Krice58 176 #1 Posted November 14, 2025 (edited) Any one know if the deck spindles are the same for the 42 and 48 inch SD mower deck. 42 inch (Model # 5-1011) is from ‘75 and the 48 inch is from ‘88 (Model # 0548SC01). They appear to be the same, the only difference I see is that the spindles from ‘88 have the grease fittings on top rather than underneath. My 42” deck is in poor condition but I wanted to salvage the spindles to keep as spares for my 48”. Edited November 14, 2025 by Krice58 Share this post Link to post Share on other sites
Krice58 176 #2 Posted November 14, 2025 1 hour ago, Krice58 said: Any one know if the deck spindles are the same for the 42 and 48 inch SD mower deck. 42 inch (Model # 5-1011) is from ‘75 and the 48 inch is from ‘88 (Model # 0548SC01). They appear to be the same, the only difference I see is that the spindles from ‘88 have the grease fittings on top rather than underneath. My 42” deck is in poor condition but I wanted to salvage the spindles to keep as spares for my 48”. I’ve checked multiple parts lists and there’s all kinds of updates and superseding numbers, so I’m a bit confused. Share this post Link to post Share on other sites
cleat 9,206 #3 Posted November 14, 2025 2 hours ago, Krice58 said: Any one know if the deck spindles are the same for the 42 and 48 inch SD mower deck. 42 inch (Model # 5-1011) is from ‘75 and the 48 inch is from ‘88 (Model # 0548SC01). They appear to be the same, the only difference I see is that the spindles from ‘88 have the grease fittings on top rather than underneath. My 42” deck is in poor condition but I wanted to salvage the spindles to keep as spares for my 48”. I know the later model 42 and 48 spindles are totally interchangeable. Those all have the grease fittings in the top of the spindle however. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #4 Posted November 14, 2025 If you look at the spindle identification charts the original spindle assembly for the 5-1011 was type K replaced by V, X and Z. The 05-48SC01 original spindle assembly was type Z. I would say it should work. 2 1 Share this post Link to post Share on other sites
Krice58 176 #5 Posted November 14, 2025 59 minutes ago, gwest_ca said: If you look at the spindle identification charts the original spindle assembly for the 5-1011 was type K replaced by V, X and Z. The 05-48SC01 original spindle assembly was type Z. I would say it should work. Thanks for the chart. Very helpful Share this post Link to post Share on other sites
Krice58 176 #6 Posted November 14, 2025 What would go into rebuilding those if needed? I would imagine just bearings if the housing and shaft aren’t destroyed. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #7 Posted November 14, 2025 If you want to look at the illustrations the 5-1011 shows them all on two pages. Click on the fuzzy picture in this link to view. Then click on the small thumbnails to enlarge. Nothing to download. 1 Share this post Link to post Share on other sites
Lee1977 7,750 #8 Posted November 14, 2025 (edited) Looks like both have metric spindles. The metric spindles have a 5/8" nut on top holding the pulley with 17 mm spindle with 6203 bearings 40mm OD, 17 mm ID, 12 mm thick bearings with a 3/4" nut holding the blade. Edited November 14, 2025 by Lee1977 2 Share this post Link to post Share on other sites
peter lena 10,013 #9 Posted November 15, 2025 @Krice58 think the most important thing you can do to a deck bearing is to carefully remove the grease shields , clean them out , carb cleaner , repack with lucas green chassis grease , all my decks and mule drive bearings are 6203 ( 3/4 ) 2rsc3 , 550 deg , flash point , polyurea rated lubricant is the exact grease you want for stress and heat . imagine , no bearing whine , remove spindle inner bearing grease shield , the difference in , spindle running ease , is amazing , also detail in the pto lever shaft start , side of battery tray , basically washer up the sloppy starting area , added a heim joint to forward end , replaced the sloppy trundle set up . just some ideas , pete 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #10 Posted December 28, 2025 I know this is an old thread, but I was wondering if 36” RD and 42” RD spindles were interchangeable? Thanks Share this post Link to post Share on other sites
kpinnc 18,884 #11 Posted December 29, 2025 18 hours ago, Easton Rich said: know this is an old thread, but I was wondering if 36” RD and 42” RD spindles were interchangeable? Thanks At least the ones I have seen, they are not interchangeable. The 36 inch deck spindles are much shorter (pulley to blade) than the 42 and 48 inch. Not sure about the bolt pattern. Share this post Link to post Share on other sites
Brockport Bill 2,454 #12 Posted December 29, 2025 18 hours ago, Easton Rich said: I know this is an old thread, but I was wondering if 36” RD and 42” RD spindles were interchangeable? Thanks the 36 spindle is notably "shorter" - considerably different spindle housing unit than the 42/48 - i am rehabbing a 36 deck now - - here is photo of the 3 housings Share this post Link to post Share on other sites
peter lena 10,013 #13 Posted December 30, 2025 @Krice58 personally think the most important part of any pulley is the lubrication , thats your failure point , you don't know wat it is , but probably on the cheapest / minimal service side of the chart . never had a failure or WHYINING NOISE , from any of my spindle bearings , with lucas x tra hd green chassis grease , that 550 deg drop point alone , tells you this is serious stuff , polyurea rated ? anti sling , so it stays with the bearing , also always go for , where available , is wide pop off grease side shields , easily removed , wipe out , carb cleaner , flush, re pack with lucas , every ROTATIONAL STAGE OF MY PTO DRIVE , HAS THIS LUBE, no screaming clutch , just smooth easy spin up , have never burned up a clutch unit , what does that tell you about lubrication ? often refer to moving my pto mule drive belt by hand ? only a suggestion , most of the stuff i see is a wreck , pete Share this post Link to post Share on other sites
groundhog47 448 #14 Posted December 30, 2025 On 11/14/2025 at 11:37 AM, Krice58 said: Any one know if the deck spindles are the same for the 42 and 48 inch SD mower deck. 42 inch (Model # 5-1011) is from ‘75 and the 48 inch is from ‘88 (Model # 0548SC01). They appear to be the same, the only difference I see is that the spindles from ‘88 have the grease fittings on top rather than underneath. My 42” deck is in poor condition but I wanted to salvage the spindles to keep as spares for my 48”. If not already mentioned the younger spindles went metric blade shaft. I believe pulley bore and keyway only was affected. In my pictures it appears blade nuts and bearing are 3/4". If memory serves me the 48" and 42" have different diameter drive pulleys also metric or standard. Share this post Link to post Share on other sites
groundhog47 448 #15 Posted December 30, 2025 @Lee1977 Appears I stepped on your reply, apologies. Share this post Link to post Share on other sites
