Old Ron 1 #1 Posted 21 hours ago (edited) I have a Eaton Model 11 with water in the transmission. I have been filling with oil and installing a new filter, then running for a few minuets and draining. I have done this 3 times and oil still comes out cloudy. Anyone have any other suggestions? Edited 21 hours ago by Old Ron changed description Share this post Link to post Share on other sites
c-series don 10,660 #2 Posted 20 hours ago Jack up the front of the tractor so the front wheels are a foot or two off the ground while draining the oil out. There’s an internal hump in the transmission. Jacking it up will help get the oil over that hump. Also cycle the hydraulic cylinder a few times to help purge the hydraulic valve, lines, and cylinder of water. Do you have any pictures of your tractor? Those 400 series are some of my favorite WH’s ! I have a 416-H, 417-A, 418-C, 418-8, and a 420-LSE. 5 Share this post Link to post Share on other sites
JoeM 9,020 #3 Posted 20 hours ago Welcome Ron. It is real hard to get all of the old oil out of the Eaton 11 system. Is the oil just cloudy or is the pronounced water that comes out of the drain plug? Motor oils can take up to 1% water and retain their lubrication ability. I would not panic. Like HD says, the bulk of the oil is in the sump and filter and you have drained those. Some residual is in the charge circuit. One question is how long have you left the sump drain? If you raise the front of the machine up and leave it over night that will help the drain. If the oil is just cloudy it would be best to run it a few hour and preform a drain and refill. 5 Share this post Link to post Share on other sites
Dan 312-8 280 #4 Posted 20 hours ago 42 minutes ago, c-series don said: Jack up the front of the tractor so the front wheels are a foot or two off the ground while draining the oil out. There’s an internal hump in the transmission. Jacking it up will help get the oil over that hump. Also cycle the hydraulic cylinder a few times to help purge the hydraulic valve, lines, and cylinder of water. Do you have any pictures of your tractor? Those 400 series are some of my favorite WH’s ! I have a 416-H, 417-A, 418-C, 418-8, and a 420-LSE. @c-series don, the missing gem to your 418 trifecta! 1 Share this post Link to post Share on other sites
Old Ron 1 #5 Posted 20 hours ago Thanks for the info!!! The oil just looks cloudy. I will jack up the front end .. 1 Share this post Link to post Share on other sites
953 nut 62,530 #6 Posted 19 hours ago Not much I can add to what Joe and Don have said. Since oil floats on water it may be advisable to allow time for the two to separate prior to the next draining. This service manual for the Eaton1100 may be helpful. 2 Share this post Link to post Share on other sites
Ed Kennell 43,294 #7 Posted 19 hours ago to the Ron. How did water get in an Eaton hydro? Share this post Link to post Share on other sites
JoeM 9,020 #8 Posted 18 hours ago 23 minutes ago, Ed Kennell said: How did water get in an Eaton hydro? I am not sure about Ron but I left one out for 2 winters. I was out of room and figured those transmissions are sealed up pretty good. The snow and rain pooled around the fill tube and migrated into the case. I figure the heat cool cycles helped too. That was the only way I figured it got into the case. At work we had found pallets of oil that was contaminated with water. Found out the supply yard thought they could leave the 5 gallon cans out in the weather. Heating and cooling, the rain that was on top of the cans got sucked inside. Industrial CSI 2 1 1 Share this post Link to post Share on other sites
Handy Don 14,835 #9 Posted 18 hours ago (edited) 13 minutes ago, JoeM said: The snow and rain pooled around the fill tube and migrated into the case. I figure the heat cool cycles helped too. That was the only way I figured it got into the case. Another source is the vent in the fill tube handle allowing in/out movement of air (which always has moisture in it). Warm/cold cycle causes condensation. Edited 18 hours ago by Handy Don Share this post Link to post Share on other sites
kpinnc 15,912 #10 Posted 10 hours ago 11 hours ago, Old Ron said: Anyone have any other suggestions? All great suggestions here. One other thing is to make sure you get what is in the hydraulic lines, cylinder, and spool valve out. 1 Share this post Link to post Share on other sites
Handy Don 14,835 #11 Posted 6 hours ago (edited) 15 hours ago, Old Ron said: I have done this 3 times and oil still comes out cloudy. 3 hours ago, kpinnc said: One other thing is to make sure you get what is in the hydraulic lines, cylinder, and spool valve out. There is no easy way to get all the oil out of the charge pump, valve, hydraulic cylinder, and hoses/tubes because there is no good way to safely introduce air to replace it. The service manual assumes disassembly (which, for my money can cause more trouble that its worth). One thing I’ve used comes after as much oil as possible has been drained from the sump and the oil filter has been removed. Secure the tractor in the “nose up” position and manually exercise the hydraulic cylinder’s rod in and out while holding the control valve in the corresponding positions for lift and drop. This can force most of the oil out of the cylinder. Do this for two or three cycles or until no more oil comes out. Where does it come out? Out of the oil filter mount--so be prepared! Edited 6 hours ago by Handy Don 1 Share this post Link to post Share on other sites
