Teddy da Bear62
Avoid overfilling the gas tank
Teddy da Bear62
Hey guys and Gals!
Something that has plagued this old bear for decades.  I tend to overfill gas tanks!
I have to use funnel.  I try to watch and listen as the sound changes as it nears full.
But inevitably, I overflow the tank maybe 10% of the time.
This seems to contribute to dangerous situations such as fires🔥.......some even ummmm......recently......😏
I'm looking for suggestions to avoid this.
Other than hearing aides, stronger glasses, better supervision.....etc.
Is there anything on the market to prevent gas tank overflow?  I know pumps at the station have it.  But I am not dragging wheel horse to gas station.
I want something for a gas can.
ebinmaine
We use a battery operated fuel pump wand.
Works great.
  • Like 5
lynnmor
Works great.
One with an automatic shut off is especially useful.
Teddy da Bear62
Very interesting
pfrederi
  • Like 5
adsm08
Or a smaller gas can. The tank on my WH is about 1/2 gallon. I take a 5 gallon tank to the station, at home I fill into a 1 gallon tank the amount I think I need, then put a little back. Using the smaller can also give a lot more control.
  • Like 4
Teddy da Bear62
Your idea has merit.
Sometimes this crusty old bear is lifting a 5 gallon army, Gerry can.
rjg854
This what I use, and have for years. I my opinion the only way to fly.
  • Like 4
Teddy da Bear62
Can I get make and model from you please?
And thank you!
953 nut
I have used the "NO SPILL GAS CAN" for several years. You control the flow with a push button on the spout, no gas comes out until you push the button. It has a float in the spout that will shut off the flow for you when the tank is nearly full.
No-spill 2.5 Gallon Gas Fuel Can - 1405
  • Like 4
Teddy da Bear62
Thank you, but that still involves lifting a heavy gas can at times.
I'm still leaning on rjg854's unit.
I think the can will remain on the floor?
rmaynard
After 60 plus years of filling small gas tanks, I have mastered the art of only spilling about a 1/4 cup full. For me, that's perfection.
Just don't fill them running, or over the grass. :lol:
At age 75 I find lifting a 5 gallon can near impossible without an incident. Therefore, I transfer gas into several 1 or 2 gallon cans. Much easier and more control.
Edited by rmaynard
  • Like 5
953 nut
It is only a 2 1/2 gallon can, I am 80, I've had a stroke and get around on a walker so the smaller can is just right for me.
Edited by 953 nut
  • Excellent 2
Wild Bill 633
I like using VP fuel jugs with the Flo-Fast hand pump with 80 micron filter. I have 3 setups. 1 for home, 1 for the trailer and 1 for the motorcycle.
rjg854
Flea Bay does have cheaper ones, but I have no experience with them.  I've had good luck with this brand.  The first one lasted about 5 years, and the one I have now is about 3 years old.  But yes, you can leave the can sitting on the ground, and the hose is long enough to reach the tank easily.  And shuts off auto-magic-ly.
HyperPete
Here's what I have.  2 years and still going strong.
I use it with my 15 gallon fuel "cans" as well as the 5 gallon cans.
663360124_Screenshot_20250702_065820_AmazonShopping.jpg.08a4f8bee40792a88f8b9dae58d8557b.jpg
Teddy da Bear62
I like the simplicity of this.
But some mentioning they last about 5 years.  The longevity isn't there.
No offense.
Teddy da Bear62
I like this one for the price.
But has no auto-stop.
HyperPete
No offense.
No offense taken.
If you buy on the jungle site, you can buy a warranty inexpensively.  I don't remember if I bought mine there, or at Tractor supply, but I bought a 4-year warranty for it for under $10. So, if it dies before 4 years, I'll get a new one at no charge. That will certainly be worth the money, assuming the second one last at least 3 years. 6 to 8 years for that price is well worth it.
HyperPete
By the way, I have both of these.
Note the different flow rates between the two.
2 - 4 gallons per minute for the one I posted.
5 - 6 quarts per minute for the one you posted.
I notice a BIG difference.
sqrlgtr
Best thing ever cant believe I waited this long to buy one. Tried to find one like @rjg854 has pictured but found this one local. Works great :handgestures-thumbupright:
Lee1977
It does get to be a problem when you can't see or hear.  I usually try to stop at around 3/4 full.
If I try to stop at full I usually run it over. Getting old is a real _____, an I've al ready got there.
rjg854
Posted (edited)
@Lee1977
Try a battery powered pump like this one it has an automatic shutoff.
https://ebay.us/m/wMk0xA
Edited by rjg854
add
