Retired Wrencher 6,098 #1 Posted 6 hours ago There was discussion about fuel pumps in another post. And they mentioned then and now automotive make four different gasket kits to rebuild a fuel pump. My spec number is S-46 215. Could not find any information on that spec number. If anybody has done business with this parts supplier and they have old K2 41s I’d appreciate it. If they have a number for that fuel pump.. Not quite sure which one to get. Any Info would be much appreciated. Share this post Link to post Share on other sites
953 nut 62,561 #2 Posted 6 hours ago https://www.then-now-auto.com/kohler-fuel-pumps-2/ They are good people, call first so they can send you what you need. 2 Share this post Link to post Share on other sites
pfrederi 19,074 #3 Posted 5 hours ago That spec number engine came with pump # 4755904 Share this post Link to post Share on other sites
oliver2-44 11,021 #4 Posted 1 hour ago 4 hours ago, 953 nut said: https://www.then-now-auto.com/kohler-fuel-pumps-2/ They are good people, call first so they can send you what you need. I've sent them a picture of my pump to be sure I get the right one. Share this post Link to post Share on other sites
Retired Wrencher 6,098 #5 Posted 1 hour ago 4 hours ago, 953 nut said: https://www.then-now-auto.com/kohler-fuel-pumps-2/ They are good people, call first so they can send you what you need. Ok thanks. Share this post Link to post Share on other sites
Retired Wrencher 6,098 #6 Posted 1 hour ago 4 minutes ago, oliver2-44 said: I've sent them a picture of my pump to be sure I get the right one. The only this invisible is the outside. I know it started leaking. I bought some rebuilt kits from I saved tractors and the one that I put in the pump that is running the 1056 it leaks. So something‘s not right there. I’ve done a bunch of fuel pumps so not sure but thank you for the information and I will definitely do that. Share this post Link to post Share on other sites
