Pullstart
Back Yard Pool Project
Pullhosen’s Pony Express
41 minutes ago, rjg854 said:
Well now that's something I've never seen before, Tyvek on a roof.  :scratchead:
I suppose it should be ok.
It was actually quite slippery when dry!  I just wanted to shed water and I had this.  It’s probably not ideal but it does currently work.
  • Heart 1
rjg854
As long as it's doing what you want it to do, that's the important thing.  Are planning on shingles? I don't see why you couldn't leave it for that purpose too.
Pullstart
Steel
Handy Don
16 hours ago, WHX?? said:
So isn't 24 OC for our snow loading
For our area, and for steeply pitched, we were well within the code--I made sure to confirm with the architect! 😀
Handy Don
It does allow vapor-sized molecules to pass through slowly.
Pullstart
The construction is pretty much wrapped up.  Time for making it weather proof!
  • Excellent 3
SylvanLakeWH
Posted (edited)
Looks great!!! :handgestures-thumbupright:
Please - no pictures of you in a Speedo and cowboy boots... :scared-eek:
Edited by SylvanLakeWH
  • Haha 4
Pullstart
Thats kind of a given… duh!!
  • Haha 1
  • Confused 1
Bill D
There's a mental image I didn't need before bed!
  • Haha 5
Pullstart
sweet dreams :lol:
  • Haha 6
WHX??
Posted (edited)
On 4/19/2026 at 6:37 PM, Pullstart said:
Most every piece needs to be cut to length and trimmed somehow to fit.
Not getting that. You'd a measured & ordered right the only cuts would have been on the gable ends? I can see I shoulda stuck around a few more days and showed how to do it! :lol:
Edited by WHX??
  • Haha 4
wallfish
On 4/19/2026 at 7:37 PM, Pullstart said:
Yep, I’m still grinding away on this.  I have 34 or so days until Jada’s graduation party.  :rolleyes:
Congratulations Jada!!!! :greetings-clapyellow:
  • Heart 1
Pullstart
I gave the steel supplier my building measurements, they gave me a stack of steel.  Most of it is all long, I think I have used 3 pieces at length.  :unsure:
Pullstart
I screwed up a couple pieces.  Or they aren’t screwed up.  :confusion-confused:
I had to order a couple more pieces, but can still work on the front.
  • Like 5
Pullstart
I have the door frames built and hung.  I am brainstorming my method of door closure.  If possible, I’d like to prevent any more holes in the concrete.  However, I have no other access to latch from the inside.  Then, I’ll install bottom trim and the sheet steel.
  • Like 4
Pullstart
I have four of these style latches coming.  There wasn’t anything locally that I could find.  My thoughts are to make a keyhole slot in the angle bracket (or use a chunk of unistrut with a slotted hole) and stick another roll pin through the end of the rod.  Push in, quarter turn.  Low enough to hold the door bottoms closed and possibly another latch to hold it open as well.  There are so many methods of keepers, rollers, etc.  it’s hard to say the right or wrong way to hold a rolling door open!
Streetrodchev
Would a “jamb latch” work for you?
Pullstart
Unfortunately no.  Those work from the inside, and I have no man doors to access otherwise.
WHX??
Do you even really need latches other than to keep the wind from banging them around?
Pullstart
Exactly :lol:
wallfish
Spit balling ideas :twocents-02cents:
My sliders only wedge to lock in the closed position
  • Excellent 2
Pullstart
That’s simple and easy John.  I like it!  Now will it work with my doors?  :confusion-confused::greetings-clappingyellow:
Pullstart
One last trim edge to do, and I’m glad to have a little extra material.  Lots of compound angles to trial and error and error and error and figure and error some more.
I’m hopeful that I will get this corner all mathed out, so the opposite will be equal measurements and easy to pop on.
  • Like 5
