1987_WHEEHORSE312 79 #1 Posted November 3, 2025 So i need a bit of advice. My 312 ran great when I got it, put about 3 hours on it, and it seem to be running a little rough and dies off during an idle. Spark plug was shot, replaced it, replaced fuel filter, and air cleaner comes tomorrow. What else can I do, I dont have a shop yet or my tools at my house to tear the carb down, though it does run fine alot of the time. Has the original Kohler in it. May I also add I just bought it, ran through the gas that was in it, and then filled it up with fresh gas that I purchased a week ago, and filled my car up and the gas can at the same time. Share this post Link to post Share on other sites
kpinnc 16,514 #2 Posted November 3, 2025 If the plug was shot be sure and clean any corrosion from the plug wire. If your tractor is a 1987 with a Kohler it is likely a Magnum with magneto ignition. It works well and is far simpler than the older coil and points ignition. Can't speak for the weather where you are, but here in NC condensation is pretty rough. As such, I regularly drop the sediment bowl on the carb to clear any water or trash that accumulates there. From what I've seen, tractors with plastic fuel tanks are more prone to getting nasty at the carb bowl. Also, if replacing any fuel line, you're better off replacing all of it. And also ethanol free fuel will make your life easier. I know some will argue that they use ethanol all the time, but it draws moisture and has a much shorter shelf life than ethanol free. I never put ethanol in anything with a carburetor. Good luck! 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #3 Posted November 3, 2025 1 minute ago, kpinnc said: If the plug was shot be sure and clean any corrosion from the plug wire. If your tractor is a 1987 with a Kohler it is likely a Magnum with magneto ignition. It works well and is far simpler than the older coil and points ignition. Can't speak for the weather where you are, but here in NC condensation is pretty rough. As such, I regularly drop the sediment bowl on the carb to clear any water or trash that accumulates there. From what I've seen, tractors with plastic fuel tanks are more prone to getting nasty at the carb bowl. Also, if replacing any fuel line, you're better off replacing all of it. And also ethanol free fuel will make your life easier. I know some will argue that they use ethanol all the time, but it draws moisture and has a much shorter shelf life than ethanol free. I never put ethanol in anything with a carburetor. Good luck! Hey I appreciate it! When I changed the filter out and the shut off, I looked the the line and it looks newer and isnt super hard. Ill pull and clean the bowl out and someone suggested I run seafoam through it Share this post Link to post Share on other sites
squonk 45,059 #4 Posted November 3, 2025 If it's a Magnum have seen a lot of crazy issues with the coil. A lot of them act like a fuel issue but it's the weak coil. Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #5 Posted November 3, 2025 1 minute ago, squonk said: If it's a Magnum have seen a lot of crazy issues with the coil. A lot of them act like a fuel issue but it's the weak coil. Are new coils easy to find? Im gonna do a fuel system treatment first just to see, cause it runs find at a higher idle Share this post Link to post Share on other sites
squonk 45,059 #6 Posted November 3, 2025 I never needed to buy one but other members have had coil issues. @Racinbob 1 Share this post Link to post Share on other sites
Racinbob 12,503 #7 Posted November 3, 2025 I purchased a mint 314-H 100 hour unit that gave me fits. Seemingly it was an obvious fuel issue. Like clockwork it would shut down as my wife was mowing. I replaced everything fuel related, rebuilt the Welbro carb twice and then replaced it, electric fuel pump. Didn't change a thing. I put a muffler 'test pipe' on it. I was hesitant to go with a coil because I had only checked for an oem coil at well over 2 bills. Not something I wanted to try as a test. Then I found a knock off coil and tried it. BINGO! I had tested the original coil and it tested good. The heat build up apparently did the number to it. 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #8 Posted November 3, 2025 56 minutes ago, Racinbob said: I purchased a mint 314-H 100 hour unit that gave me fits. Seemingly it was an obvious fuel issue. Like clockwork it would shut down as my wife was mowing. I replaced everything fuel related, rebuilt the Welbro carb twice and then replaced it, electric fuel pump. Didn't change a thing. I put a muffler 'test pipe' on it. I was hesitant to go with a coil because I had only checked for an oem coil at well over 2 bills. Not something I wanted to try as a test. Then I found a knock off coil and tried it. BINGO! I had tested the original coil and it tested good. The heat build up apparently did the number to it. Interested, im gonna try seafood when I mow in a week or two and see what that does. If that doesnt work ill tackle the coil Share this post Link to post Share on other sites
953 nut 63,547 #9 Posted November 4, 2025 1 hour ago, 1987_WHEEHORSE312 said: gonna try seafood when I mow Not too sure that will make the engine run any better but I'm always in favor of seafood. 4 Share this post Link to post Share on other sites
Bar Nuthin 2,041 #10 Posted November 4, 2025 1 hour ago, 1987_WHEEHORSE312 said: gonna try seafood when I mow Autocorrect can be your worst enema. 4 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #11 Posted November 4, 2025 18 hours ago, Racinbob said: I purchased a mint 314-H 100 hour unit that gave me fits. Seemingly it was an obvious fuel issue. Like clockwork it would shut down as my wife was mowing. I replaced everything fuel related, rebuilt the Welbro carb twice and then replaced it, electric fuel pump. Didn't change a thing. I put a muffler 'test pipe' on it. I was hesitant to go with a coil because I had only checked for an oem coil at well over 2 bills. Not something I wanted to try as a test. Then I found a knock off coil and tried it. BINGO! I had tested the original coil and it tested good. The heat build up apparently did the number to it. Interesting. Ill have to keep an eye on it. Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #12 Posted November 4, 2025 16 hours ago, 953 nut said: Not too sure that will make the engine run any better but I'm always in favor of seafood. Seafoam, though a lobster tail wouldn't be a bad option either 🤣🤣 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #13 Posted November 4, 2025 16 hours ago, Bar Nuthin said: Autocorrect can be your worst enema. 🤣🤣 1 Share this post Link to post Share on other sites
peter lena 9,642 #14 Posted November 4, 2025 @953 nut https://www.google.com/search?q=seattle+fish+market+throwing&rlz=1C1CHBF_enUS866US866&oq=seattle+fish+&gs_lcrp=EgZjaHJvbWUqBwgFEAAYgAQyCggAEAAY4wIYgAQyBwgBEC4YgAQyBggCEEUYOTINCAMQLhivARjHARiABDINCAQQLhivARjHARiABDIHCAUQABiABDIHCAYQABiABDINCAcQLhivARjHARiABDIHCAgQABiABDIHCAkQLhiABNIBCTE3ODUwajBqNKgCAbACAfEFvk_42bGC4zLxBb5P-NmxguMy&sourceid=chrome&ie=UTF-8 ever been in seattle ? incrediable alsakan fish sorting spot , also boeing aircraft factory tour , the chinese food area , wear loose clothes , it helps , space needle , pete 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #15 Posted November 6, 2025 ***Update*** Sprayed seafoam in intake, put some in gas take and performed a slight adjustment to my idle screw and main throttle screw on the carb and she runs perfect! 1 1 Share this post Link to post Share on other sites
peter lena 9,642 #16 Posted November 6, 2025 @ e312 , that sounds like a REPEDITIVE something that you should regularly do ! simple as it sounds , regularly try experiments with anything issues , thats how you can really dial in reliability , and minimal issues . years back had regular fuel related problems , commonality was fuel hose break down , clogged filters . cleaned out tank , add filter at tank , all new hoses , another filter close to carb , also started using , STA,BIL fuel storage treatment , ounce or two , to every tank top off . never had another fuel related anything on my 3 horses . another glairing gain is that all my fuel filters and fuel bowls , are clean/ clear . just started up stand by generator , instant start , clean fuel bowl . regularly suggest this , because its been bombproof , another thing I don't have issues with is spark plugs . only suggest what has been consistently working for me . pete Share this post Link to post Share on other sites
