TGooser 0 #1 Posted July 24, 2025 Hello all. i looked up a lift cylinder and of course none are available unless you find a used one. is there any source that sells a kit of the seals and O-rings to rebuild one at home? i see that there was a repair kit back in the day Share this post Link to post Share on other sites
lynnmor 8,720 #2 Posted July 24, 2025 If your cylinder has a large snap ring holding it together, I have a kit for that. If your cylinder is welded together there is/was a guy in the vendors section that will cut them apart and rebuild. 2 Share this post Link to post Share on other sites
ebinmaine 78,072 #3 Posted July 24, 2025 3 hours ago, TGooser said: is there any source @lynnmor has ya covered in the cylinder. Just as FYI, ALL the parts for a Wheelhorse are available if one knows where to look. @76c12091520h is Brian Badman. Excellent source for many things. There are more....... Share this post Link to post Share on other sites
adsm08 4,323 #4 Posted July 24, 2025 (edited) 3 hours ago, lynnmor said: If your cylinder is welded together there is/was a guy in the vendors section that will cut them apart and rebuild. @wheelhorseman offers this service through Wheelhorsepartsandmore.com. There is also a guy here in Dillsburg that offers hydraulic cylinder repairs on a wide variety of things. I've lost his number, but if I remember I'll grab it when I go that way again. Edited July 24, 2025 by adsm08 Share this post Link to post Share on other sites
