AHS 1,544 #26 Posted 19 hours ago I see that you have fuel filters after the fuel pump. It would make sense for you to have them before? So that you know filtered fuel is going thru it or is that a no no? Share this post Link to post Share on other sites
squonk 43,769 #27 Posted 19 hours ago 23 minutes ago, AHS said: I see that you have fuel filters after the fuel pump. It would make sense for you to have them before? So that you know filtered fuel is going thru it or is that a no no? Filter should be BEFORE the pump. 1 Share this post Link to post Share on other sites
Ed Kennell 41,896 #28 Posted 19 hours ago Some of the better pumps come with a filter on the pump inlet. 1 Share this post Link to post Share on other sites
adsm08 3,198 #29 Posted 11 hours ago 8 hours ago, squonk said: Filter should be BEFORE the pump. Why not both? Share this post Link to post Share on other sites
squonk 43,769 #30 Posted 11 hours ago 26 minutes ago, adsm08 said: Why not both? You can if you want but keep the trash out of the pump. Doesn't take much to lock up a pump. I had a tiny piece of a valve stem seal lock up an oil pump on a Dodge 318 once. Share this post Link to post Share on other sites
