jsoluna 514 #26 Posted November 29, 2025 (edited) 15 minutes ago, lynnmor said: Pull the gas tank and clean under there, it is a good place for debris to cause rust. In my opinion a pressure washer has no place in the Wheel Horse world. I use an engine cleaner with a parts cleaning brush and then rinse with a garden hose. That small space under the engine should be kept clean so the fins under there can cool the oil. Thanks. I do plan on a more thorough second stage of cleaning once the unit is proven to be basically functional. Gotta hear it run and see it move first. Edited November 29, 2025 by jsoluna 4 Share this post Link to post Share on other sites
jsoluna 514 #27 Posted November 30, 2025 (edited) Well I can confirm that the sub - $100.00 aftermarket ignition system kit that includes the coil, condenser, and ignition module does indeed work. I was quite skeptical after I opened it up and saw how drastically different the module was from the original. It required drilling new mounting holes and extending the wiring, as the wires exit the module opposite from the factory location. The coil brass posts are not threaded very well and will strip extremely easily. Luckily there is enough thread on the posts that you can stack some washers up and try again if you have stripped them at the base. Longevity is yet to be seen. Spark quality is fantastic. It will throw a bright blue spark at .750" gap @ atmospheric pressure. Is it worth the savings versus an Onan module and Harley coil? Time will tell. Edited November 30, 2025 by jsoluna 4 Share this post Link to post Share on other sites
lynnmor 9,040 #28 Posted November 30, 2025 1 hour ago, jsoluna said: Well I can confirm that the sub - $100.00 aftermarket ignition system kit that includes the coil, condenser, and ignition module does indeed work. I was quite skeptical after I opened it up and saw how drastically different the module was from the original. It required drilling new mounting holes and extending the wiring, as the wires exit the module opposite from the factory location. The coil brass posts are not threaded very well and will strip extremely easily. Luckily there is enough thread on the posts that you can stack some washers up and try again if you have stripped them at the base. Longevity is yet to be seen. Spark quality is fantastic. It will throw a bright blue spark at .750" gap @ atmospheric pressure. Is it worth the savings versus an Onan module and Harley coil? Time will tell. The factory coil kit from Onan needs machine work as well and extension wire and a new bracket are included, the studs on the coil are also weak and will not be replaced under warranty if stripped. The two coil studs are different sizes and you might have metric threads on the replacement. You should have a "gasket" under the module, it is used to insulate some of the engine heat, older models didn't have it but you should add it. 2 1 Share this post Link to post Share on other sites
jsoluna 514 #30 Posted November 30, 2025 8 hours ago, lynnmor said: The factory coil kit from Onan needs machine work as well and extension wire and a new bracket are included, the studs on the coil are also weak and will not be replaced under warranty if stripped. The two coil studs are different sizes and you might have metric threads on the replacement. You should have a "gasket" under the module, it is used to insulate some of the engine heat, older models didn't have it but you should add it. I did add an insulator between the module and the cover. Appears to be for heat dissipation, as the module is case grounded through the mounting bolts. 1 Share this post Link to post Share on other sites
jsoluna 514 #31 Posted December 9, 2025 (edited) Does anyone have a picture of the (2) spring washers under the lower friction washer on the hydro cam plate? (#9 on the parts diagram below.) Just took this one apart and found what I think is a single domed, solid washer. None of the parts diagrams show that. Wondering if I have a previous owner "fix".... I assume they are like spring/wave washer of sorts? Or are they bellville washers? Edited December 9, 2025 by jsoluna 3 Share this post Link to post Share on other sites
ebinmaine 80,708 #32 Posted December 9, 2025 Check @cleat 's thread about his 416 1 1 Share this post Link to post Share on other sites
jsoluna 514 #33 Posted December 9, 2025 2 hours ago, ebinmaine said: Check @cleat 's thread about his 416 Cleat's thread is fantastic. However, during the rebuild, he did not use the factory spring washer and tension washer setup at the hydro cam plate, so for OEM reference it does not suffice. https://www.wheelhorseforum.com/topic/110413-got-another-one-a-416-this-time/?do=findComment&comment=1253363 2 1 Share this post Link to post Share on other sites
cleat 9,333 #34 Posted December 9, 2025 (edited) 3 hours ago, jsoluna said: Does anyone have a picture of the (2) spring washers under the lower friction washer on the hydro cam plate? (#9 on the parts diagram below.) Just took this one apart and found what I think is a single domed, solid washer. None of the parts diagrams show that. Wondering if I have a previous owner "fix".... I assume they are like spring/wave washer of sorts? Or are they bellville washers? Thanks Guys. My 416 is going to foot control so removed those spring washers. There should be two dome shaped washers that go in facing each other for spring action. I wonder if your is missing one or they are just facing the same direction and stacked. Likely either way will work so long as you can get the proper drag when tightened as shown below. Edited December 9, 2025 by cleat 3 Share this post Link to post Share on other sites
jsoluna 514 #35 Posted December 9, 2025 Thanks Cleat. The washers are NLA, found some NOS and have them coming. I have about 5 hours of seat time on the tractor, so here is a bit of an update/explanation for why I'm looking at the hydro controls: The engine runs fantastic after a good carb clean and replacement of all the ignition system components. Hard to believe this is a 2000 hour Onan. I will still plan on a proper reseal/valve adjustment/500+ hour service but this will require pulling the engine, so I'm going to let that go in order to tackle the more pressing needs of the machine. I do plan on an intake reseal before then just for peace of mind. The four areas that need attention: 1. Steering - extremely sloppy. Tie rod ends are shot, axle pivot is loose, steering gear backlash needs work. 2. Throttle cable creep. (Fixed) Removed the lever, drilled out the review, installed 1/4-20 bolt, washers, and nylock. 3. Charging system fault. Unit overcharges. Diagnosed the fault to be at the regulator output. Will replace regulator. For now, I have a Kohler regulator temporarily hooked up to keep everything stable. 4. Hydro leak. So far, the only leak I see is from the side of the case, below the fan where there looks to be a casting plug. Further analysis will require some deeper teardown. For now, though there is not any leak that is so massive that I could see it being responsible for the amount of debris that it had covering everything. I changed the fluid and filter (they had an automotive engine filter installed 😐). 5. Hydro creep/lack of top speed. Adjustment of the friction washers did not help. Found one broken friction washer. Plan is to rebuild the whole assembly. At 2000 hours, it's just all ready to be replaced anyway. I've taken it apart, cleaned and inspected, welded up some wear on the adjustment cam, and reinstalled. The spring washers aren't really a wear item, but it can't hurt to have new ones. Will plan on new rod ends for the linkage and new bushing for the lever pivot. Don't like the use of the nyliners, so depending on difficulty of access, I may elect for modification and an oilite bearing upgrade. It now can reach almost full travel on the cam plate and will hold lever position much better. Still a long way from being correct, but makes the unit much less annoying to drive. 6. Final electrical fixes. Deutsch plug for disconnecting engine from chassis. Get all dash lighting operational. Fix rear light fixtures. Lots to do, but it does run, drive, steer, stop and mow now. Shame the owner let it get this bad.😥 3 Share this post Link to post Share on other sites
ebinmaine 80,708 #36 Posted December 9, 2025 45 minutes ago, jsoluna said: Steering - extremely sloppy. Tie rod ends are shot, axle pivot is loose, steering gear backlash needs work. I'll have the tie rods. You're all set there. As far as the axle pivot, at the recommendation of others on Red Square I purchased a reamer a while back. If I recall correctly it goes to 7/8 inch so I buy bushings that are 7/8 by 3/4. Not sure if a 520 is the same. I believe so. The steering gear backlash, there are a couple of great threads here on Red Square about that repair. I can get them out of my notes and post them here later. 4 1 Share this post Link to post Share on other sites
Handy Don 17,474 #37 Posted December 9, 2025 4 hours ago, ebinmaine said: Not sure if a 520 is the same. 520 swept spindles are 1” but earlier versions are ¾”, yes. 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #38 Posted December 9, 2025 1 hour ago, Handy Don said: 520 swept spindles are 1” but earlier versions are ¾”, yes. Center pivot? Share this post Link to post Share on other sites
cleat 9,333 #39 Posted December 9, 2025 35 minutes ago, ebinmaine said: Center pivot? Front axle center pivot is 3/4 on all 520's just like the 300 and 400 series machines. Only the spindles went to 1" on 1990 and later 520's and on 1988,1989 520HC models. The 1988 and 1989 500 series outside of the HC models basically used the same front end as the 300 and 400 series machines. 2 1 Share this post Link to post Share on other sites
Handy Don 17,474 #40 Posted December 9, 2025 Thanks! 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #41 Posted December 9, 2025 8 hours ago, ebinmaine said: I can get them out of my notes and post them here later. Here ya go. Share this post Link to post Share on other sites
jsoluna 514 #42 Posted December 12, 2025 (edited) First video on the revival published today! Edited December 12, 2025 by jsoluna 3 Share this post Link to post Share on other sites
jsoluna 514 #43 Posted December 13, 2025 The steering and hydro controls are going to be the first two projects to tackle in earnest on this guy. It needs to be drivable so I can put a few hours behind it doing actual work to be able to determine its character and suitability for work. The steering, aside from being sloppy, turns probably 25% more to the right than left. Closer inspection reveals that the fan gear is moving fully in that direction but the quadrant that controls the steering links contacts the frame before full travel. Some research indicates I may have inherited one of the units with the fan gear and steering quadrant improperly oriented to each other from the factory. 😵💫 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #44 Posted December 13, 2025 9 hours ago, jsoluna said: fan gear and steering quadrant improperly oriented This is new to me. As you repair or modify I'd be interested to see pics... 1 Share this post Link to post Share on other sites
Ed Kennell 47,343 #45 Posted December 13, 2025 10 hours ago, jsoluna said: fan gear and steering quadrant improperly oriented I've had several projects that were sloppy enough that the steering gears would jump teeth on a hard steer. 2 1 Share this post Link to post Share on other sites
WHX?? 58,134 #46 Posted December 13, 2025 (edited) Having four working 520s & a parts tractor so following with interest. Doing outstanding work Luna and love your attitude about doing it right. I think the hardest part of a project like this is cleaning all the crap out. Edited December 14, 2025 by WHX?? 2 Share this post Link to post Share on other sites
jsoluna 514 #47 Posted December 14, 2025 (edited) 14 hours ago, ebinmaine said: This is new to me. As you repair or modify I'd be interested to see pics... Will do. Further inspection is required, but I do know that it was a problem on some of the later non-gear reduction steering units. It's significant enough that it kind of makes the tractor annoying to drive. Can't believe the owner lived with it like that. 13 hours ago, Ed Kennell said: I've had several projects that were sloppy enough that the steering gears would jump teeth on a hard steer. Luckily, the gear mesh is not that bad yet. I'll still adjust/remove shims on the support block for the secondary shaft and tighten up the nut on the pinion. Every little bit helps. 12 hours ago, WHX?? said: Having four working 520s & a parts travtor. so following with interest. Doing outstanding work Luna and love your attitude about doing it right. I think the hardest part of a project like this is cleaning all the crap out. Thanks for the encouragement. I've never had the time or money to really do one of these the way I would like to, but I do try to be as thorough as I can without grinding the project to a halt. It's a delicate balance. And yeah, I'm not a huge fan of all the cleaning that's required but it is so satisfying to see the end result - a machine you can see all the working parts on and be able to work on without getting covered in filth. Edited December 14, 2025 by jsoluna 2 Share this post Link to post Share on other sites
jsoluna 514 #48 Posted March 28 Back on th 520-H! Been a long winter and it's time to get this 2000 hour basket case to work! Tackling some of the outstanding issues that would cause to it to be a burden to use or otherwise be unreliable. The goals is to fix the major concerns, then put it to work this year taking care of my parent's place. After it proves itself this year, we will make some time to get more detailed with it next year. First step is the awful steering. Replaced the tie rod ends, which took up a significant amount of slop. The gear reduction system still needs shimmed/adjusted to get the rest of the play out, and the front axle will need reamed/bushed to take care of the negative camber issue. The larger issue that we are going to deal with later is the steering quadrant not being properly welded in respect to the main fan gear. We made temporary accommodations for this by adjusting the tie rod ends to balance the steering as best as possible. Video detailing some of our findings: 3 Share this post Link to post Share on other sites
lynnmor 9,040 #49 Posted March 28 3 hours ago, jsoluna said: First step is the awful steering. Replaced the tie rod ends, which took up a significant amount of slop. The gear reduction system still needs shimmed/adjusted to get the rest of the play out, and the front axle will need reamed/bushed to take care of the negative camber issue. You might find that the bulk of your steering wheel play can be adjusted in just a few minutes. There is a nut in front of the gears that takes a 3/4" wrench, remove the cotter pin and turn the nut in till the steering wheel just begins to bind and then back off just a bit. If the nut turns in so far that the cotter pin might not hold it, add a washer or two behind the nut. 2 1 1 Share this post Link to post Share on other sites
jsoluna 514 #50 Posted March 28 4 hours ago, lynnmor said: You might find that the bulk of your steering wheel play can be adjusted in just a few minutes. There is a nut in front of the gears that takes a 3/4" wrench, remove the cotter pin and turn the nut in till the steering wheel just begins to bind and then back off just a bit. If the nut turns in so far that the cotter pin might not hold it, add a washer or two behind the nut. I'll give that a shot before it gets loaded up! If it's that simple, it would be a shame not to give it a try. 1 Share this post Link to post Share on other sites
