Pullhosen’s Pony Express 98 #126 Posted October 10, 2025 41 minutes ago, rjg854 said: Well now that's something I've never seen before, Tyvek on a roof. I suppose it should be ok. It was actually quite slippery when dry! I just wanted to shed water and I had this. It’s probably not ideal but it does currently work. 2 1 Share this post Link to post Share on other sites
rjg854 12,963 #127 Posted October 10, 2025 As long as it's doing what you want it to do, that's the important thing. Are planning on shingles? I don't see why you couldn't leave it for that purpose too. 1 Share this post Link to post Share on other sites
Pullstart 69,702 #128 Posted October 10, 2025 2 hours ago, rjg854 said: As long as it's doing what you want it to do, that's the important thing. Are planning on shingles? I don't see why you couldn't leave it for that purpose too. Steel 1 Share this post Link to post Share on other sites
Handy Don 16,279 #129 Posted October 10, 2025 16 hours ago, WHX?? said: So isn't 24 OC for our snow loading For our area, and for steeply pitched, we were well within the code--I made sure to confirm with the architect! 😀 1 Share this post Link to post Share on other sites
Handy Don 16,279 #130 Posted October 10, 2025 2 hours ago, Pullhosen’s Pony Express said: It’s probably not ideal but it does currently work. It does allow vapor-sized molecules to pass through slowly. 1 Share this post Link to post Share on other sites
Pullstart 69,702 #131 Posted October 11, 2025 The construction is pretty much wrapped up. Time for making it weather proof! 3 3 Share this post Link to post Share on other sites
Pullstart 69,702 #132 Posted April 19 Yep, I’m still grinding away on this. I have 34 or so days until Jada’s graduation party. Most every piece needs to be cut to length and trimmed somehow to fit. It’s time consuming, so I am using whatever dry weather I have to get it done. 5 4 Share this post Link to post Share on other sites
SylvanLakeWH 31,109 #133 Posted April 19 (edited) Looks great!!! Please - no pictures of you in a Speedo and cowboy boots... Edited April 19 by SylvanLakeWH 1 4 Share this post Link to post Share on other sites
Pullstart 69,702 #134 Posted April 20 8 minutes ago, SylvanLakeWH said: Looks great!!! Please - no pictures of you in a Speedo and cowboy boots... Thats kind of a given… duh!! 2 1 1 1 Share this post Link to post Share on other sites
Bill D 2,770 #135 Posted April 20 36 minutes ago, SylvanLakeWH said: Looks great!!! Please - no pictures of you in a Speedo and cowboy boots... There's a mental image I didn't need before bed! 1 5 Share this post Link to post Share on other sites
Pullstart 69,702 #136 Posted April 20 13 minutes ago, Bill D said: There's a mental image I didn't need before bed! sweet dreams 1 6 Share this post Link to post Share on other sites
Pullstart 69,702 #137 Posted April 20 There’s lots of work today to get 70 square foot of steel mounted up! Back window and door openings are cut out, window is in and I need to trim and seal it up. Back sliding door track is installed and trimmed as well. 8 3 Share this post Link to post Share on other sites
WHX?? 56,132 #138 Posted April 21 (edited) On 4/19/2026 at 6:37 PM, Pullstart said: Most every piece needs to be cut to length and trimmed somehow to fit. Not getting that. You'd a measured & ordered right the only cuts would have been on the gable ends? I can see I shoulda stuck around a few more days and showed how to do it! Edited April 21 by WHX?? 1 4 Share this post Link to post Share on other sites
wallfish 19,745 #139 Posted April 21 On 4/19/2026 at 7:37 PM, Pullstart said: Yep, I’m still grinding away on this. I have 34 or so days until Jada’s graduation party. Congratulations Jada!!!! 1 1 Share this post Link to post Share on other sites
Pullstart 69,702 #140 Posted April 21 1 hour ago, WHX?? said: Not getting that. You'd a measured & ordered right the only cuts would have been on the gable ends? I can see I shoulda stuck around a few more days and showed how to do it! I gave the steel supplier my building measurements, they gave me a stack of steel. Most of it is all long, I think I have used 3 pieces at length. 2 Share this post Link to post Share on other sites
Pullstart 69,702 #141 Posted April 21 I screwed up a couple pieces. Or they aren’t screwed up. I had to order a couple more pieces, but can still work on the front. 4 1 Share this post Link to post Share on other sites
Pullstart 69,702 #142 Posted 9 hours ago I have the door frames built and hung. I am brainstorming my method of door closure. If possible, I’d like to prevent any more holes in the concrete. However, I have no other access to latch from the inside. Then, I’ll install bottom trim and the sheet steel. 3 1 Share this post Link to post Share on other sites
Pullstart 69,702 #143 Posted 9 hours ago I have four of these style latches coming. There wasn’t anything locally that I could find. My thoughts are to make a keyhole slot in the angle bracket (or use a chunk of unistrut with a slotted hole) and stick another roll pin through the end of the rod. Push in, quarter turn. Low enough to hold the door bottoms closed and possibly another latch to hold it open as well. There are so many methods of keepers, rollers, etc. it’s hard to say the right or wrong way to hold a rolling door open! Share this post Link to post Share on other sites
Streetrodchev 1,081 #144 Posted 3 hours ago Would a “jamb latch” work for you? Share this post Link to post Share on other sites
Pullstart 69,702 #145 Posted 1 hour ago 1 hour ago, Streetrodchev said: Would a “jamb latch” work for you? Unfortunately no. Those work from the inside, and I have no man doors to access otherwise. Share this post Link to post Share on other sites
WHX?? 56,132 #146 Posted 1 hour ago Do you even really need latches other than to keep the wind from banging them around? Share this post Link to post Share on other sites
Pullstart 69,702 #147 Posted 24 minutes ago 1 hour ago, WHX?? said: Do you even really need latches other than to keep the wind from banging them around? Exactly Share this post Link to post Share on other sites
