mike avad 61 #1 Posted December 6, 2025 Will this snow thrower mount on a 1976 wheel horse B-80 the snow thrower model no.79262 and the serail is 5900198 and what belt size would be used for this? Share this post Link to post Share on other sites
ri702bill 13,189 #2 Posted December 6, 2025 Did you look in the pinned Implement Interchange Chart Models 1955-2000? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #3 Posted December 6, 2025 Will not work as the 79262 is for models with a vertical engine crankshaft. You can see the model used in 1976. Here is a list of the models you need Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar for the front quick hitch. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 1 Share this post Link to post Share on other sites
Handy Don 17,557 #4 Posted December 6, 2025 And @gwest_ca comes through again! Share this post Link to post Share on other sites
