tstab 2 #1 Posted November 11, 2025 Hey all, curious if anyone knew any specs about this lift bar fo the 6-71-21 Dozer Blade. I managed to track one down for my charger 8 but it did not come with the lift bar. I know the part number is Toro 104003 but idk anything about length or what it actually looks like outside of the diagram. I'm trying to avoid making one so if anyone has one I can buy or if you know if there is one that will work on wheel horse parts give me a hollar. I know I can fab one up but I just am very limited on (reno'ing my house) Share this post Link to post Share on other sites
rlrnot 39 #2 Posted November 17, 2025 I believe I have what you need. My manual lists it as Item #8172. I can get you the dimensions if you would like or you can have this one (It has been modified but is functional). The issue is I don't know how to get it to you. I am in NE Ohio. I had this blade on my Charger 8 and then modified it to fit my 310-8. Be glad to help any way I can. Share this post Link to post Share on other sites
tstab 2 #3 Posted November 17, 2025 (edited) Thanks! Im originally from Lodi actually, my parents live in Wadsworth. I don’t want to inconvenience ya in figuring out to send it. I am open to maybe working something out around the holiday but if you could send me the dimensions that would be cool because then maybe I could just cross reference it was something on eBay to make everybody’s life easier lol I appreciate your response. I just didn’t know if there was like an offset because I think it’s slightly bent, but I’m not sure. I have a charger 8 that I wanna push some stuff around with this winter so trying to get it lined up I missed out last year. Edited November 17, 2025 by tstab Share this post Link to post Share on other sites
rlrnot 39 #4 Posted November 17, 2025 Just to verify, this refers to Item # 28 in the manual. 1 1/2 by 3/8 bar stock. OAL = 22 7/8. All dimensions are from end with (2) 27/64 holes. 23/32 to ctr. of first hole. 1 11/32 to ctr. of second hole. 21 27/32 to ctr. of 11/16 hole. My bar is straight. I think this gives you the dimensions you need. If not, let me know. Share this post Link to post Share on other sites
peter lena 9,715 #5 Posted November 17, 2025 @tstab your squeeze lever , blade swing control , operates the SWING QUADRANT PIN , and related spring , that spring runs the entire movement cycle ? # 22 bolt , changed to a shoulder bolt and elastic Lok nut , lets you dial in exact , squeeze , pull / push right hand swing action . also like red aerosol grease at every movement stage . sounds like a rifle bolt . plows are a gold mine for correction / improvement , lots to do and relatively easy , pete Share this post Link to post Share on other sites
tstab 2 #6 Posted November 17, 2025 Thanks so much @rlrnot ! I'll see if I can cook one up . You are a lifesaver! Thanks for the advice @peter lena! Share this post Link to post Share on other sites
peter lena 9,715 #7 Posted November 17, 2025 @tstab done a number of plows , mower decks , blowers , always removing / improving failure areas . trying to find my original write up / picture reference . another thing I suggest is to use a bench or roller stool , so you can easily verify what's going on , when you are comfortably looking at / for a problem its easier then standing on your head . found one , functional detailing , makes every stage smooth / solid / easy . first picture insures smooth / easy lever work . shoulder bolt in that , lets you dial in a perfect swing . pete Share this post Link to post Share on other sites
