Teddy da Bear62 172 #1 Posted June 29, 2025 Hey guys and Gals! Something that has plagued this old bear for decades. I tend to overfill gas tanks! I have to use funnel. I try to watch and listen as the sound changes as it nears full. But inevitably, I overflow the tank maybe 10% of the time. This seems to contribute to dangerous situations such as fires🔥.......some even ummmm......recently......😏 I'm looking for suggestions to avoid this. Other than hearing aides, stronger glasses, better supervision.....etc. Is there anything on the market to prevent gas tank overflow? I know pumps at the station have it. But I am not dragging wheel horse to gas station. I want something for a gas can. 1 Share this post Link to post Share on other sites
ebinmaine 79,716 #2 Posted June 29, 2025 We use a battery operated fuel pump wand. Works great. 5 Share this post Link to post Share on other sites
lynnmor 8,914 #3 Posted June 29, 2025 2 minutes ago, ebinmaine said: We use a battery operated fuel pump wand. Works great. One with an automatic shut off is especially useful. 2 Share this post Link to post Share on other sites
Teddy da Bear62 172 #4 Posted June 29, 2025 Very interesting 1 Share this post Link to post Share on other sites
adsm08 4,802 #6 Posted June 29, 2025 Or a smaller gas can. The tank on my WH is about 1/2 gallon. I take a 5 gallon tank to the station, at home I fill into a 1 gallon tank the amount I think I need, then put a little back. Using the smaller can also give a lot more control. 4 Share this post Link to post Share on other sites
Teddy da Bear62 172 #7 Posted June 29, 2025 10 minutes ago, adsm08 said: Or a smaller gas can. The tank on my WH is about 1/2 gallon. I take a 5 gallon tank to the station, at home I fill into a 1 gallon tank the amount I think I need, then put a little back. Using the smaller can also give a lot more control. Your idea has merit. Sometimes this crusty old bear is lifting a 5 gallon army, Gerry can. 1 Share this post Link to post Share on other sites
rjg854 13,199 #8 Posted June 29, 2025 3 hours ago, lynnmor said: One with an automatic shut off is especially useful. This what I use, and have for years. I my opinion the only way to fly. 4 Share this post Link to post Share on other sites
Teddy da Bear62 172 #9 Posted June 29, 2025 1 hour ago, rjg854 said: This what I use, and have for years. I my opinion the only way to fly. Can I get make and model from you please? And thank you! 1 Share this post Link to post Share on other sites
953 nut 67,463 #10 Posted June 29, 2025 I have used the "NO SPILL GAS CAN" for several years. You control the flow with a push button on the spout, no gas comes out until you push the button. It has a float in the spout that will shut off the flow for you when the tank is nearly full. 4 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #11 Posted June 29, 2025 7 minutes ago, 953 nut said: I have used the "NO SPILL GAS CAN" for several years. You control the flow with a push button on the spout, no gas comes out until you push the button. It has a float in the spout that will shut off the flow for you when the tank is nearly full. Thank you, but that still involves lifting a heavy gas can at times. I'm still leaning on rjg854's unit. I think the can will remain on the floor? 1 Share this post Link to post Share on other sites
rmaynard 17,432 #12 Posted June 29, 2025 (edited) After 60 plus years of filling small gas tanks, I have mastered the art of only spilling about a 1/4 cup full. For me, that's perfection. Just don't fill them running, or over the grass. At age 75 I find lifting a 5 gallon can near impossible without an incident. Therefore, I transfer gas into several 1 or 2 gallon cans. Much easier and more control. Edited June 29, 2025 by rmaynard 5 1 Share this post Link to post Share on other sites
953 nut 67,463 #13 Posted June 29, 2025 (edited) 29 minutes ago, Teddy da Bear62 said: Thank you, but that still involves lifting a heavy gas can at times. It is only a 2 1/2 gallon can, I am 80, I've had a stroke and get around on a walker so the smaller can is just right for me. Edited June 29, 2025 by 953 nut 2 2 Share this post Link to post Share on other sites
lynnmor 8,914 #14 Posted June 30, 2025 3 hours ago, Teddy da Bear62 said: Can I get make and model from you please? And thank you! https://www.terapump.net/products/trfa01-4th-gen-gas-can-fuel-transfer-pump Shop around, they can be found at better prices. 2 Share this post Link to post Share on other sites
Wild Bill 633 936 #15 Posted June 30, 2025 I like using VP fuel jugs with the Flo-Fast hand pump with 80 micron filter. I have 3 setups. 1 for home, 1 for the trailer and 1 for the motorcycle. Share this post Link to post Share on other sites
rjg854 13,199 #16 Posted June 30, 2025 (edited) @Teddy da Bear62 https://ebay.us/m/KcSAr8 This is where I got mine. Edited June 30, 2025 by rjg854 add Share this post Link to post Share on other sites
rjg854 13,199 #17 Posted June 30, 2025 Flea Bay does have cheaper ones, but I have no experience with them. I've had good luck with this brand. The first one lasted about 5 years, and the one I have now is about 3 years old. But yes, you can leave the can sitting on the ground, and the hose is long enough to reach the tank easily. And shuts off auto-magic-ly. 2 Share this post Link to post Share on other sites
HyperPete 939 #18 Posted July 2, 2025 Here's what I have. 2 years and still going strong. I use it with my 15 gallon fuel "cans" as well as the 5 gallon cans. 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #19 Posted July 2, 2025 1 hour ago, HyperPete said: Here's what I have. 2 years and still going strong. I use it with my 15 gallon fuel "cans" as well as the 5 gallon cans. I like the simplicity of this. But some mentioning they last about 5 years. The longevity isn't there. No offense. Share this post Link to post Share on other sites
Teddy da Bear62 172 #20 Posted July 2, 2025 I like this one for the price. But has no auto-stop. Share this post Link to post Share on other sites
HyperPete 939 #21 Posted July 3, 2025 11 hours ago, Teddy da Bear62 said: I like the simplicity of this. But some mentioning they last about 5 years. The longevity isn't there. No offense. No offense taken. If you buy on the jungle site, you can buy a warranty inexpensively. I don't remember if I bought mine there, or at Tractor supply, but I bought a 4-year warranty for it for under $10. So, if it dies before 4 years, I'll get a new one at no charge. That will certainly be worth the money, assuming the second one last at least 3 years. 6 to 8 years for that price is well worth it. 1 Share this post Link to post Share on other sites
HyperPete 939 #22 Posted July 3, 2025 On 7/2/2025 at 9:16 AM, Teddy da Bear62 said: I like this one for the price. But has no auto-stop. By the way, I have both of these. Note the different flow rates between the two. 2 - 4 gallons per minute for the one I posted. 5 - 6 quarts per minute for the one you posted. I notice a BIG difference. Share this post Link to post Share on other sites
sqrlgtr 3,293 #23 Posted January 6 Best thing ever cant believe I waited this long to buy one. Tried to find one like @rjg854 has pictured but found this one local. Works great 2 Share this post Link to post Share on other sites
Lee1977 7,710 #24 Posted January 9 It does get to be a problem when you can't see or hear. I usually try to stop at around 3/4 full. If I try to stop at full I usually run it over. Getting old is a real _____, an I've al ready got there. ----- Share this post Link to post Share on other sites
rjg854 13,199 #25 Posted January 9 (edited) @Lee1977 Try a battery powered pump like this one it has an automatic shutoff. https://ebay.us/m/wMk0xA Edited January 9 by rjg854 add Share this post Link to post Share on other sites
