Pullstart 68,407 #2 Posted Monday at 03:11 PM I’ve never seen one at the pump, but I do know what they are! 4 Share this post Link to post Share on other sites
JoeM 9,064 #3 Posted Monday at 03:14 PM 2 minutes ago, Pullstart said: I’ve never seen one at the pump Pretty common to see a six pack at the pump back in the day. Amazing, no caps just wide open tops. 1 Share this post Link to post Share on other sites
ri702bill 10,306 #4 Posted Monday at 03:58 PM A friend of mine ran a local Discount Gas Station in the early 1970's. He used to drain and collect all what was left at the bottom of the cardboard / metal quarts of top price name brand oil. Guess where it ended up selling for half the cost at the pump. Pure profit there... 1 7 Share this post Link to post Share on other sites
c-series don 10,687 #5 Posted Monday at 04:05 PM I don’t remember glass bottles, but I do remember the quart cans that you had to jam the spout into. Or a knife or screwdriver, whatever you had handy to open it! And then if the spout wasn’t sharp and it was on of those heavy paper cans that had been exposed to any moisture the top of the can would kink then spout wouldn’t seal up good and oil would leak all over!! 10 Share this post Link to post Share on other sites
ebinmaine 74,991 #6 Posted Monday at 04:23 PM 17 minutes ago, c-series don said: I don’t remember glass bottles, but I do remember the quart cans that you had to jam the spout into. Or a knife or screwdriver, whatever you had handy to open it! And then if the spout wasn’t sharp and it was on of those heavy paper cans that had been exposed to any moisture the top of the can would kink then spout wouldn’t seal up good and oil would leak all over!! Same here. When I started selling Auto Parts in north central Massachusetts in 1992 there were still a few products available in the old round cardboard cans with metal tops. Most things had switched over to the plastic bottles we know of today. Share this post Link to post Share on other sites
Skwerl58 769 #7 Posted Monday at 04:28 PM We had a FISCA station that used these well into the upper 70's. It was the only place I remember using them. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,519 #8 Posted Monday at 05:36 PM 1 hour ago, ri702bill said: A friend of mine ran a local Discount Gas Station in the early 1970's. He used to drain and collect all what was left at the bottom of the cardboard / metal quarts of top price name brand oil. Guess where it ended up selling for half the cost at the pump. Pure profit there... My Dad had a jig in the garage that funneled oil cans into a jar... Always had oil for oil cans, chains etc. It was a large funnel on top a jar with two pieces of wood to hold an upside down can in the funnel... I still do this with the plastic bottles... keeps my oiler jars full... Waste not want not... 8 1 1 Share this post Link to post Share on other sites
Ed Kennell 43,366 #9 Posted Monday at 08:53 PM Nope, we had tin cans that you pierced with the pointed spout. Also had a 5-6 foot section of rain gutter nailed to the wall at an angle that drained about two dozen oil cans into a glass jar. 1 4 Share this post Link to post Share on other sites
Handy Don 14,886 #10 Posted Monday at 09:10 PM And now the “lube shops” use an electronically-controlled metered pump with a nozzle for quick oil changes, which I fervently distrust. I”ve asked who certifies the pumps and got “we do” for an answer! The techs in the shop I patronize use hand pumps from a barrel into a measuring pitcher/funnel and then pour it into the car. They also measure the drained oil so they can note any conspicuous consumption. 3 1 1 1 Share this post Link to post Share on other sites
8ntruck 8,258 #11 Posted Monday at 10:29 PM I don't remember seing them at gas stations, but dad had one hanging around. 2 Share this post Link to post Share on other sites
Beap52 1,699 #12 Posted Monday at 11:01 PM I prefer to change my own oil in our four vehicles, two mowers and two generators. While I'm under the vehicles I can give them a shot of grease as needed, look for leaks, just keep an eye on things in general. In our three older vehicles, (ranging from 1947 to 1992) I've began syphoning out the brake fluid and power steering pump pretty much every time I change oil. I figure it won't hurt to keep these fluids clean as well. The last time I changed transmission fluid in my 1992 pickup, I had a drain installed. Now, if/when I change the fluid and/or filter, I can drain before loosening the pan on the transmission. I may or may not drain the transmission fluid between recommended intervals without dropping the pan and new filter--just because. The '47 doesn't have an oil filter but it does have a cap on the side of the distributor that needs a quarter turn or so to lube the distributor shaft every so often and the heat riser needs to be twisted so it doesn't get frozen in place. My (reproduction) owner's manual has quite list of maintenance procedures that were required often for these old cars. I've don't remember seeing the glass oil jugs, but have punched holes in the top of cardboard oil cans. If using a flat blade screwdriver, drive it in and give it a spin to make a nice round hole then on opposite side of lid, a smaller one for air. And, like others, have crushed my share along the way when using the metal spout. 2 Share this post Link to post Share on other sites
953 nut 62,606 #13 Posted Tuesday at 12:01 AM @JoeM, I'm about as old as anyone on this site but only remember seeing the glass oil containers in antique shops. Metal cans and funnel spout was what I grew up with. When my brother passed away I went through the shop hoping to find it and some other things I have absolutely no use for but wanted to have, never did find it. 1 2 Share this post Link to post Share on other sites
JimSraj 559 #14 Posted Tuesday at 01:36 AM Many of you probably remember going to the ‘filling station’ and being asked by the attendant, that was going to pump your gas and clean your windshield, if you wanted the oil and washer fluid checked. Around here, if you needed a small amount of oil it would have come from that glass jar that was near the pump. Gas was around $.30 per gallon. 1 Share this post Link to post Share on other sites
JoeM 9,064 #15 Posted Tuesday at 05:02 AM The small town I grew up in had one gas station on every road leading out of town, four. Two were modern and two still had the old tall pumps and one was a general store but by today's standards a 7/11 and free air. It was the early sixties and remember my mom getting gas and those bottles at the pumps. I even ask the guy what is that? A deep brown greenish liquid. (just like me it looks a lot different now) Ten years later, working in a garage for change, we used a drum and pumped into a galvanized container that held a gallon. We never kept track just filled up with the dipstick. Back then people checked their own oil often, mostly out of necessity, and the last thing you wanted to do is short change someone. Oh Boy that was a big deal. Sold oil by the paper quarts over the counter at that time I know now cars and some trucks don't even have dip sticks on their transmissions. I think my truck calls for 150k fluid changes on trans and diffs. Just in the 130 range now, probably replace the truck not the fluids before that time comes. . 3 Share this post Link to post Share on other sites
ebinmaine 74,991 #16 Posted Tuesday at 09:40 AM 4 hours ago, JoeM said: I know now cars and some trucks don't even have dip sticks on their transmissions. I think my truck calls for 150k fluid changes on trans and diffs. Just in the 130 range now, probably replace the truck not the fluids before that time comes. Yep. My Kia Soul has "lifetime transmission fluid". Likely I'll also swap the vehicle instead of the fluid. I've been looking at a fluid swap. Can't DIY this one without a code scanner I won't buy. Maybe our local mechanic will do it. Maybe I'll get a different vehicle. Share this post Link to post Share on other sites
Ed Kennell 43,366 #17 Posted Tuesday at 12:26 PM 7 hours ago, JoeM said: I know now cars and some trucks don't even have dip sticks on their transmissions When I had Mrs.Ks new Ford Escape in for it's first annual PeeAaa state inspection, my local guy reported oil on top of the tranny cooling fins. No dip stick to check it, so back to the dealer under warranty. They drained it, measured what came out and determined too much was put in during assembly and it was being forced out a vent hole. 4 Share this post Link to post Share on other sites
JoeM 9,064 #18 Posted Tuesday at 12:45 PM 8 minutes ago, Ed Kennell said: Ford Escape My daughter just replaced her 20 Escape. 78K miles. RPM's were surging. Turns out the antifreeze was low too. Sure sign of a cracked block or head gasket. My daughter was pissed. She keeps cars for 10 years and only had 2 more payments. On the other side of family my DIL's father works the service desk for a Ford dealer. He says the engineering on stuff now is bad. Tons of recalls. Probably like where I worked, they got rid of anyone knowing anything for lower cost new guys. Then they struggle and wonder why. 5 Share this post Link to post Share on other sites
rmaynard 16,647 #19 Posted Tuesday at 02:04 PM I am old enough to remember the hand-cranked oil dispensers at gas filling stations. Glass bottles with metal lids. I collect small oil cans, but I also have a couple old glass bottles. The one in the picture is a genuine bottle with spout. There are a lot of fakes found in antique stores nowadays. Most of the fake spouts are screwed to quart Mason jars. Back in the day, oil sales were regulated. If you find an original jar it will have several marks embossed in the glass. A fill-to line, and a State approval mark. In this case it was marked for Pennsylvania. Just a few worthless facts... 3 2 1 Share this post Link to post Share on other sites
ebinmaine 74,991 #20 Posted Tuesday at 03:47 PM 1 hour ago, rmaynard said: Just a few interesting facts... Fixed it for ya 2 Share this post Link to post Share on other sites
Lee1977 7,419 #21 Posted Tuesday at 07:22 PM I remember the old hand pump gas and oil tank There was a Esso station 200 yards beside the local school. Stayed in operation until around 1955. I have the little 20 gallon air compressor that set beside that store. The 1/4 HP motor and compressor still works but the tank is rusted out. My uncle work for Esso repairing gas pumps at area stations. Share this post Link to post Share on other sites
Wayne0 1,388 #22 Posted Tuesday at 09:28 PM We had a "Tulsa" gas station in the next town over that sold "Recycled" oil in those bottles. Share this post Link to post Share on other sites
RJ Hamner 1,026 #23 Posted Tuesday at 11:51 PM I remember these.One of the local gas stations (not a big name one) always had the the 6 bottle holders at all the pumps. They were for "recycled" oil and were dirt cheap.. As my first car was a 53 Chevy that went thru a quart every 50 miles they were my usual brand. It didnt burn the oil just leaked it 1 Share this post Link to post Share on other sites
c-series don 10,687 #24 Posted 6 hours ago (edited) @rmaynard A few days ago we discussed slides. Probably 10 years ago I was going through my dad’s slides and found this picture he took of the Esso gas station and general store across the road from our house. I’m not sure what year it was taken, but I know it was before I was born. I have the glass Esso plate out of one of those pumps. Someone gave it to me because they knew I would appreciate where it came from. As a kid I remember the pumps still in service but it wasn’t Esso anymore, at least I don’t think it was. After I had the slide printed into a picture I had an extra one made to hang in the store that is now a deli. I hung this picture in my garage and one day after it was already there for a few years I looked up at it and realized that I have the sign that is in the picture hung up almost right next to it! I circled it in red. This was my family’s business sign. Edited 6 hours ago by c-series don 1 Share this post Link to post Share on other sites
