Similar Content
By Jennifer
Husband wants some advice… lol. So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running! The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice??? It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky.. checked the gap and pull again… same thing over and over! Thanks in advance!
By Stigian
Morning all, Nigel and I fired up his
suburban yesterday and although the engine sounds sweet with no nasty noises the govenor arm does not move freely.
Cleaning it and a touch of oil has helped a bit but it's still too stiff to move as it should.
Are we going to have to pull the engine out and pull it apart to see if the problem is internal or will the gov free itself up
after a while?
I'm guessing were not the only ones to have this problem, so what did you do to sort it?
Thanks Guys.
