RJR49 179 #1 Posted November 1, 2025 I have a 1975 C-160. Points, plugs, and a condenser. Runs great. That's what i grew up with. My brother gave me his 1977 C-160. No spark, but no points either! Any advise from you younger guys would be appreciated Share this post Link to post Share on other sites
ebinmaine 80,713 #2 Posted November 1, 2025 Same engine. Both had points. Can you post pics or engine numbers from the 77? Share this post Link to post Share on other sites
702854boy 1,149 #3 Posted November 1, 2025 Thats the breaker less style of ignition so ot doesn't have points but I've seen on here that if it works, its great, but once they fail its better to just convert it over to a points style. I think @Handy Don might be able to help but I don't remember exactly who all ive seen post this. Share this post Link to post Share on other sites
702854boy 1,149 #4 Posted November 1, 2025 I guess @ebinmaine has more knowledge and faster fingers than me Share this post Link to post Share on other sites
RJR49 179 #5 Posted November 1, 2025 Is there any way to test this? It has a coil, and plug. I tested the plug wire but I'm not sure about testing the coil. I'll probably use the one on the 1975. I know it's good Share this post Link to post Share on other sites
ebinmaine 80,713 #6 Posted November 1, 2025 15 minutes ago, 702854boy said: I guess @ebinmaine has more knowledge and faster fingers than me Kohler 16 HP had points from 1973 to the mid 80s. 9 minutes ago, RJR49 said: Is there any way to test this? It has a coil, and plug. I tested the plug wire but I'm not sure about testing the coil. I'll probably use the one on the 1975. I know it's good Pics of the existing coll? Share this post Link to post Share on other sites
RJR49 179 #7 Posted November 1, 2025 I'm wondering what you guys think of this? Share this post Link to post Share on other sites
ebinmaine 80,713 #8 Posted November 1, 2025 1 minute ago, RJR49 said: I'm wondering what you guys think of this? I dunno if that fits any Kohler.... .. But you should diagnose the existing issue before attempting modification. Share this post Link to post Share on other sites
oliver2-44 11,753 #9 Posted November 1, 2025 It sound like the 77 has a Kohler Magnum engine which would have the breaker less electronic ignition. You can or put the coil from the 75 on it. The Kohler manual has testing instruction for the breakeless ignition. Make sure you do not connect any 12v power to the breaker less coil or trigger. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #10 Posted November 1, 2025 1 hour ago, 702854boy said: Thats the breaker less style of ignition so ot doesn't have points but I've seen on here that if it works, its great, but once they fail its better to just convert it over to a points style. I think @Handy Don might be able to help but I don't remember exactly who all ive seen post this. Sorry, haven’t yet had to do a conversion! Share this post Link to post Share on other sites
702854boy 1,149 #11 Posted November 1, 2025 32 minutes ago, Handy Don said: Sorry, haven’t yet had to do a conversion! No problem, I couldn't remember exactly who I'd seen talk about it but for some reason your name rang a bell. Share this post Link to post Share on other sites
Racinbob 13,192 #12 Posted November 1, 2025 Through the years we've only had one with the breakerless. It was a Raider 12. Never had any trouble with it but.............. 1 Share this post Link to post Share on other sites
Racinbob 13,192 #13 Posted November 1, 2025 10 hours ago, RJR49 said: I'm wondering what you guys think of this? Those are coil packs. I kinda doubt it. Nova has/had a points eliminator. I had a couple but it's my understanding that they won't work on a battery ignition. 1 1 Share this post Link to post Share on other sites
953 nut 69,326 #14 Posted November 1, 2025 12 hours ago, RJR49 said: I have a 1975 C-160. Points, plugs, and a condenser. Runs great. That's what i grew up with. My brother gave me his 1977 C-160. No spark, but no points either! Any advise from you younger guys would be appreciated Is the engine a Kohler? Some 1977 C-160s has Onan engines. What are the engine SPEC numbers on your engine ( should be 711128 ) and the engine from your brother's "77 C-160? The engine in your brother's may not be the engine the tractor was built with. Knowing the Kohler Spec number will allow you to find out what ignition system the engine has. Share this post Link to post Share on other sites
ebinmaine 80,713 #15 Posted November 1, 2025 51 minutes ago, 953 nut said: Kohler? Some 1977 C-160s has Onan engines. C160 was made 1974 - 1977. 1974 had either the not so common Tecumseh OHV160 in C160-8 tractors only, or the Kohler in either automatic or manual transmission. To the best of my knowledge ALL 1975 76 77 C160-8 and C160 Automatic were built with the Kohler K341.. Share this post Link to post Share on other sites
RJR49 179 #16 Posted November 1, 2025 Seems like I made a mistake. It looks like this one does have points. Share this post Link to post Share on other sites
RJR49 179 #17 Posted November 1, 2025 I guess that the easiest thing todo is replace that points and condenser. Probably the coil too Share this post Link to post Share on other sites
ebinmaine 80,713 #18 Posted November 1, 2025 2 hours ago, RJR49 said: I guess that the easiest thing todo is replace that points and condenser. Probably the coil too My advice would be to determine the EXACT issue. CLEAN the points first. See if it runs. At that point determine if the points NEED replacement. ... or just leave as is. My experience shows me that the original stock parts are likely better than most modern pieces. 2 1 Share this post Link to post Share on other sites
RJR49 179 #19 Posted November 1, 2025 They're probably not original but I'll try that first. Do you know how to test the cap & coil? I can "borrow" them from my 75 but I've always been curious about testing. Share this post Link to post Share on other sites
RJR49 179 #20 Posted November 1, 2025 Ebinmaine you've done it again! The points are Kohler and not in bad shape. Especially, since the rubber gasket was not in place. But taking you're advise i cleaned the points. Sprayed some starting fluid in the carb and it started. I let it run for a while then shut it off. Tried again and it fired right up without the starting fluid! Tomorrow I'll tighten the tow valve and see what happens when I try to move it. 3 Share this post Link to post Share on other sites
