Mike'sHorseBarn 3,711 #1 Posted September 7, 2025 Weird issue. It has neutral meaning I take it out of gear and let the clutch out and it won't go anywhere, but if i shut it off and try to push the tractor it won't free wheel. What's the deal? Share this post Link to post Share on other sites
peter lena 10,118 #2 Posted September 7, 2025 @ MIKES HORSE BARN, what does the trans oil look like ? milky ? when was it last serviced ? pete Share this post Link to post Share on other sites
Ed Kennell 47,866 #3 Posted September 8, 2025 Is the brake dragging? 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,711 #4 Posted September 8, 2025 27 minutes ago, peter lena said: @ MIKES HORSE BARN, what does the trans oil look like ? milky ? when was it last serviced ? pete I just flushed it and drained what was in there, didn't have much in it. 17 minutes ago, Ed Kennell said: Is the brake dragging? Brake does not seem to be dragging i checked that. Share this post Link to post Share on other sites
JoeM 10,318 #5 Posted September 8, 2025 Have you jacked it up and spun the back tires by hand. Think a final drive bolt sheared and is dragging. just thinking. 4 Share this post Link to post Share on other sites
ebinmaine 81,220 #6 Posted September 8, 2025 8 hours ago, Mike'sHorseBarn said: Weird issue. It has neutral meaning I take it out of gear and let the clutch out and it won't go anywhere, but if i shut it off and try to push the tractor it won't free wheel. What's the deal? Does it run and drive fine otherwise? Clicking on sharp turns? When OFF does pushing the clutch make a difference? Or brake? Does selecting Hi vs Low change it? Different gears? Have you tried coaxing it with a carrot 🥕? 3 Share this post Link to post Share on other sites
Pullstart 71,538 #7 Posted September 8, 2025 Does it need a turbo? 2 3 1 Share this post Link to post Share on other sites
953 nut 70,541 #8 Posted September 8, 2025 Are the tires fully inflated? Pushing backward the same as forward? Share this post Link to post Share on other sites
Mike'sHorseBarn 3,711 #9 Posted September 8, 2025 6 hours ago, ebinmaine said: Does it run and drive fine otherwise? Clicking on sharp turns? When OFF does pushing the clutch make a difference? Or brake? Does selecting Hi vs Low change it? Different gears? Have you tried coaxing it with a carrot 🥕? It does run and drive fine, which is the weird part. Pushing the clutch makes Zero difference in free wheeling same with brake. If I take the brake band off though I can free wheel it like it's in gear and the drive pulley spins like it's in gear, but If I start it in neutral and let the clutch out, it won't move like it's actually in neutral, but it won't free wheel. Weird. Next step may be coaxing it with a different trans until I can tear into this one lol Share this post Link to post Share on other sites
Mike'sHorseBarn 3,711 #10 Posted September 8, 2025 4 hours ago, 953 nut said: Are the tires fully inflated? Pushing backward the same as forward? Yes to both 1 Share this post Link to post Share on other sites
stevasaurus 23,890 #11 Posted September 8, 2025 It sounds to me like some teeth from either the axke gear(s) or from one or more of the pinions in the differential have chipped off and causing your issue. Jack up the rear end and try turning each wheel one at a time). 1 Share this post Link to post Share on other sites
ri702bill 13,350 #12 Posted September 8, 2025 4 hours ago, stevasaurus said: It sounds to me like some teeth from either the axke gear(s) or from one or more of the pinions in the differential have chipped off and causing your issue. Jack up the rear end and try turning each wheel one at a time). If it time to change the fluid, you can confirm what Steve said. Inspect the used fluid that comes out - look for shiny bits of gear teeth that have left home for good... 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,711 #13 Posted September 8, 2025 2 hours ago, ri702bill said: If it time to change the fluid, you can confirm what Steve said. Inspect the used fluid that comes out - look for shiny bits of gear teeth that have left home for good... I did change the fluid, it has such a horrendous leak that it had next to no fluid in it. Anyway ya look at it, I gotta take it apart. 3 1 Share this post Link to post Share on other sites
stevasaurus 23,890 #14 Posted September 9, 2025 Mike. just for kicks what horse or what 8 speed trans do you think we have here?? I'm wondering if this is a 10 pinion differential with a brokem spring. 1 Share this post Link to post Share on other sites
Handy Don 17,708 #15 Posted September 9, 2025 1 hour ago, stevasaurus said: Mike. just for kicks what horse or what 8 speed trans do you think we have here?? I'm wondering if this is a 10 pinion differential with a brokem spring. Ah, a locked differential! Share this post Link to post Share on other sites
Mike'sHorseBarn 3,711 #16 Posted September 9, 2025 2 hours ago, stevasaurus said: Mike. just for kicks what horse or what 8 speed trans do you think we have here?? I'm wondering if this is a 10 pinion differential with a brokem spring. This is a 1974 C-160 with the 5091 trans 1 Share this post Link to post Share on other sites
ebinmaine 81,220 #17 Posted September 9, 2025 1 hour ago, Mike'sHorseBarn said: This is a 1974 C-160 with the 5091 trans So that should be an eight pinion 1 1 1 Share this post Link to post Share on other sites
953 nut 70,541 #18 Posted September 9, 2025 6 hours ago, stevasaurus said: Mike. just for kicks what horse or what 8 speed trans do you think we have here?? I'm wondering if this is a 10 pinion differential with a brokem spring. I thought only the six speeds had the limited slip differentials. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,220 #19 Posted September 9, 2025 4 minutes ago, 953 nut said: I thought only the six speeds had the limited slip differentials. 6 speeds and some early 1970s hydros. My '70 Charger had it. Anything could have been done by a PO. Limited Slip Differential can be retrofitted to an 8 speed. Share this post Link to post Share on other sites
953 nut 70,541 #20 Posted September 10, 2025 12 hours ago, ebinmaine said: 6 speeds and some early 1970s hydros. My '70 Charger had it. Anything could have been done by a PO. Limited Slip Differential can be retrofitted to an 8 speed. As could a four pinion. 1 Share this post Link to post Share on other sites
ebinmaine 81,220 #21 Posted September 10, 2025 3 minutes ago, 953 nut said: As could a four pinion. If the axle sizes match up, absolutely. Share this post Link to post Share on other sites
stevasaurus 23,890 #22 Posted September 10, 2025 The 5060 and the 5071 are considered 6 speed...where brake shaft is mushroom gear. The 5073 is an 8 speed 10 pinion limited slip...brake shaft on cluster gear shaft.. @953 nut The 3 speed and the 4 speed transmissions all are 4 pinion differentials with 1" axles. Even the #110996 in the 300 & 400 series is a 4 pinion differential with 1" axles and this is an 8 speed. 1 Share this post Link to post Share on other sites
ebinmaine 81,220 #23 Posted September 10, 2025 3 minutes ago, stevasaurus said: The 5073 is an 8 speed 10 pinion limited slip...brake shaft on cluster gear shaft.. 1970, 71? Share this post Link to post Share on other sites
stevasaurus 23,890 #24 Posted September 10, 2025 On 9/8/2025 at 10:35 AM, Mike'sHorseBarn said: It does run and drive fine, which is the weird part. Pushing the clutch makes Zero difference in free wheeling same with brake. If I take the brake band off though I can free wheel it like it's in gear and the drive pulley spins like it's in gear, but If I start it in neutral and let the clutch out, it won't move like it's actually in neutral, but it won't free wheel. Weird. Next step may be coaxing it with a different trans until I can tear into this one lol This is the part I am having trouble with. It runs and drives fine, but if I start it in neutral and let the clutch out, it won't move. BOTH OF THESE CAN NOT BE TRUE. Further explaination is in order here.. 1 Share this post Link to post Share on other sites
stevasaurus 23,890 #25 Posted September 10, 2025 @ebinmaine Eric, the list with all the years of Wheel Horse model numbers, engine numbers and transmissions is wrong where you are reading it. The #5060 and the #5071 transmissions are the 6 speeds, 10 pinion differentials with 1 1/8" axles...brake drum on the mushroon gear shaft. The #5073 is the 8 speed 10 pinion differential with 1 1/8" axles...brake drim on the cluster gear shaft. Look here my friend...table of contents. 1 Share this post Link to post Share on other sites
