608KEB 812 #1 Posted September 5, 2025 (edited) Will a mid-mount grader blade work to tear up weeds and restore gravel on a gravel parking lot? The area is getting some grass on it. Edited September 5, 2025 by 608KEB 1 Share this post Link to post Share on other sites
ebinmaine 77,974 #2 Posted September 5, 2025 19 minutes ago, 608KEB said: Will a mid-mount grader blade work to tear up weeds and restore gravel on a gravel parking lot? The area is getting some grass on it. Done with patience and proper methods... yes. Share this post Link to post Share on other sites
lynnmor 8,700 #3 Posted September 5, 2025 You would have better results if you could loosen the surface first with workers or a harrow. Depending on how firm the surface is it can be impossible to grade. 2 Share this post Link to post Share on other sites
953 nut 64,846 #4 Posted September 5, 2025 2 hours ago, 608KEB said: grader blade It is a grader blade, not an excavator. Once it has been loosened the blade will grade it smooth. A subsoiler may be able to break it loose. Share this post Link to post Share on other sites
ebinmaine 77,974 #5 Posted September 5, 2025 18 minutes ago, lynnmor said: if you could loosen the surface first We've considered having a grader blade with a row of "teeth". Perhaps a separate bolt on 🔩 edge. Not sure on tooth count. Maybe less is better......? 1 Share this post Link to post Share on other sites
Lee1977 7,629 #6 Posted September 6, 2025 (edited) I have used my home built pulverizer on my gravel drive to get the grass out. It's still a tough job, as you still have to seperate the grass from the gravel. Best to kill the grass before trying to remove it. Edited September 6, 2025 by Lee1977 3 2 Share this post Link to post Share on other sites
8ntruck 8,700 #7 Posted September 6, 2025 3 hours ago, ebinmaine said: We've considered having a grader blade with a row of "teeth". Perhaps a separate bolt on 🔩 edge. Not sure on tooth count. Maybe less is The county uses dump trucks with belly blades to grade the gravel roads around here. Some of them have a cutting edge on them with"teeth" - serrations like 60 degree triangles maybe 1 1/2" on a side. 1 Share this post Link to post Share on other sites
ri702bill 11,617 #8 Posted September 6, 2025 I made up a short scarifier to fit my 42" WH plow. When not in use, it flips up out of the way... 4 Share this post Link to post Share on other sites
squonk 45,892 #9 Posted September 6, 2025 The biggest issue with the WH mid graders is the fact it's pretty light weight. They want to skid more than dig. You need a solid lift link and you just about have to stand on the top edge. You need something heavy with teeth. 4 Share this post Link to post Share on other sites
kpinnc 17,580 #10 Posted September 6, 2025 (edited) 12 hours ago, squonk said: The biggest issue with the WH mid graders is the fact it's pretty light weight. They want to skid more than dig. You need a solid lift link and you just about have to stand on the top edge. You need something heavy with teeth. Or you can find an old worn out commercial scrape blade and cut you a thick one from the wear bar. This one weighs about 80lbs. Got mine from Don @Lee1977 and fabbed the rest. It will spin the tires on the tractor without jumping just because of the weight. Edited September 6, 2025 by kpinnc 2 4 Share this post Link to post Share on other sites
top_cat 41 #11 Posted September 8, 2025 I've got a 600 foot gravel drive. Over the years I tried a box scraper, grader blade, drag and other ways to get rid of the weeds and level it. I finally bought a DR Power Equipment power grader. I've used it for the last 8 years with great results. I let 2 of my friends try it and they both bought one. Fist thing to do is go to your local farm store a get a commercial weed killer and spray the area to kill the roots, then grade and roll the gravel, I use my C-101 with no problems. After a couple of uses, you'll have a new parking area. Not cheap but do yourself a favor, go to the website and watch the video. Share this post Link to post Share on other sites
