AHS 1,695 #26 Posted July 26, 2025 I see that you have fuel filters after the fuel pump. It would make sense for you to have them before? So that you know filtered fuel is going thru it or is that a no no? Share this post Link to post Share on other sites
squonk 47,420 #27 Posted July 26, 2025 23 minutes ago, AHS said: I see that you have fuel filters after the fuel pump. It would make sense for you to have them before? So that you know filtered fuel is going thru it or is that a no no? Filter should be BEFORE the pump. 2 Share this post Link to post Share on other sites
Ed Kennell 46,608 #28 Posted July 26, 2025 Some of the better pumps come with a filter on the pump inlet. 2 Share this post Link to post Share on other sites
adsm08 4,804 #29 Posted July 26, 2025 8 hours ago, squonk said: Filter should be BEFORE the pump. Why not both? Share this post Link to post Share on other sites
squonk 47,420 #30 Posted July 26, 2025 26 minutes ago, adsm08 said: Why not both? You can if you want but keep the trash out of the pump. Doesn't take much to lock up a pump. I had a tiny piece of a valve stem seal lock up an oil pump on a Dodge 318 once. 2 Share this post Link to post Share on other sites
peter lena 9,951 #31 Posted July 27, 2025 (edited) @kpinnc also have my electric pumps up front with no issues , often refer to fuel hose , breakdown / debris issues , when ever I encounter a CHRONIC / REPEDITIVE PROBLEM , i make a change ? you know what does not work . since going over to STABIL , fuel storage additive , and new hoses throughout , my filters are always clean, clear , that alone was worth the experiment ! always top of my tanks with an ounce or two , of stabil . fuel bowls are clean / clear , instant starts , also have fuel hose vertical check valves before the carb , so you can see fuel held to carb , regularly keep in touch with everything , and touch up accordingly . if your fuel hoses are breaking down , you have to replace ALL OF THEM , and try something different . realise this is a bone of contention , clean / clear fuel filters , pete Edited July 27, 2025 by peter lena 1 Share this post Link to post Share on other sites
