Pullstart
Back Yard Pool Project
Pullstart
5th try, and it’s still not what I imagined, but it’s water proof and looks decent.  I will try to duplicate the other end, but you can’t see them both at the same time :lol:
I have foam rubber closure pieces to stuff under the roof edge before screwing if down too.
Pullstart
Shed construction is finished, shy of door latches and door sheet metal.  Yay!
  • Excellent 4
Pullstart
I received my latches, and got to work.  The door is just a tickle over 1-1/2” thick, built using 2x4s and all.  :D
The first issue, was that the brackets were more than 2” long.  That doesn’t work for me.  I bought some uni-strut for this project and I have not used any yet.  I have a feeling things will change soon.
Pullstart
A little cut here, drill there, and tack weld about, and I have a latch that fits inside my door.  It still has no way to hold the door from swinging in the wind
(yet).
Pullstart
The latch fits inside the door, and I believe with another roll pin through that 304 stainless steel rod, it can create a key to engage the post bracket.  I’ll need to trim the length of the rod, but it’s proving to be doable.
Pullstart
Rod drilled, post bracket built.
Pullstart
Proof of concept!  I can build the remaining latches and trim the rods to length, then install them in the door frames.  I’ll then install the door steel, drill through holes, and assemble.  This feels good!
Pullstart
I trimmed the rod to length and assembled one latch.  The door opens and closes with clearance, and shuts well.  Now I just need to blow the rest of the latches apart and repeat the process.
Pullstart
The front door can latch open or closed, and will function smooth.  Plus a bonus it’s custom :lol:
Pullstart
I’m soaked from the rain, but making progress!
Handy Don
But hey, the stuff inside is mostly dry. 😉
  • Haha 1
Pullstart
I realized I am behind on video updates on this, so I went through the archives since October and tossed stuff together.  It’ll be releasing in the next few days.  🤠
Pullstart
Fence components ordered :unsure:
  • Sad 1
Pullstart
Video update from a while back up to now
Pullstart
  • Heart 1
953 nut
:confusion-shrug:              Will there be a huge Release Gala with celebrities walking the red carpet like they do in Hollywood?             :teasing-poke:
Lights! Camera! Gala! An Evening of ...
  • Haha 1
Pullstart
  • Excellent 3
953 nut
Siskel and Ebert give it a BIG thumbs up.
  • Haha 1
Pullstart
Pullstart
SylvanLakeWH
:eusa-clap:
