Pullstart
Back Yard Pool Project
Pullstart
Pictures of my “lawn” coming in.  Yes, we did pick up about 100 square foot of free sod, so there is some new grass between the driveway and concrete.
  • Sad 1
SylvanLakeWH
The seed will grow... just gotta keep it wet, always... I seeded a huge area of former wood chips... lousy soil prep... kept it wet, its completely covered now...
:twocents-twocents:
Pullstart
I like quick improvements I suppose.  Top exterior piping is finished and in the paint booth.  We used this same paint to refinish the diving board.  If it’s not 100% match to the shed, it’ll match something at least!
Pullstart
I’m sure I’ve mentioned this, but there is a valve that I will be able to control how much water goes to the roof, how much simply returns to the pool.  The supply pipe will feed the bottom of the manifold and has a 2” check valve as well, to keep the system full.  Winterizing plans will include this tee to drain the system, and I’ll be able to blow air into the rest to empty the majority.  RV antifreeze will be strategically pumped in to prevent any freezing from possible condensate entry too.
953 nut
Kevin, I know you have a well deserved reputation for being an accident looking for a place to happen,  BUT     :confusion-shrug:     do you need five wheel chairs?   :ychain:
  • Haha 4
Pullstart
I got in the pool yesterday for the first time all year.  Not due to temperature or lack of, but lack of time it seems.  The solar cover is doing a good job keeping temp in on the cool nights and keeping evaporation down during the day.  The issue with the cover however, is it needs attached to the roller for one person operation.  Yesterday I layer out my center, marked every two feet, and have 10 new straps on the way to span between the 18 foot of roller.  I masking taped the cover to the roller for concept and was able to roll it up effortlessly.  After Jada cut the new cover square, of course.
Pullstart
Oh, and the solar panel on the roof is pumping the heat out well!  It was fun to feel the difference in the jet areas vs the non-jet areas.
  • Heart 1
Pullstart
1 long year this project has been going on.  Our pool liner came today.  The company cut out the old one, and left for the day so I can dig up that pipe I buried a year ago.  Except it’s not exactly where I thought it was.  The light niche developed a leak and we were having a hard time keeping water levels up.  My new pump burned up after about 38 or more hours of dry run time when I was out of town flying pigs.
  • Sad 1
Pullstart
Found the 2” pipe I sunk in the ground a year ago, and am now excavating a track for the two new dump basins.
  • Like 4
Pullstart
I got all the piping complete, then it was time to backfill!
Pullstart
About 9:20 tonight Mrs. P and I finished the mud work!  She helped a ton!
  • Like 4
Pullstart
We woke up to 2” of ground water that had seeped into the new mud.  I was freaking out, the pool guy was not ao concerned.  I wet vacuumed the majority of the mess, and he added dry vermiculite and some hydraulic cement.  I a couple hours it looked like a pool again!
  • Excellent 6
SylvanLakeWH
Pool cam at Pullstart's a few minutes ago...
Must be snack break... :scared-eek:
  • Haha 7
Handy Don
3 hours ago, Pullstart said:
in a couple hours it looked like a pool again
Did you put the water into the tank truck originally?
Some years ago a local pool water company was found to be drawing water from a drinking water reservoir without a permit. It was soon after 9’/11 and they were reported by an observer who suspected the operators were putting something into the water, not drawing it out. Fines and reputation loss “tanked” the business.
Pullstart
This company has permits to obtain water from a hydrant.  It was 10,000 gallons of fresh never been peed in water.
@SylvanLakeWH B)
  • Haha 3
WHX??
I can fix that B)
  • Haha 5
SylvanLakeWH
:scared-eek:
  • Haha 1
Pullstart
Edited by Pullstart
  • Excellent 2
Pullstart
So close to being full, but having the bottom sump is great for circulation!
Pullstart
It’s full enough to give my well a rest, and give the pool a vacuum job!  Yay!
