, asking… “What do you need all that adjustability for, it’s a garden tractor! some people just don’t understand🤣🤓 1 1 Share this post Link to post Share on other sites
peter lena 10,065 #31 Posted December 31, 2025 @RoubaixRider notice 2nd photo down , the pto outer swing arm , connection slide pin ? there is a light extension spring just visible on the right outside ? have that attached to the frame mount hitch pin clip , rounded end , that tension , eliminates all the buzzing , bouncing , with that set up . always looking for some improvement , love REPEDITIVE ISSUES , ? take them apart and improve as you go , more often than not , its been a pretty simple mod . also like a black vinyl cap on my axel spindle top , initial snug fit is just right . also have heim joint on my clutch linkage , many years no failures . good talkin , pete Share this post Link to post Share on other sites
Retired Wrencher 6,989 #32 Posted January 2 On 12/18/2025 at 3:40 PM, RoubaixRider said: It is now officially in two halves🤣 next step is going to be some serious cleaning and sanding/media blasting. I’m not going gangbusters on the sanding on this one… My hands took a real beating when I redid my CASE 444, so there’s going to be a lot of media blasting work done on this one. J Personally, and I’m not alone on this. I would just clean everything. Tap and die all all holes and bolts cause there’s a lot of stuff over the years it gets on those threats just slowly reassemble it and enjoy it. Share this post Link to post Share on other sites
RoubaixRider 284 #33 Posted January 3 (edited) On 1/2/2026 at 3:45 AM, Retired Wrencher said: Personally, and I’m not alone on this. I would just clean everything. Tap and die all all holes and bolts cause there’s a lot of stuff over the years it gets on those threats just slowly reassemble it and enjoy it. The project is a full restoration. Complete disassembly, repairs, corrosion treatment if any and repainting to factory original as close as possible. Edited January 3 by RoubaixRider 2 Share this post Link to post Share on other sites
RoubaixRider 284 #34 Posted January 3 (edited) On 12/31/2025 at 1:00 PM, peter lena said: @RoubaixRider notice 2nd photo down , the pto outer swing arm , connection slide pin ? there is a light extension spring just visible on the right outside ? have that attached to the frame mount hitch pin clip , rounded end , that tension , eliminates all the buzzing , bouncing , with that set up . always looking for some improvement , love REPEDITIVE ISSUES , ? take them apart and improve as you go , more often than not , its been a pretty simple mod . also like a black vinyl cap on my axel spindle top , initial snug fit is just right . also have heim joint on my clutch linkage , many years no failures . good talkin , pete Hi Pete, i’m not exactly sure what you mean… You mentioned the second photo down. Could you expand a little bit… It’s always great to get good advice on making improvements. Most of my experience is with case tractors… As well as Bell Helicopters🤣 Edited January 3 by RoubaixRider Share this post Link to post Share on other sites
RoubaixRider 284 #35 Posted January 3 Finally got the center console base and hood shot with paint after a lot of sanding some very minor Bondo prep and several sanded coats of primer. normally, I enjoy painting, but this project has been a little more frustrating, but it’s going slowly. Patience. 4 Share this post Link to post Share on other sites
sqrlgtr 3,930 #36 Posted January 3 @RoubaixRider Looks great. Are you still using the Rustoleum Sunrise Red ? Share this post Link to post Share on other sites
AlexR 3,112 #37 Posted January 3 Very nice job on that hood!!! 1 Share this post Link to post Share on other sites
RoubaixRider 284 #38 Posted January 3 1 hour ago, sqrlgtr said: @RoubaixRider Looks great. Are you still using the Rustoleum Sunrise Red ? Yes sir. It’s been a tricky paint to use… Either runs or orange peel… Obviously that is application error. Unfortunately I don’t have my good paint gun with me in the shop at the moment so it’s rattle can action. 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,930 #39 Posted January 3 14 minutes ago, RoubaixRider said: Yes sir. It’s been a tricky paint to use… Either runs or orange peel… Obviously that is application error. Unfortunately I don’t have my good paint gun with me in the shop at the moment so it’s rattle can action. My experience, If I try and go back over it with another coat it will orange peel on me. I have got in the habit of barely covering with first coat (can still see primer/old paint) just barely wet and then quick as I can throw the paint to it or try and cover with first coat and quit after that. If I try and do 2 or 3 coats it will orange peel every time. If i want to go back over it after that may as well figure on a month of cure time before starting to paint again Of course everybody has there on procedure and this might not work for everyone. This is when using rattle cans. If you're for a spray gun you will have more control over cure times and such. Share this post Link to post Share on other sites
RoubaixRider 284 #40 Posted January 6 On 1/2/2026 at 3:45 AM, Retired Wrencher said: Personally, and I’m not alone on this. I would just clean everything. Tap and die all all holes and bolts cause there’s a lot of stuff over the years it gets on those threats just slowly reassemble it and enjoy it. You know, I’ve been thinking about this reply for the last week or so and I’m confused by it. Do people think it’s a mistake that I’m doing a restoration on this tractor? 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,504 #41 Posted January 6 11 minutes ago, RoubaixRider said: You know, I’ve been thinking about this reply for the last week or so and I’m confused by it. Do people think it’s a mistake that I’m doing a restoration on this tractor? Your tractor your choice. Always going to have people chiming in with opinions. To be expected. Difference with this site vs elsewhere is that those opinions are respectful. You're doing a great job and I am enjoying tagging along. 1 Share this post Link to post Share on other sites
Treepep 1,151 #42 Posted January 6 54 minutes ago, RoubaixRider said: Personally, and I’m not alone on this. I would just clean everything. Tap and die all all holes and bolts cause there’s a lot of stuff over the years it gets on those THREADS. Just slowly reassemble it and enjoy it. Fixed it Share this post Link to post Share on other sites
Handy Don 17,474 #43 Posted January 6 39 minutes ago, SylvanLakeWH said: Your tractor your choice. Always going to have people chiming in with opinions. To be expected. Difference with this site vs elsewhere is that those opinions are respectful. Grownups here who recognize that other grownups get to make their own decisions! Whatever makes you smile about that tractor is what you should go ahead and do. 2 2 Share this post Link to post Share on other sites
RoubaixRider 284 #44 Posted January 7 (edited) Ran out of daylight, but the reassembly fun continues… right now a lot of it is just dry fitting all the parts and making sure all the holes and everything lineup nice and putting things back in the proper order. Was really happy with the way the aluminum dash console cleaned up on the inside… It was quite a mess with corrosion! I was not able to get the pin out of the steering wheel… No matter what I tried… Even a hydraulic press. So I decided to just sever the steering shaft and it will get reinserted and spot welded. Fortunately, I’ve got lots of leather and fireproof blankets to throw over the machine when I weld the steering shaft back together. should make for an interesting video lol. Edited January 7 by RoubaixRider 2 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,504 #45 Posted January 7 11 minutes ago, RoubaixRider said: steering shaft and it will get reinserted and spot welded. Fortunately, I’ve got lots of leather and fireproof blankets to throw over the machine when I weld the steering shaft back together Could just use a shaft collar. That way you can easily take it back apart if need arises... 2 Share this post Link to post Share on other sites
RoubaixRider 284 #46 Posted January 7 55 minutes ago, SylvanLakeWH said: Could just use a shaft collar. That way you can easily take it back apart if need arises... Very good idea. I picked one up the other day that will do the trick…much easier than re-welding it surrounded by freshly painted parts, even with all my protective blankets.🤓 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #47 Posted January 7 (edited) 18 hours ago, RoubaixRider said: You know, I’ve been thinking about this reply for the last week or so and I’m confused by it. Do people think it’s a mistake that I’m doing a restoration on this tractor? A lot of times when people get into this hobby, they make a mistake where they want it to shine and look new. I’ve been there done that a few times. Much time involved and I guess when you get older, you just think that it’s not worth it. That’s why I’m at it happily just enjoying what I have for what it is. Just my two cents. Edited January 7 by Retired Wrencher 1 2 Share this post Link to post Share on other sites
rjg854 13,359 #48 Posted January 7 (edited) The only ones I've painted were the ones some else had already messed with. I'm of the idea they are only original once. And I like them to show their age and yet they still perform like new. I do like clean wheels, that to me is the eye catcher. Edited January 7 by rjg854 add 2 Share this post Link to post Share on other sites
RoubaixRider 284 #49 Posted January 7 On 12/31/2025 at 5:27 AM, peter lena said: @RoubaixRider , happy new year ! been experimenting with heim joints for years , extremely durable , like SUPER LUBE hydraulic oil in them , extreme temp range and rating , love it on the pto lever rod end , replacing the sloppy trundle , the ability to ANGULATE SMOOTH MOTION , for any lever end point , eliminates a lot of sloppy issues . use a DIE NUT 3/8 x 24 right over the original 3/8 x 16 threading , lubricate , heim screws right on , like this , that area is a GOLD MINE for improvement , glad to share it with you , questions ? ask away , pete Pete, I checked out your link showing your PTO shaft Heim joint upgrade. I’m going to do the same. Looks fantastic and must be so much more positive a feel of engagement. 1 Share this post Link to post Share on other sites
RoubaixRider 284 #50 Posted January 7 22 hours ago, Treepep said: Fixed it 🤣🤣 Share this post Link to post Share on other sites
