davem1111 2,314 #1 Posted July 27, 2025 So, the 1987 312-A that I've had for quite a few years (my first horse) has been running badly lately. It blows black smoke when choking it to start, runs rough then smooths out a lot with the choke open. However, it just starts coughing and dies after about 10-15 minutes (yeah, it's been bloody hot lately, so that could be a factor). 1. No, I'm not running non-ethanol gas in it right now, but I have tried to switch to that later in the season with all my tractors so there's no ethanol in them over the winter. 2. OEM fuel pump died a few years ago and I replaced it with a CarBole 12v pump. I don't have any reason to suspect this - yet. 3. Filter seems good, need to check the screen on the tank valve, and check the gas cap. 4. Suspecting engine wear, I bought a compression tester. Getting about 70 psi. This is "cold", I haven't tried to warm it up before checking. 5. Was reading about "leak down" tests, wondering if I should be trying that. 6. The circuit board with the indicator LEDs is in bad shape and I had to do some soldering/splicing a while back to get good connections, maybe something is not good electrically. Any and all advice welcome. 2 Share this post Link to post Share on other sites
squonk 47,887 #2 Posted July 27, 2025 My first thought is if this is a Magnum I have seen many coils go bad on these. @Racinbob just went through this. 3 1 Share this post Link to post Share on other sites
ri702bill 12,808 #3 Posted July 27, 2025 1 hour ago, squonk said: My first thought is if this is a Magnum I have seen many coils go bad on these. @Racinbob just went through this. I second that. Use an inline spark checker. Start it up cold, when it dies, see if you have spark on the hot restart. Most likely no spark. Once the coil cools off, it will provide spark. Very annoying. 2 1 Share this post Link to post Share on other sites
953 nut 68,501 #4 Posted July 27, 2025 3 hours ago, davem1111 said: 1. No, I'm not running non-ethanol gas in it right now, but I have tried to switch to that later in the season with all my tractors so there's no ethanol in them over the winter. Doesn't take too long for the ethanol to do damage. A new fuel hose, filter, and a heavy dose of Barryman's B-12 could be the answer. 2. OEM fuel pump died a few years ago and I replaced it with a CarBole 12v pump. I don't have any reason to suspect this - yet. 3. Filter seems good, need to check the screen on the tank valve, and check the gas cap. 4. Suspecting engine wear, I bought a compression tester. Getting about 70 psi. This is "cold", I haven't tried to warm it up before checking. With a compression release cam that is good compression. 5. Was reading about "leak down" tests, wondering if I should be trying that. Couldn't hurt but doubt it is needed. 6. The circuit board with the indicator LEDs is in bad shape and I had to do some soldering/splicing a while back to get good connections, maybe something is not good electrically. Those lights have nothing to do with your engine. 1 Share this post Link to post Share on other sites
Racinbob 13,110 #5 Posted July 28, 2025 4 hours ago, squonk said: My first thought is if this is a Magnum I have seen many coils go bad on these. @Racinbob just went through this. The symptoms are a fair amount different from mine. The black smoke thing and coughing never happened to me. But it definitely could be the culprit. Share this post Link to post Share on other sites
Rick3478 462 #6 Posted July 31, 2025 On first read, it sounds like over-rich fuel/air mix. Black smoke when choked is a normal thing, due to rich mix making lots of soot, but if it doesn't clear up when un-choked, it may still be running rich. If the carburetor has never been apart, a good cleaning and adjustment may be in order. The needle valve wears shorter with age, which raises the float level and fuel/air mix gets richer. And I would be remiss to not mention the air filter, which acts like a choke if it is clogged. Share this post Link to post Share on other sites
Rick3478 462 #7 Posted July 31, 2025 Quick thought about that CarBole fuel pump. Make sure you have the low pressure version. 2 to 3 PSI is plenty. The higher pressure automotive versions can overpower the needle valve and flood out. Share this post Link to post Share on other sites
peter lena 10,013 #8 Posted August 1, 2025 @953 nut have had zero / fuel issues since changing out all related hoses ,and regularly adding an ounce or two , of STA BIL to all my fuel , fuel filters are clean / clear , fuel bows are clean / clear , what is that telling you ? have also detailed all related linkage areas for functional movement ease . cables move / slide with a light spring assist , super lube hydraulic oil in all cables . repetitive problems let you get after every detail , eliminate and move on . pete 1 Share this post Link to post Share on other sites
953 nut 68,501 #9 Posted August 1, 2025 6 minutes ago, peter lena said: regularly adding an ounce or two , of STA BIL to all my fuel I am a firm beleaver in an ounce (or two) of prevention being worth a pound of cure. Every can of non-ethanol gas that comes in my shop has two ounces of Sta-Bil and two ounces of Berryman's B 12 in it. A couple of years ago I had a stroke and none of my small engine equipment was fired up for a year, some sat for two years, but I have had no fule related issues with any of them. 1 Share this post Link to post Share on other sites
peter lena 10,013 #10 Posted August 1, 2025 @953 nut glad to hear that , another thing I often suggest is laying in a 5/16 steel brake line ,the length of the frame , tucked into the corner bend , hiding in plane site , and also eliminating a big chunk of rubber hose , ends can be a swage compression to screw in barb , for short run to tank and carb , also a good spot for a filter . my stand by generator sits , and always quickly starts . filter is never , dirty in any way . sta bil , repetitive problems let you see and think about your plan , commonality is changing what's going on. done a lot of that , like a roller stool to really look at issue , what's going on ? , what if I try this ? really like that approach on attachments , all they really need is function detailing , for easy / quiet / smooth operation . good talking , pete Share this post Link to post Share on other sites
