Terry M-(Moderator) 2,255 #1 Posted July 26 Years ago I picked up this short frame plow and today I decided to put it together. Long story short, it won’t mount up to the existing bracket as the part of the plow frame is too wide for the bracket. I’ve never dabbled with this type of implement before. so…sounding stupid..do I have an odd plow or do I need a different mounting bracket. bracket originally came on this tractor…Guess I could research but thought maybe a quick answer was to be found here.. model stamping on the tag is hard to read…possibly BD 4254 or 4257. 1 Share this post Link to post Share on other sites
squonk 44,091 #2 Posted July 26 I think if the left bracket Ron the right and the right was on the left it would work. I ran into something similar once but don't remember how I solved it. The plow looks right. 2 1 Share this post Link to post Share on other sites
stevasaurus 23,355 #3 Posted July 26 It is the right plow for your horse Terry. They do make two different brackets. One for your series plow and one for the "B" & "C" type horses. The plow blade either mounts outside the locking do-hickies or the do-hickies are on the inside. 2 Share this post Link to post Share on other sites
oldlineman 1,567 #4 Posted July 26 that's what I was thinking squonk 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #5 Posted July 26 6 minutes ago, squonk said: I think if the left bracket Ron the right and the right was on the left it would work. I ran into something similar once but don't remember how I solved it. The plow looks right. Bracket is one piece …sounds like I need a different bracket… Share this post Link to post Share on other sites
moe1965 766 #6 Posted July 26 I like the idea of the quick removable pin to switch out the hitch. I'm going to do the same to mine 2 Share this post Link to post Share on other sites
stevasaurus 23,355 #7 Posted July 26 Check with Lowell, Terry. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #8 Posted July 26 Just now, stevasaurus said: Check with Lowell, Terry. Good idea… Share this post Link to post Share on other sites
squonk 44,091 #9 Posted July 26 18 minutes ago, Terry M said: Bracket is one piece …sounds like I need a different bracket… I think I cut the piece that connects both sides turned the brackets around and re welded them. As I remember the brackets on our 604 we had back in the 60's were not connected together. 2 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #10 Posted July 26 Here’s a pic of the bracket removed …definitely won’t work…this shows the difference a lot better.. I’ll have @wheelhorseman check this out.. Share this post Link to post Share on other sites
wheelhorseman 3,239 #11 Posted July 26 3 minutes ago, Terry M said: Here’s a pic of the bracket removed …definitely won’t work…this shows the difference a lot better.. I’ll have @wheelhorseman check this out.. That plow was meant to use the angle iron bracket - like this 1 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #12 Posted July 26 I’m guessing I have a newer plow than my 606 would have used back in 1966? Share this post Link to post Share on other sites
squonk 44,091 #13 Posted July 26 (edited) The bracket you have looks like to me a long frame plow bracket. If you were to cut off the connector piece, turn the brackets around, connect to the plow on the shiny outer part it would work. Edited July 26 by squonk 2 Share this post Link to post Share on other sites
wheelhorseman 3,239 #14 Posted July 26 1 minute ago, Terry M said: I’m guessing I have a newer plow than my 606 would have used back in 1966? No you have the newer bracket, the plow is correct 3 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #15 Posted July 26 5 minutes ago, squonk said: The bracket you have looks like to me a long frame plow bracket. If you were to cut off the connector piece, turn the brackets around, connect to the plow on the shiny outer part it would work. I may consider doing that…or I may just find a correct bracket…I thought at one time I had one that wasn’t connected between sides…I’ll need to dig in my parts boxes and see.. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,588 #16 Posted July 27 The early brackets bolted to the front of the square axle housing - not the bottom like later models. Best guess 4 Share this post Link to post Share on other sites
