Chrishar
Suburban 400 project
Chrishar
Started to look at some stuff found out the motor oil was over full and mikey looking so I decided to drain it and found water in it so I will have clean it out and look at it and got to fix the exhaust on the motor too that's what I found so far
oliver2-44
@Chrishar I think I have a pipe tap to tap that Kohler exhaust like the suburbans originally had.
Chrishar
That would be great if you have one oliver2-44
clueless
Sorry about that, I never remover the cover that was on it. The water most like got in from there, it did sit outside off and on during the last 10+ years. Have you removed the head yet?
Edited by clueless
Chrishar
No not yet
Chrishar
Been busy and waiting for parts to come in for it
Chrishar
Took motor off and will take it apart to clean it and check it out to make sure everything is good because it had water in it
Chrishar
Take transmission apart something is not right with it and does anybody have a hood stand for it
Chrishar
So the transmission has water in it too yay
Chrishar
So what I was thinking it has bad bearings it was a rebuild transmission so this is what happens when water gets in there it was hard to turn the brake pulley so now have to order a transmission kit for it hope the motor is not this bad
Chrishar
Going to be a bigger project then what I thought it was going to be
Chrishar
Just waiting on some bearings and a gasket set to come in so I can get this put all back together again
clueless
Please let me know what the engine looks like when you open it, you are due some refund from me.
Chrishar
I will let you know what I find out I hope not to bad
Easton Rich
On 8/5/2025 at 10:26 PM, Chrishar said:
Here's the 400 I went and pickup in Florida just needs a little of TLC to get it going again
Understatement.
wallfish
What's wrong with the hood stand?
Chrishar
It's broken in four places and some one tried to fix it but not so good I can probably fix it but if I could find one to replace it that would help me on time to get it done for a show coming up soon
Chrishar
  • Sad 1
Chrishar
Front rims came in today I just got to clean up paint and put new tires on
Chrishar
Pulled the head off and it looks good
Chrishar
Clean the old paint off and I still have to pull the oil pan and clean the inside of motor and going to reseal the motor too
Chrishar
I'm still waiting on transmission kit to come in
Chrishar
Had sometime last tonight to work on motor so I took it apart cleaned it and put all new gaskets on
Chrishar
Painted some parts and the motor  too
