Old Ron 1 #1 Posted 4 hours ago (edited) I have a Eaton Model 11 with water in the transmission. I have been filling with oil and installing a new filter, then running for a few minuets and draining. I have done this 3 times and oil still comes out cloudy. Anyone have any other suggestions? Edited 4 hours ago by Old Ron changed description Share this post Link to post Share on other sites
c-series don 10,654 #2 Posted 3 hours ago Jack up the front of the tractor so the front wheels are a foot or two off the ground while draining the oil out. There’s an internal hump in the transmission. Jacking it up will help get the oil over that hump. Also cycle the hydraulic cylinder a few times to help purge the hydraulic valve, lines, and cylinder of water. Do you have any pictures of your tractor? Those 400 series are some of my favorite WH’s ! I have a 416-H, 417-A, 418-C, 418-8, and a 420-LSE. 3 Share this post Link to post Share on other sites
JoeM 9,016 #3 Posted 3 hours ago Welcome Ron. It is real hard to get all of the old oil out of the Eaton 11 system. Is the oil just cloudy or is the pronounced water that comes out of the drain plug? Motor oils can take up to 1% water and retain their lubrication ability. I would not panic. Like HD says, the bulk of the oil is in the sump and filter and you have drained those. Some residual is in the charge circuit. One question is how long have you left the sump drain? If you raise the front of the machine up and leave it over night that will help the drain. If the oil is just cloudy it would be best to run it a few hour and preform a drain and refill. 4 Share this post Link to post Share on other sites
Dan 312-8 280 #4 Posted 3 hours ago 42 minutes ago, c-series don said: Jack up the front of the tractor so the front wheels are a foot or two off the ground while draining the oil out. There’s an internal hump in the transmission. Jacking it up will help get the oil over that hump. Also cycle the hydraulic cylinder a few times to help purge the hydraulic valve, lines, and cylinder of water. Do you have any pictures of your tractor? Those 400 series are some of my favorite WH’s ! I have a 416-H, 417-A, 418-C, 418-8, and a 420-LSE. @c-series don, the missing gem to your 418 trifecta! 1 Share this post Link to post Share on other sites
Old Ron 1 #5 Posted 2 hours ago Thanks for the info!!! The oil just looks cloudy. I will jack up the front end .. 1 Share this post Link to post Share on other sites
953 nut 62,519 #6 Posted 2 hours ago Not much I can add to what Joe and Don have said. Since oil floats on water it may be advisable to allow time for the two to separate prior to the next draining. This service manual for the Eaton1100 may be helpful. 2 Share this post Link to post Share on other sites
Ed Kennell 43,287 #7 Posted 2 hours ago to the Ron. How did water get in an Eaton hydro? Share this post Link to post Share on other sites
JoeM 9,016 #8 Posted 1 hour ago 23 minutes ago, Ed Kennell said: How did water get in an Eaton hydro? I am not sure about Ron but I left one out for 2 winters. I was out of room and figured those transmissions are sealed up pretty good. The snow and rain pooled around the fill tube and migrated into the case. I figure the heat cool cycles helped too. That was the only way I figured it got into the case. At work we had found pallets of oil that was contaminated with water. Found out the supply yard thought they could leave the 5 gallon cans out in the weather. Heating and cooling, the rain that was on top of the cans got sucked inside. Industrial CSI 1 Share this post Link to post Share on other sites
Handy Don 14,830 #9 Posted 1 hour ago (edited) 13 minutes ago, JoeM said: The snow and rain pooled around the fill tube and migrated into the case. I figure the heat cool cycles helped too. That was the only way I figured it got into the case. Another source is the vent in the fill tube handle allowing in/out movement of air (which always has moisture in it). Warm/cold cycle causes condensation. Edited 1 hour ago by Handy Don Share this post Link to post Share on other sites
