adsm08 3,444 #26 Posted September 2 (edited) I don't know how you have the time to do all this. I have about an hour a day to work on my projects. Edited September 2 by adsm08 1 Share this post Link to post Share on other sites
Pullstart 67,332 #27 Posted September 3 1 hour ago, adsm08 said: I don't know how you have the time to do all this. I have about an hour a day to work on my projects. I spent 14 hours on it today. I don’t schedule many customer projects, when there’s a major undertaking like this to make Momma happy. I do have an Equinox that needs a fuel pump and a Subaru that needs a power steering pump and a few other things. 3 Share this post Link to post Share on other sites
rjg854 12,331 #28 Posted September 3 12 hours ago, Pullstart said: I don’t schedule many customer projects, when there’s a major undertaking like this to make Momma happy. A man has got to have his priorities! 3 Share this post Link to post Share on other sites
Pullstart 67,332 #29 Posted September 3 Fixin’ and buildin’ 1 Share this post Link to post Share on other sites
Pullstart 67,332 #30 Posted September 3 Rain delay… which is fine for a mid day coffee break. My shop’s a mess and I’ll spend the afternoon working in there doing some tidy work. I need to fab up a diving board anchor too, once I get the shop in ship shape. Share this post Link to post Share on other sites
Pullstart 67,332 #31 Posted September 3 I have been asking my concrete guy questions and guidance along the way. Friday was the plan for him to come set forms, but this rain delays him a bit. Friday is Grandma’s funeral service and I wouldn’t have been available to help or answer/ask questions. That’s been pushed to Monday, which is great! I was stressing over this not being adequate to make a great pour. He assured me that the efforts I’ve put into the job have far exceeded where he would normally start. He has all week next week set aside for this job only and he won’t allow the project to fail. Monday is setup day. Tuesday, Wednesday, and Thursday if needed, we’ll pour. Thursday/Friday, we clean up and cut lines. Yay! 2 5 Share this post Link to post Share on other sites
953 nut 60,819 #32 Posted September 3 22 hours ago, Pullstart said: major undertaking like this to make Momma happy. 9 hours ago, rjg854 said: A man has got to have his priorities! Kevin has his priorities set correctly, Keep Mrs. Pulstart happy and life is good. 2 Share this post Link to post Share on other sites
adsm08 3,444 #33 Posted September 3 22 hours ago, Pullstart said: I don’t schedule many customer projects, when there’s a major undertaking like this to make Momma happy. I take it that means you are self-employed. That would explain a lot. 2 Share this post Link to post Share on other sites
Pullstart 67,332 #34 Posted September 4 Cleaned up the shop yesterday and rocked out a fuel pump in an equinox. Two sending units? What? Silliness. 5 Share this post Link to post Share on other sites
Handy Don 14,244 #35 Posted September 4 Haven’t seen a plate compactor in use yet in any of your vids. I am hoping the excavation contractor is compacting in layers on the backfills. Just running a bobcat back and forth isn’t generally considered adequate compaction of soil. 2 Share this post Link to post Share on other sites
Pullstart 67,332 #36 Posted September 4 47 minutes ago, Handy Don said: the excavation contractor is me We have had some massive rains, and I have also been compacting too, wetting down the deep areas of fill (trenches), etc. We will bring in a gas powered compactor too come Monday, after forms are set. 2 Share this post Link to post Share on other sites
adsm08 3,444 #37 Posted September 5 12 hours ago, Pullstart said: Two sending units? Very common on saddlebag tanks. Very annoying. Typically they both display the same resistance range and then whatever module is responsible for monitoring that averages the readings. Brilliant from an engineering stand point, stupid in the real world. I've seen more than one where the side that's just a sender hangs, or the transfer tube fails and fuel isn't pumped from the far side, and the gauge says 1/2 a tank, but you run out of fuel. Share this post Link to post Share on other sites
Pullstart 67,332 #38 Posted September 5 The pit is 4 miles away. It’s nice to have the resources all around! 5 Share this post Link to post Share on other sites
Pullstart 67,332 #39 Posted September 6 My A/C system is a year old. I was able to use the compressor to pump the Freon out of the line set and shut it down, then un-sweat the lines for a clean disconnect. 1 Share this post Link to post Share on other sites
953 nut 60,819 #40 Posted September 6 1 hour ago, Pullstart said: then un-sweat the lines for a clean disconnect. Aren't refrigeration lines hard soldered (silver solder)? I didn't know they could be separated by heating, Share this post Link to post Share on other sites
Pullstart 67,332 #41 Posted September 6 Just now, 953 nut said: Aren't refrigeration lines hard soldered (silver solder)? I didn't know they could be separated by heating, Yes, they are silver soldered. Enough heat, it melts again. I have stay-silv flux and silver solder in my plumber’s crack box to get it back together. 3 1 Share this post Link to post Share on other sites
Pullstart 67,332 #42 Posted September 7 All my helpers with good intent… 2 1 Share this post Link to post Share on other sites
Pullstart 67,332 #44 Posted Monday at 09:14 PM The concrete guys were here today. They loved the prep work and have an amazing 4 pours in three days plan! but first… 3 Share this post Link to post Share on other sites
Pullstart 67,332 #45 Posted Monday at 11:05 PM This is the general drawing of the pool plan. We ended up moving the pool house back 3’ for a larger gap between the diving board and the pool house doors. The pool house will now be 8’x24’x10’ sidewall. Tomorrow we pour the blue section. Wednesday morning the red sections, and in the afternoon the green. Thursday morning we finish with the yellow. Hopefully when we’re done, the rainbow will all be grey scale! 2 Share this post Link to post Share on other sites
Wayne0 1,295 #46 Posted Monday at 11:13 PM Nice pen. 2 1 Share this post Link to post Share on other sites
953 nut 60,819 #47 Posted Monday at 11:27 PM 20 minutes ago, Pullstart said: Tomorrow we pour the blue section. Wednesday morning the red sections, and in the afternoon the green. Thursday morning we finish with the yellow. Hope the concrete finishers can stay inside the lines, unlike you. 7 Share this post Link to post Share on other sites
Pullstart 67,332 #48 Posted Tuesday at 07:20 AM 8 hours ago, Wayne0 said: Nice pen. That’s a bolt action exotic wood custom from one of my father inlaw’s coworkers. 3 Share this post Link to post Share on other sites
Pullstart 67,332 #49 Posted Tuesday at 07:21 AM 3:20 am. Heading to drop Mrs. P at the airport for a work conference. She’ll get home to all fresh concrete! 2 1 Share this post Link to post Share on other sites
953 nut 60,819 #50 Posted Tuesday at 12:17 PM 4 hours ago, Pullstart said: She’ll get home to all fresh concrete! Good planning on her part, anything goes wrong it wasn't her fault, she has an ironclad alibi. 1 3 Share this post Link to post Share on other sites
