PWL216
K91R Auction Buy
PWL216
I was the winning bidder on a pump powered by a Kohler K91R engine. Based on its specs it’s a 1961. I don’t really have a need for it at the moment, but couldn’t pass it up. Here’s what I found about the K91…
  • Model: Kohler K91
  • Spec Number: 31504A
  • Serial Number: 3019680
  • Horsepower: ~4 HP
  • Shaft Orientation: Horizontal (most likely, based on spec)
  • Year of Manufacture: 1961
About Spec Number 31504A
Kohler’s spec number identifies the exact configuration of the engine — including shaft size, PTO options, mounting patterns, and whether it’s for a tractor, generator, or industrial use. While full public spec decoding guides are rare, the “A” suffix usually designates a factory revision or minor configuration changes.
Spec 31504A is known to have been used on early Wheel Horse tractors, most likely models like:
  • RJ-58
  • RJ-59
  • Suburban 400 or 550
  • Excellent 3
oliver2-44
Great buy!
Interesting diaphragm pump.
ebinmaine
Neeeeaaatt.
Cute little tires too.
Ed Kennell
Great find.  Any data on the pump capacity?
PWL216
@Ed Kennell Hi Ed. I pick it up Monday and it comes with the manual. Will know then. I was wondering if I should keep the whole thing together or just pull the engine, since I don’t need a pump. Thoughts on that?
PWL216
18 minutes ago, oliver2-44 said:
Great buy!
@oliver2-44 Thx. Paid a whopping $10.90 for it ;)
Ed Kennell
Posted (edited)
It would make a great display piece for a tractor show.     Maybe pumping water up to a small flume that operates a small waterwheel that turns a fan, ice cream churn, etc.
Edited by Ed Kennell
  • Excellent 3
  • Heart 2
ebinmaine
Seconded.
Chris G
Posted (edited)
I would say use it as a display piece as well. Chances are that the end of the crankshaft has a star style end on it. Due to the gear reduction on it. So to use for a RJ or suburban you would probably have to change crankshaft. I attached a photo of what I mean by the different end on the crankshaft. But besides all that I'd also say it's a pretty cool find
Edited by Chris G
oliver2-44
That type of pump should be able to pump a slurry, cement grout, mud.
oliver2-44
Posted (edited)
That’s almost disgusting 😂
Help us feel better and tell you had to spend a lot on gas or something going to pick it up!
Edited by oliver2-44
  • Haha 3
953 nut
We called the mud pumps, they were great for removing groundwater from a trench before pouring a footer.
  • Similar Content
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Stigian
      By Stigian
      Morning all, Nigel and I fired up his
      suburban yesterday and although the engine sounds sweet with no nasty noises the govenor arm does not move freely.
      Cleaning it and a touch of oil has helped a bit but it's still too stiff to move as it should.
      Are we going to have to pull the engine out and pull it apart to see if the problem is internal or will the gov free itself up
      after a while?
      I'm guessing were not the only ones to have this problem, so what did you do to sort it?
      Thanks Guys.
